Rotational kinematic equations help
In summary, a wheel with a diameter of 60.0 cm accelerates uniformly from 245 rpm to 395 rpm in 7.5 seconds. The question asks for the distance traveled by a point on the edge of the wheel in this time. The equation used to calculate this is s = (1/2) * (w1 + w2) * t, where s represents distance, w1 and w2 represent the initial and final angular velocities, and t represents time. Using this equation, the distance can be calculated to be 125.66 cm. Referencing a previous forum thread, the rotational kinematic equations can be used to solve this problem. It is important to show the relevant equations and algebraic steps
bosox3790
A wheel 60.0 cm in diameter accelerates uniformly from 245 rpm to 395 rpm in 7.5 s. How far will a point on the edge of the wheel have traveled in this time?
I keep getting 125.66, I don't really understand what forumal to use.
Show what you did to arrive at your answer.
Check out this thread from the last couple of days where the rotational kinematic equations were used by another student. Model your work after that poster's work. Show all the relevant equations, and then show your algebra and how you get to the answer.
https://www.physicsforums.com/showthread.php?t=148047
FAQ: Rotational kinematic equations help
What are rotational kinematic equations?
Rotational kinematic equations are a set of mathematical equations that describe the motion of objects that are rotating around a fixed axis. They are similar to linear kinematic equations, but they are specifically used for rotational motion.
How do rotational kinematic equations help in understanding motion?
Rotational kinematic equations help in understanding motion by providing a mathematical framework to analyze and predict the motion of rotating objects. They allow scientists to calculate quantities such as angular velocity, angular acceleration, and rotational displacement.
What are the basic rotational kinematic equations?
The basic rotational kinematic equations are:
- ω = ω0 + αt
- θ = θ0 + ω0t + 1/2αt2
- ω2 = ω02 + 2α(θ - θ0)
- θ = θ0 + (ω + ω0)t/2
How are rotational kinematic equations derived?
Rotational kinematic equations are derived from the basic principles of rotational motion, which include angular displacement, angular velocity, and angular acceleration. They are also derived from the relationships between linear and rotational quantities, such as the relationship between linear velocity and angular velocity.
Can rotational kinematic equations be applied to all types of rotating objects?
Yes, rotational kinematic equations can be applied to all types of rotating objects, as long as they rotate around a fixed axis. This includes objects such as spinning tops, wheels, and planets. However, they may not be applicable to objects that do not rotate around a fixed axis, such as objects in free fall or in orbit.
