Rotation of spin projection different to general rotation?
In summary: U^{\dagger}(\boldsymbol{\alpha})\mathbf{a} \cdot U(\boldsymbol{\alpha})\mathbf{\hat{x}} U^{\dagger}(\boldsymbol{\alpha})U(\boldsymbol{\alpha}) = U^{\dagger}(\boldsymbol{\alpha})\mathbf{a} \cdot \mathbf{\hat{x}}(\theta)$$Finally, using the property ##S = R(\boldsymbol{\alpha})##, we can write the expression as:$$U^{\dagger}(\boldsymbol{\alpha})\mathbf{a} \cdot \mathbf{\hat{x}}(\theta) = U^{\dagger}(\bold
bananabandana
113
Prove, for the matrix ##S = exp
\bigg(-\frac{i}{\hbar}\mathbf{\hat{n}}\cdot \mathbf{\hat{S}}\bigg)## (spin-rotation matrix), and for an arbitary vector ##\mathbf{a}## that:
$$ S^{-1} \mathbf{a} \cdot \mathbf{\hat{x}} S = a(-\theta) \cdot \mathbf{x} = a \cdot \mathbf{x}(\theta) $$
Let ##\langle \psi| \mathbf{V} \rangle = \mathbf{V}_{0}##. Where ##\mathbf{V}## is some vector operator. Then (after Binney, Physics of Qunatum Mechanics,pg74):
Where ##\boldsymbol{\alpha}## is an axis of rotation, and let ##\mathbf{R}(\boldsymbol{\alpha})## be a rotation operator about that axis.
$$ \mathbf{R}(\boldsymbol{\alpha})\mathbf{V} = U^{\dagger}(\boldsymbol{\alpha})\mathbf{V}U(\boldsymbol{\alpha})$$
i.e as standard. Apart from that, I have no idea where to begin! Apparently this is based on some 'standard relation in tensor calculus (read, matrix manipulations here, I think) - but I have no idea what is happening!
Thanks
for posting in the forum! First, let's define some variables for clarity. Let ##S = exp\bigg(-\frac{i}{\hbar}\mathbf{\hat{n}}\cdot \mathbf{\hat{S}}\bigg)## and ##\mathbf{a}## be an arbitrary vector. We also have the spin-rotation matrix ##S^{-1}##.
To prove the given statement, we need to show that ##S^{-1} \mathbf{a} \cdot \mathbf{\hat{x}} S = a(-\theta) \cdot \mathbf{x} = a \cdot \mathbf{x}(\theta)##.
To do this, we can use the definition of the spin-rotation matrix ##S## and the rotation operator ##R(\boldsymbol{\alpha})##. We can write ##S## as ##S = R(\boldsymbol{\alpha})##, where ##\boldsymbol{\alpha} = -\frac{i}{\hbar}\mathbf{\hat{n}}\cdot \mathbf{\hat{S}}##.
Next, we can use the relation mentioned in the post, ##\mathbf{R}(\boldsymbol{\alpha})\mathbf{V} = U^{\dagger}(\boldsymbol{\alpha})\mathbf{V}U(\boldsymbol{\alpha})##, to rewrite the left-hand side of the given statement. We get:
$$S^{-1} \mathbf{a} \cdot \mathbf{\hat{x}} S = U^{\dagger}(\boldsymbol{\alpha})\mathbf{a} \cdot \mathbf{\hat{x}} U(\boldsymbol{\alpha})$$
Now, we can use the properties of the rotation operator to simplify this expression. We know that the rotation operator ##U(\boldsymbol{\alpha})## satisfies the following relation:
$$U(\boldsymbol{\alpha})\mathbf{\hat{x}} U^{\dagger}(\boldsymbol{\alpha}) = \mathbf{\hat{x}}(\theta)$$
where ##\theta = |\boldsymbol{\alpha}|##. Using this relation, we can rewrite the above expression as:
$$U^{\dagger}(\boldsymbol{\alpha})\mathbf{a} \cdot \mathbf{\hat{x}} U(\boldsymbol{\alpha}) =
Related to Rotation of spin projection different to general rotation?
1. What is the difference between rotation of spin projection and general rotation?
Rotation of spin projection refers to the change in the orientation of an object's spin, while general rotation refers to the change in orientation of the entire object. In other words, rotation of spin projection refers specifically to the rotation of an object's internal angular momentum, whereas general rotation refers to the rotation of the entire object, including its translational motion.
2. How does rotation of spin projection differ from general rotation in terms of quantum mechanics?
In quantum mechanics, rotation of spin projection is described by the laws of spin angular momentum, which are different from the laws of general rotation. The spin of an object is described by its intrinsic angular momentum, which is a fundamental property of particles, while general rotation is described by the laws of classical mechanics.
3. Can an object have different spin projection and general rotation?
Yes, an object can have different spin projection and general rotation. For example, a spinning top has both spin angular momentum and general rotation, but they are not necessarily aligned with each other. This means that the direction of the top's spin may change while it is rotating, resulting in different spin projection and general rotation at the same time.
4. What are the practical applications of understanding rotation of spin projection and general rotation?
Understanding rotation of spin projection and general rotation is important in many areas of physics, including quantum mechanics, nuclear physics, and astrophysics. It is also essential in the development of technologies such as magnetic resonance imaging (MRI) and nuclear magnetic resonance (NMR) spectroscopy.
5. How do scientists measure rotation of spin projection and general rotation?
Scientists can measure rotation of spin projection and general rotation using various techniques such as angular momentum spectroscopy, which involves analyzing the angular distribution of particles emitted from a rotating object. In addition, techniques such as NMR and MRI use the principles of rotation of spin projection and general rotation to produce images and information about the structure of molecules and materials.
  • Quantum Physics
