Rotational Forces on a Hollow Cylinder
To model the rotational speed of a hollow cylinder fixed on a horizontal axle with a tangential force applied, the moment of inertia (I) is crucial. The relevant formula for a cylindrical shell is I = MR^2, where M is the mass and R is the radius. The relationship between torque, moment of inertia, and angular acceleration can be expressed as torque = I * angular acceleration. The mass of the cylinder can be calculated using the formula mass = π * r² * l * ρ. Understanding these equations will help in determining the angular acceleration and rotational speed of the cylinder.
Ben Reynolds
I am trying to model a hollow cylinder of known radius r, length l and density rho.
The cylinder is fixed on a horizontal axle along its longest axis (l) and will have a force F applied tangentially to its surface and perpendicular to its axis, with negligible frictional forces acting between it and the axle.
What equations could I use to model the speed of its rotation?
Mass = pi*r2*l*rho
Some equation involving moments, potentially?
I am a mathematician and have little work on angular velocity, so I apologise for the trouble.
I have attempted to find a relevant equation but all searches gave either inapplicable scenarios or equations quoted ad verbatim with no clarification to notation.
Do you know about moment of inertia... how it is defined, the formula for the MoI of a cylinder, its use in angular acceleration...?
Okay, so I have found the equation I = MR^2 for a cylindrical shell of negligible width being rotated along its long axis, which is close to what I'm looking for. However, I would not know how to include such an equation in finding angular acceleration.
It's very like the linear equation: torque about axis = moment of inertia about axis * angular acceleration about axis.
That's perfect, thanks!
  • · Replies 21 ·
  • · Replies 40 ·
