Rotational force of motor + potential gear reduction
In summary: It sounds like you'll be using an Arduino with a motor shield to control your stepper motor. You'll want to set up the motor so that it knows where "zero" is, and then use limit switches to ensure that the screen stays in its desired position.
bpm009
I'm trying to determine how powerful of a stepper motor I need for a project. I am attempting to take a display that weighs 15lbs and transition it from laying flat to inclined (approximately 45 degrees) using a stepper motor. I had considered a linear actuator since it would have been an easier build but clearance under the display is an issue and I have more room horizontally.
I haven't done the exact measurements for the lifting arm as I'm not sure if a gear reduction will be needed yet but for example purpose I was thinking of a 5in moment arm from the center of the motor. Even though the display will pivot at the bottom and be supported I figured that when laying flat the motor still has to have enough force to lift the full 15lbs at the 5in displacement for a moment of 75lb-in.
Motors I have looked at talk of a "holding torque" value as what describes them. Did a little research on holding torque but still not 100% understanding the term. These values, for most ideal sized motors, rarely exceeds 250 oz-in or about 15.5lb-in.
Am I right in needing to optimize "holding torque" > moment? In which case if I want to utilize the 15.5lb-in motor I would then need to perform at least a 1:5 gear reduction in order to boost my torque to 77.5lb-in to accommodate the max moment?
Thanks for any input.
You are correct in assuming you'll want the holding torque of the motor/gearbox to be greater than the required torque (plus a safety factor). Ideally, you'll want the motor's "self-braking" torque to be greater than the required torque in the upright position, so that you don't need to power the motor to maintain position of the screen. In that case, the powered torque of the motor will be plenty strong, and you'll be limited by the resting torque of the motor/gearbox combo.
Is a motor's "self-braking" torque a factor of holding torque or is it variable based on motor design/application. When looking at most stepper motors holding torque is typically the only torque value given. Otherwise the specifications are just electrical and physical sizes. Thanks for the self-braking point as I do not want to have the motor constantly powered to resist the load.
I came upon the idea of replacing a stepper and gear reduction with a worm gear motor. I know with worm gears you can't drive the input with the output technically so with my output being the force from the upright screen, would I then be safe in finding a worm gear motor that has a torque rating higher than what my torque requirement is?
I think a worm gear could be a good idea for the reason you're stating- they are very difficult to back-drive so you could position the screen and then power down the motor. It will also be easy to find larger gear reductions when using a worm gear. Will you be using limit switches to detect the position of the screen? If so, it might not be necessary to use a stepper motor at all, and you could instead use a simple DC motor.
That is to be my new problem because with the stepper motor I hadn't planned to use limit switches and base my code off of step counts to provide limits that way. I know I will have to add in limit switches now yes (not quite sure how or best options yet). I had less experience with limit switches and more with coding so that was the reason for stepper over DC motor but I will look into both worm gear and DC motor since I will need limit switches with either.
I appreciate all the info... Civil Engineer attempting to be a Mechanical Engineer here lol. Now it is onward to limit switch options.
With any stepper motor you still need to use some sort of "home" switch to define zero before you can start counting steps from that position. With any motor it's usually best-practice to have switches for at least the travel limits. Any simple switch should work, or even things like optical sensors or flags, but first you should decide what kind of controller you're using and then choose a switch that's compatible with it. So, what kind of controller will you be programming to control the motor?
Likes Greg Bernhardt
I've been opting to go with an arduino with motor shield as the controller. I had planned on setting up the motor and designating the "zero" point to base the steps off of after since I didn't plan on moving the gear position after. It would still be smart to go with limit switches as a failsafe I'm sure and I should just do my research on them anyway.
Related to Rotational force of motor + potential gear reduction
1. What is rotational force?
Rotational force is a type of force that causes an object to rotate around an axis or pivot point. It is also known as torque and is measured in units of newton-meters (Nm).
2. How is rotational force related to motors?
A motor is a device that converts electrical energy into rotational force. The rotational force produced by a motor is dependent on factors such as the strength of the magnetic field, the number of coils in the motor, and the amount of current flowing through the coils.
3. What is gear reduction and how does it affect rotational force?
Gear reduction is the process of using gears to decrease the speed of rotation and increase the torque output of a motor. This is achieved by using a smaller gear (known as the pinion) to drive a larger gear (known as the gear). The gear reduction ratio is the ratio of the number of teeth on the gear to the number of teeth on the pinion. A higher gear reduction ratio will result in a higher torque output but a lower speed of rotation.
4. What factors determine the potential gear reduction in a motor?
The potential gear reduction in a motor is dependent on several factors, including the gear ratio, the motor's speed and torque ratings, and the load that the motor will be driving. It is important to select a gear reduction that is suitable for the specific motor and application to ensure optimal performance.
5. How is rotational force and potential gear reduction important in machinery and equipment?
Rotational force and potential gear reduction play a crucial role in many types of machinery and equipment, particularly in applications where high torque is required. These include vehicles, industrial machinery, and robotics. Properly understanding and utilizing rotational force and gear reduction can result in more efficient and effective operation of these machines.
  • Mechanical Engineering
