Rotational Dynamics Practice Problems Help
In summary, the conversation is about a student's upcoming test in their AP Physics C class on Rotation Dynamics. They mention that their teacher gave them a practice exam over the weekend, and while they initially felt confident, they are now struggling with the difficult questions. The student then shares their attempts at solving some of the problems, but asks for help on two others. They also mention using equations for kinetic energy and time for a case 1 trajectory. The conversation then shifts to a different problem involving spheres, a rod, and a clay lump, and the student shares their attempts at solving it but expresses confusion on finding the angular velocity and angular momentum.
Lavitz
My AP Physics C class has a test tomorrow about Rotation Dynamics and my teacher gave us a practive exam over the weekend and i felt really good about it thinking i was going to do really well, but this practice exam is really difficult and I am stuck on every problem. there are four problems but ill try to get help with them 1 at a time.
A large sphere rolls without slipping(pure rolling) across a horizontal surface. The sphere has a constant translational velocity of 10 m/s, a mass of 25kg, and a radius of 0.2 m. The sphere approaches the 25 degree incline of height 3 m as shown in the attached file and rolls up the incline without slipping. (entire problem and questions attached)
Vo = 10 m/s
m = 25 kg
r = 0.2 m
ϑ = 25 degrees
h = 3 m
(also I'm using g = 10 m/s^2)
KE = 1/2 mv^2 + 1/2 Iw^2
I = 2/5 MR^2 (solid sphere)
TEa = TEb
ok i did parts a and b but I am stuck at c, and i feel really stupid for not being able to figure it out but here's what i have so far.
a.) to find the total kinetic energy, i used
KE = 1/2 mv^2 + 1/2 Iw^2 and plugged in the inertia and omega, and solved it down to
KE = 1750 joules
b.) to find the velocity, i used
TEa = TEb for TEa i plugged in 1750 and for TEb i plugged in the kinetich and potential energy.
1750 = 1/2 mv^2 + 1/2 Iw^2 + mgh plugged in everything and solved it down to
v = 7.56 m/s
now part c asks for how far in the x direction it travels after flying off the plane. i know that it will leave the inclined plane in a case 1 trajectory but i have forgotten a lot of the trajectory motion stuff we did at the beginning of the year and i have completely forgotten how to find the time. once i have the time i would plug it into Sx=Vo(sin ϑ)t. i have an equation for the time of a case 1 trajectory but the sphere falls another 3 meters after it is level with the point it left from.
if anyone could help me find the time for this spot i would much appreciate it.-EDIT-
ok i figured out #1 by myself. to find the time you set Sy = -3 and use the equation
Sy = Vo(Sin ϑ)t - 1/2gt^2 plug in and move it around to get the quadratic
0 = -5t^2 = 3.18t - 3 use the quadractic equation and use the positive result as the time
t = 1.16 s
then plug that into
Sx = Vo(Cos ϑ)t plug in all variables and solve
Sx = 7.98 mI also solved my problems with #2 so i won't post that. but i have some issues on #3 and 4 as well so ill post them next.
I must say that you have indeed,beautifully described the problem. It is really a good thread to start with.
The c part is much easier than the rest.
You know the velocity at the highest point now we know that
[tex] H = \frac{v^{2}sin^2\theta}{2g}[/tex]
[tex] T = \frac{2vsin\theta}{g}[/tex]
solving them we get that
[tex] T = \sqrt{\frac{2H}{g}}[/tex]
We want H and that we have it already.
Hard to explain. See the attachment for the problem statement.
http://img524.imageshack.us/img524/3558/problem3rr9.th.jpg
each sphere has
- mass = m
- small r
the rod has
- length = l
- negligable mass.
the clay lump has
- mass = m
- initial velocity = Vo
all answers should be in terms of m, Vo, l, and fundamental constants.
KE = 1/2 mv^2
W = change in KE (KEf - KEo)
Xcm = (m1x1 + m2x2)/(m1+m2)
Pi = Pf
Li = Lf
for part a, you need to find the velocity after the collision using
m1v1 + m2v2 = (m1 + m2)v'
mVo + 0 = (m + 2m) v'
v' = Vo / 3
then for ai.) use
KE = 1/2 mv^2 plug in Vo / 3 fo V and solve down to
KE = (mVo^2) / 6
for aii.) use
W = change in KE
W = KEf - KEo
W = 1/6 mv^2 - 1/2 mv^2
W = 1/6 mv^2 - 3/6 mv^2
W = -(mVo^2)/3for part b.) you know that once the clay lump hits the other object, the new object is going to rotate about the center of mass, and the center of mass is going to continue to move in a linear path. so first you need to find the center of mass.
bi.)
Xcm = (m1x1 + m2x2)/(m1 + m2) using the left sphere as the 0 point,
Xcm = 0 + 2ml / 3m
Xcm = 2/3 L
bii.)
as i said before, the CoM continues to move in a linear path so the direction would be straight upward on the paper.
biii.)
we know that both angular and linear momentum are conserved so the linear speed will be the same as if it was hit in the center. so
V' = Vo/3
heres where I am stuck though. I am not sure how to go about finding the angular momentum and thus, the angular speed. of the object. and I am also not sure what to do for bv. either. would it be the same as aii.) since the V' is the same?
I am not able to see anything.
So please write down the problem.
i hosted the image on an outside hosting site and edited it into the Problem statement section.
i have a feeling that to find the angular velocity I am going to need to use
v = ωR
just I am not sure how i would go about implementing this formula. i have the linear velocity of the center of mass, but it isn't at the center. it is 2/3 the length from the left side of the system. and if i use the equation at the center of mass, the R is 0 so the whole thing cancels out to 0 so I am not sure what to do here.
Now we know that
[tex]Impulse(J) = mv[/tex]
Also
[tex] Jx = I\omega[/tex]
Where x is the distance of impulse from the point of rotation.Solving them we can get relation between v and omega.
v is not equal to omega(r) as it is not pure rolling.
FAQ: Rotational Dynamics Practice Problems Help
1. What is rotational dynamics and why is it important?
Rotational dynamics is the branch of physics that deals with the motion of objects that are rotating around a fixed axis. It is important because it helps us understand and analyze the behavior of various rotating systems, such as wheels, gears, and celestial bodies.
2. How do I solve rotational dynamics practice problems?
To solve rotational dynamics practice problems, you will need to apply the principles of torque, angular velocity, and rotational inertia. First, identify the known and unknown quantities and then use the relevant equations to solve for the unknown quantity.
3. What are some common mistakes to avoid when solving rotational dynamics problems?
Some common mistakes to avoid when solving rotational dynamics problems include not properly accounting for the direction of torque and angular velocity, forgetting to convert units to the correct form, and not considering the effects of friction and other external forces.
4. How can I improve my understanding of rotational dynamics?
To improve your understanding of rotational dynamics, it is important to practice solving problems and to review the relevant concepts and equations. You can also watch online tutorials or attend a workshop or class to deepen your understanding.
5. Can you provide some real-world examples of rotational dynamics?
Some real-world examples of rotational dynamics include the motion of planets and stars in the solar system, the rotation of tires on a car, the spinning of a top, and the movement of a spinning gyroscope. These examples demonstrate the principles of angular velocity, torque, and rotational inertia in action.
