Rotational Freefall and Designation of Axis
In summary, the conversation discusses the concepts of torque and rotational motion in relation to objects falling from a height. The first question raises the issue of a rotating object experiencing slower acceleration due to the conservation of energy, and the second question delves into the arbitrariness of the axis of rotation and its relationship to applied torque. The experts provide explanations and clarify misconceptions, ultimately concluding that torque is not simply an extension of force and that applying torque to an object implies no applied linear force. The conversation ends with a hypothetical scenario of a pen moving and rotating in space.
WhackyWookie
Well, I'm not even sure if freefall is the right word, but my first quandary is as followed:
If two objects fall from the same height, and one object will begin to rotate after it has been release (ie. a yoyo), while the other will not rotate, then the rotating object will accelerate slower and hit the ground after the non-rotated one because of conservation of energy (PE = translational KE + Rotational KE).
But I can't seem to justify the slower acceleration of the rotating object in the force point of view since, based on my understanding, the torque of the rotating object should not affect the net force on the CM, therefore, the net forces on the CMs of both object should be the same and the translational acceleration should then also be equal.
I know there is something wrong with my logic, but I can't find where. Any help would be much appreciated.
My second question has to do with a quote in my physics textbook: "we see that if a body is to remain at rest, the net torque applied to it (calculated about any axis) must be zero ... the choice of axis is arbitrary. If a body is at rest, then net torque = zero about any axis what so ever."
What I do not understand is why can the axis be arbitrary is definition of torque is force times distance to the axis? For example, if a large rigid stick has two equally strong torque of opposite direction acting on the two ends and one force that cancel out the translational effect of the torque acting on the CM, then the stick will remain at rest if and only if the axis of rotation is the CM, otherwise, the torque will be unbalanced and it will spin.
Any clarification is again, much appreciated. Thanks
1. Careful!
A yo-yo does not experience free-fall; the cord imparts an upwards force on the yo-yo acting tangentially,in the stretched cord's direction on the axis; hence the spinning, and the slower acceleration.
2.Here, you have not accounted for the moments of ALL forces around an arbitrary axis properly.
The argument is as follows:
Suppose we have balance of 3 forces, and balance of the three moments about a given axis, i.e:
[tex]\vec{F}_{1}+\vec{F}_{2}+\vec{F}_{3}=\vec{0},\vec{r}_{1}\times\vec{F}_{1}+\vec{r}_{2}\times\vec{F}_{2}+\vec{r}_{3}\times\vec{F}_{3}=\vec{0}[/tex]
Let us now consider the moments of the same forces about a differently situated axis.
The new position vectors to the points where the forces acts, are therefore:
[tex]\vec{r}_{N,1}=\vec{r}_{1}-\vec{x}_{A},\vec{r}_{N,2}=\vec{r}_{2}-\vec{x}_{A},\vec{r}_{N,3}=\vec{r}_{3}-\vec{x}_{A}[/tex]
(Here, [tex]\vec{x}_{A}[/tex] is the position vector of the "new" axis in the "old" coordinate system)
Computing the moment about the new axis yields:
[tex]\vec{r}_{N,1}\times\vec{F}_{1}+\vec{r}_{N,2}\times\vec{F}_{2}+\vec{r}_{N,3}\times\vec{F}_{3}=[/tex]
[tex]\vec{r}_{1}\times\vec{F}_{1}+\vec{r}_{2}\times\vec{F}_{2}+\vec{r}_{3}\times\vec{F}_{3}-\vec{x}_{A}\times(\vec{F}_{1}+\vec{F}_{2}+\vec{F}_{3})=\vec{0}[/tex]
I will let arildno's response to your first question speak for myself as well.
WhackyWookie said:
... I do not understand ... why can the axis be arbitrary is definition of torque is force times distance to the axis?
This is not quite the definition of [applied] torque. The definition should involve a cross product at least.
You are probably thinking of torque as some kind of extension or generalization of force. You should instead think of torque as the rotational analog of force. Both "force" and "torque" are subsets of the generalized/canonical force. Anyway, the point is that applying torque to a body already implies that you are not applying a translational/linear force.
There is a subtle difference in an applied force that induces a net torque about the CM vs. an applied torque to begin with which implies no applied linear force.
Here is a word document with some illustrations that may help:
  • applied_vs_induced_torque.doc
I understand arildno's explanation for the 2nd question. can't believe i overlooked that.
But the rest I'm still somewhat vague about.
can you guys elaborate a bit more in context to this question:
If one was to impart a force on the end of a pen in space at 90 degree, would the pen move forward and rotate or just rotate in the same position?
It would both move forward (i.e. its CM would translate) and it would rotate.
If you did not want the CM to move, you could get pure rotation by using two fingers, one at each end of the pen, pushing equally hard in opposite directions. (I am assuming an ideal pen with appropriate symmetries.)
FAQ: Rotational Freefall and Designation of Axis
1. What is rotational freefall?
Rotational freefall refers to an object's motion when it is falling freely through the air without any external forces acting on it. In this state, the object is subject to only the force of gravity, causing it to accelerate towards the ground.
2. How is rotational freefall different from regular freefall?
In regular freefall, an object falls straight down due to the force of gravity. In rotational freefall, the object is also rotating as it falls, causing its axis of rotation to change continuously.
3. What is the designation of axis in rotational freefall?
The designation of axis in rotational freefall refers to the direction around which an object is rotating as it falls. This can be designated as either the x, y, or z axis depending on the orientation of the object.
4. What factors affect the designation of axis in rotational freefall?
The primary factors that affect the designation of axis in rotational freefall are the shape, size, and mass distribution of the object. These factors determine the object's rotational inertia, which affects how it rotates during freefall.
5. How is the designation of axis important in designing objects for rotational freefall?
The designation of axis is crucial in designing objects for rotational freefall as it determines the object's stability and orientation during freefall. By understanding the designation of axis, scientists can design objects that maximize their stability and minimize any unwanted rotation during freefall.
