Rotational Inertia Seesaw Picot
In summary, the rotational inertia of the seesaw pivot can be calculated using the formula Inet = Ia + Ig + Ib, where Ia represents the moment of inertia of Alice, Ig represents the moment of inertia of the seesaw, and Ib represents the moment of inertia of Bonnie. In this specific scenario, the rotational inertia is equal to 625 kg/m^2^. However, there seems to be a discrepancy in the calculation of Ib, as the distance should be measured from the center/pivot instead of the end of the seesaw. This could potentially affect the accuracy of the calculated rotational inertia.
premedonna89
CORRECTION ON TITLE: it should be "Rotational Inertia Seesaw Pivot"
Alice (20kg) and Bonnie (25kg) sit on seesaw (10m long, 12 kg mass). Pivot of seesaw is in the middle. In order for the seesaw to stay level we determined (in the previous step of the multi-part problem) that Bonnie has to sit 4 m away from the pivot/center.
What is the rotational inertia of this system about the seesaw pivot?
Inet = Ia + Ig + Ib
I = mass x radius^2^
Ig = 1/12 x mass x length^2^
I actually have the answer already (this is a practice exam). But I don't understand how he got it.
Inet = Ia + Ig + Ib
Inet = mass,a x radius,a^2^ + 1/12 x mass x length^2^ + mass,b x radius,b^2^
Inet = 500 + 100 + 25
Inet = 625 kg/m^2^
I don't understand how:
mass,b x radius,b^2^ = 25
Shouldn't it be: 25 x 4^2^ = 400 ?
I imagine radius, b = 1, therefore 1 square is just 1. Since Bonnie is sitting 4 meters away from the center, and the edge is 5 meters away from the center, so 5 minus 4 = 1. Then multiply that by 25 kg to get 25. However, I can't find anywhere in the textbook section for inertia that says to measure radius from the end of the seesaw (?) rather than from the center/pivot.
Thank you!
You can of course calculate the moment of inertia with respect to any point (and the result is different for different points) but you're right about this making no sense at all. The distance in your formulas is indeed the distance from the point where you wish to calculate I.
Hello,
Thank you for sharing your attempt at solving this problem. Rotational inertia, also known as moment of inertia, is a measure of an object's resistance to rotational motion. It depends on both the mass of the object and its distribution of mass around the axis of rotation.
In this case, the seesaw is a long thin object with most of its mass concentrated at the ends where Alice and Bonnie are sitting. The rotational inertia of this system is calculated by adding the individual moments of inertia of each object, Alice (Ia), Bonnie (Ib), and the seesaw itself (Ig).
The moment of inertia of a point mass (I = mr^2) is calculated using the distance from the axis of rotation (r) and the mass (m) of the object. In this case, the distance from the seesaw pivot to Alice (radius,a) is 5 meters, and the distance from the pivot to Bonnie (radius,b) is 4 meters. So, the moment of inertia for Alice (Ia) is calculated as:
Ia = 20kg x (5m)^2 = 500 kgm^2
Similarly, the moment of inertia for Bonnie (Ib) is calculated as:
Ib = 25kg x (4m)^2 = 400 kgm^2
Lastly, the moment of inertia for the seesaw itself (Ig) is calculated using the parallel axis theorem, which takes into account the distribution of mass along the length of the object. This is where the 1/12 factor comes in. The equation is Ig = 1/12 x mass x length^2. In this case, the mass of the seesaw is 12 kg and the length is 10m, so Ig = 100 kgm^2.
Now, we can add all three moments of inertia together to get the total rotational inertia of the system:
Inet = Ia + Ig + Ib = 500 kgm^2 + 100 kgm^2 + 400 kgm^2 = 1000 kgm^2
However, this is the rotational inertia of the system about the center of mass, which in this case is the seesaw pivot. To find the rotational inertia about the seesaw pivot, we need to use the parallel axis theorem again, but this time we will use the distance from the center of mass to the pivot (which is half the length of
Related to Rotational Inertia Seesaw Picot
1. What is rotational inertia and how does it relate to a seesaw?
Rotational inertia, also known as moment of inertia, is a measure of how difficult it is to change an object's rotational motion. In the case of a seesaw, rotational inertia is important because it affects the balance and stability of the seesaw. The greater the rotational inertia of the seesaw, the more force is needed to move it.
2. How is rotational inertia calculated for a seesaw?
The rotational inertia of a seesaw is calculated by multiplying the mass of the seesaw by the square of its distance from the center of rotation. This distance is known as the moment arm. The longer the seesaw, the greater the moment arm and therefore, the higher the rotational inertia.
3. How does the distribution of mass affect the rotational inertia of a seesaw?
The distribution of mass on a seesaw can greatly affect its rotational inertia. When the mass is evenly distributed on both sides of the seesaw, the rotational inertia is balanced and the seesaw is easier to move. However, if the mass is unevenly distributed, the seesaw will have a higher rotational inertia on one side, making it more difficult to move.
4. Can the rotational inertia of a seesaw be changed?
Yes, the rotational inertia of a seesaw can be changed by altering its mass or the distance of the mass from the center of rotation. For example, adding more weight to one side of the seesaw will increase its rotational inertia on that side, making it more difficult to move.
5. How does a seesaw's rotational inertia affect the safety of children playing on it?
A seesaw with a higher rotational inertia can be more difficult to move and may require more force to lift or lower one side. This can pose a safety risk for children, as they may not have enough strength to move the seesaw safely. It is important to ensure that the seesaw's rotational inertia is appropriate for the age and size of the children using it.
16K
9K
