Rotational Kinematics/Momentum Problem
  • Thread starter jjd101
  • Tags
    Rotational
In summary, flywheels are large wheels used to store energy and can be spun up slowly to release high amounts of power. A large flywheel with a 2.4 m diameter and a mass of 300 kg has a maximum angular velocity of 1500 rpm. To reach this speed, it takes 484.9 seconds with a constant torque of 70 Nm. The energy stored in the flywheel is 2.7*10^6 Joules. When connected to a machine, it delivers an average power of 540,000 Watts and exerts a torque of 3437.3 Nm. The amplitude and period of
jjd101
95
Flywheels are large massive wheels (disks) used to store energy. They can be spun up slowly, and then the wheel’s energy can be released quickly to accomplish a task that demands high power. A large flywheel has a 2.4 m diameter and a mass of 300 kg. Its maximum angular velocity is 1500 rpm.
a. The flywheel is spun up at a constant torque of 70 Nm. How long does it take the flywheel to reach top speed?
b. How much energy is stored in the flywheel?
c. After reaching top speed, the flywheel is connected to a machine to which it will deliver energy. Half of the energy stored in the flywheel is delivered in 2.5 sec. What is the average power delivered to the machine?
d. How much torque does the flywheel exert on the machine?
I=1/2MR^2
I calculated the moment for Inertia for this disk and got 216 but i am not sure what to do from here
It's a good idea to check your textbook for the section or chapter that covers this topic. You will find many relevant formulas, and you can think about how they might apply to this problem.
Check over all formulas that involve torque, and think about how one of them might apply here.
Check for any formulas that relate energy and rotating objects.
a. What is the amplitude of the subsequent oscillation?
b. What is the period of the subsequent oscillation?
I=1/2MR^2
That's a start. As I said, check over your book discussion and look for formulas that involve whatever each question is asking for.
Notice your title uses rotational kinematics and momentum. Look up those formulas. yes you need moment of inertia but that's not enough.
Krot = 1/2Iw^2 and T = mr^2(angular Acceleration) ?
i solved for angular acceleration and got .162
this doesn't seem right to me because i solved for time it takes to reach 1500 rpm(157.1 rad/sec) and got 970s
You have your torque is mrsquared alpha. Remember this is a disk, not a ring.
torque = I alpha so you need to use the correct moment of inertia.
Once you get angular acceleration you can use angular kinematics equations and rotational energy equations to calculate the other variables you need.
i did this and solved for alpha with the correct moment of inertia and alpha was .324 giving 484.9s as time to reach 1500 rpms. for Krot=1/2Iw^2 do i use w as the 1500 rpm in rad/sec?
wait - alpha is in rad/secsquared yes omega is in rad/sec
so Krot= 1/2I(omega)^2 Krot= (1/2)(216)(157.1)^2 Krot= 2665484.3? huh?
Flywheels store a lot of energy. If your calculation is right, your answer could be huge. You have waaay too many significant digits though. Your given info has only two so round it and put it in exponential notation.
2.7*10^6 and with this i got the answer to c as 540,000 Watts. how do i solve for d?
work is torque theta and since power is time rate of change of work, what will it be equal to in terms of torque?
T= (P*(delta t))/Theta?
time rate of change of work means Work divided by time. so what happens to the other side of the equation if you divide one side by time?
wouldnt you multiply by T since W/T= P to get W=PT I am confused as to what youre saying
You start with the fact that work is difined as torque times the angle for rotational motion.
But you don't have the angle the machine rotates through so you can't calculate the torque from this. BUT you know that power is defined as work divided by time so take what work is equal to in terms of torque and divide it by time because you also have power.
So W = T(theta)/Time? What is theta in this problem?
ahh you don't know theta but what variable is theta/time?
theta/time is omega? so W=Tomega W/omega=T T=540000/157.1 = 3437.3 Nm?
not work but POWER = Torque omega and you have power and I thought you had omega also after the energy was transferred.
sorry i meant power, 540000 is the value for power, isn't omega 1500 rpm converted to rad/sec which is 157.1rad/sec?
It seems like it has to be. This part bothers me a bit and I'm brain dead. What bothers me is we don't know anything about the machine and omega isn't necessarily the same for the machine and the fly wheel. The linear velocity is the same where they are attached to a belt but not necessarily the angular velocity. If you have the answers try it. I'll check it out again tomorrow and see if I can use linear values to double check or perhaps someone less brain dead will chime in.
ok thank you
Related to Rotational Kinematics/Momentum Problem
1. What is rotational kinematics?
Rotational kinematics is the study of the motion of objects that are rotating or moving along a circular path. It involves concepts such as angular velocity, angular acceleration, and rotational displacement.
2. How do you calculate angular velocity?
Angular velocity is calculated by dividing the change in angular displacement by the change in time. It is measured in radians per second (rad/s).
3. What is the difference between linear and angular momentum?
Linear momentum refers to the product of an object's mass and its linear velocity, while angular momentum refers to the product of an object's moment of inertia and its angular velocity. Linear momentum deals with the motion of an object in a straight line, while angular momentum deals with the motion of an object in a circular path.
4. How does a change in moment of inertia affect rotational motion?
A change in moment of inertia, which is a measure of an object's resistance to rotational motion, affects rotational motion in the same way that a change in mass affects linear motion. An increase in moment of inertia will result in a decrease in angular acceleration and vice versa.
5. Can rotational motion be described by Newton's laws of motion?
Yes, rotational motion can be described by Newton's laws of motion, specifically the second law which states that the net torque on an object is equal to the product of its moment of inertia and its angular acceleration. The third law, which states that every action has an equal and opposite reaction, also applies to rotational motion.
15K
19K
