Tom79Tom
- 45
- 3
I am conducting an experiment that rotates a sealed donut cylinder to investigate amongst other things the inertia of the contained fluid.
Process
I rotate the cylinder to a set speed (assuming that the viscosity of the internal fluid will end up rotating the fluid to solid body rotation) then rapidly stop the vessel.
I have noticed little effect when I have filled the vessel is filled just with Air in fact no discernable effect
much akin to when you turn a fan off the flow seems to stop immediately with water the inertial flow is much greater and lasts longer
My question
Is this only because of the differences between air and water Kinematic viscosities
Air 15.11 cSt
Water 1.004 cst
meaning that viscous effects stop the dynamic pressure of air very quickly or is there other effects at play ?
Some come to mind
Gas vs Liquid - rate of diffusion ?
I would think that a gas would diffuse energy throughout the sealed vessel at a much greater rate due to the low interaction of particles where as a liquid which would have to displace molecules that contain there own dynamic pressure .
Total Mass
Could the net mass of the flow - (where as air has a mass of 1.35 kg/m3 water has a a mass of 1000kg/m3 be a factor ) for the equivalent volume and flow rate (from solid body rotation) the developed inertia contained in this volume is less to begin with
Process
My question
Air 15.11 cSt
Water 1.004 cst
Some come to mind
Total Mass
