- #36
member 731016
No worries @erobz! What was the mistake?erobz said:I goofed. Should be ##\frac{\sqrt{2}}{2} R##
Many thanks!
No worries! We all make algebra mistakes! Thank you for your reply @erobz!erobz said:##x^2 + x^2 = R^2##
##2x^2 = R^2##
##\implies x = \frac{R}{\sqrt{2}} = \frac{\sqrt{2}}{2} R##
Just carless algebra...late at night for me.
You should be able to work that out yourself. R is the distance from the centre of the square to one corner. How far is it from the centre of the square to the centre of one side? If x is a displacement along a side from its midpoint, what is the range of x?Callumnc1 said:
Thank you for your reply @haruspex!haruspex said:You should be able to work that out yourself. R is the distance from the centre of the square to one corner. How far is it from the centre of the square to the centre of one side? If x is a displacement along a side from its midpoint, what is the range of x?
Why do you want to solve this using vectors? It's straightforward using scalars and the parallel axis theorem.Callumnc1 said:Thank you for your reply @haruspex!
I was trying to consider cases where ##\vec r ≠ R## for when the position vector is pointing somewhere along to the mass element on the sides not to the corners.
When ##\vec r = R##, I can see that since it square then each side of the right triangle will have equal sides of length ##x##.
I think the range of x for that case would be from ##0## at the midpoint to ##\frac {R}{\sqrt{2}}## at the centre of one side.
Dose this special case hold for ##\vec r ≠ R##?
Many thanks!
The vector ## \vec{r}## varies, in both magnitude and direction, but for that horizontal segment It will always have the form:Callumnc1 said:No worries! We all make algebra mistakes! Thank you for your reply @erobz!
So, I'm just trying to understand how you got ## y\hat j = x\hat j##. I have drawn a grey square below.
I'm trying not to use circular reasoning, but did you get ## y\hat j = x\hat j## because ##\vec r## will always form a right isosceles triangle since it is a square so ##\theta = 45##?
Many thanks!
Thank you for your reply @haruspex !haruspex said:Why do you want to solve this using vectors? It's straightforward using scalars and the parallel axis theorem.
Edit: rereading your post, I don’t understand it. How are you defining ##\vec r## and x?
Thank you @erobz!erobz said:
Thank you for that @erobz!erobz said:The vector ## \vec{r}## varies, in both magnitude and direction, but for that horizontal segment It will always have the form:
$$ \vec{r} = x ~{\hat i} + \frac{\sqrt{2}}{2} R ~{\hat j}$$
Yes, that will always be the case for a square.Callumnc1 said:Thank you @erobz!
I think I now understand where you get that constant from now. So basically, you assume that both sides of the triangle are equal which means that angle must be 45 degrees.
So ##\sin45 = x/R## which gives your result.
Is that how you did it?
Many thanks!
Thank you for your reply @erobz !erobz said:Yes, that will always be the case for a square.
Thank you very much for that @nasu!nasu said:Won't be easier to just find the moment of inertia for a square of side L and mass m and then use the results for any value of L and for any way this side is related to another parameter in the problem, like to the radius here? You can do this in two or three lines, even by using the integral.
For one side of the square, the moment of inertia relative to the center is just $$\int_{-L/2}^{L/2} [(L/2)^2+x^2]\lambda dx =\lambda L (L/2)^2+\lambda \frac{x^3}{3}\Big|_{-L/2}^{L/2} =\lambda L (L/2)^2+\lambda \frac{2L^3}{3\times 8}$$
I considered the x axis parallel to the side I am looking at.
Using ##M=\lambda L## you get
$$I_{side} =m\frac{L^2}{4}+m \frac{L^2}{12}$$
The last term is the moment of inertia for an axis going through the center of the bar (look it up in a table) and the first term is what you add by using the parallel axis theorem. You could write this right away, without any integral.
Then the monemt of the square is just ##I_{square}=4I_{side}##.
Only now is time to see what happens if ##L=R\sqrt{2}##.
