Rotational Kinematics -- questions about a=mg sin(theta) / (m+I/R^2)
MP97
Hi, I am learning. Rotational Kinematics and I was given this formula in class: a=mgsin(theta)/(m+I/R^2); however, I couldn't understand the professor's explanation of where it comes from. Could someone provide some insights about it?
I appreciate any help you can provide.
Do you at least have an idea of what physical situation it is supposed to describe? Is the formula you posted all there is in your notes? It looks like you have a mass sliding down a frictionless incline of angle ##\theta##. A massless string is tied to the mass and wrapped around a pulley of radius ##R## and moment of inertia ##I##. The expression you posted describes the linear acceleration of the mass down the incline.
It comes from the application of Newton's second law for linear motion and for rotations. If you want to see its derivation, I am sure you can find it on the web now that you know what it (probably) is.
Correct it describes an object rolling down an inclined plane without slipping. Thank you!
That's not what I said, but it describes that too. You are welcome.
For some insights, you could try this:
FAQ: Rotational Kinematics -- questions about a=mg sin(theta) / (m+I/R^2)
What is rotational kinematics?
Rotational kinematics is the branch of mechanics that deals with the motion of objects that rotate about an axis. It describes the relationships between angular displacement, angular velocity, angular acceleration, and time, analogous to linear kinematics for translational motion.
What does the equation a = mg sin(theta) / (m + I/R^2) represent?
This equation represents the linear acceleration (a) of a rolling object down an inclined plane. The term mg sin(theta) is the component of gravitational force acting parallel to the incline, m is the mass of the object, I is the moment of inertia, and R is the radius of the object. The denominator m + I/R^2 accounts for both the translational and rotational inertia of the object.
How is the moment of inertia (I) related to rotational motion?
The moment of inertia (I) is a measure of an object's resistance to changes in its rotational motion. It depends on the mass distribution of the object relative to the axis of rotation. For example, a solid cylinder and a hollow cylinder of the same mass and radius will have different moments of inertia.
Why is the term I/R^2 included in the equation?
The term I/R^2 is included in the equation to account for the rotational inertia of the object. When an object rolls without slipping, its rotational motion is coupled with its translational motion. The term I/R^2 effectively converts the rotational inertia into an equivalent mass that contributes to the total resistance to acceleration.
How do you derive the equation a = mg sin(theta) / (m + I/R^2)?
The equation is derived by applying Newton's second law for both translational and rotational motion. For translational motion, the net force down the incline is mg sin(theta) - friction. For rotational motion, the torque due to friction causes angular acceleration. By combining these equations and eliminating the friction term, we arrive at the expression a = mg sin(theta) / (m + I/R^2), which simplifies the analysis of the rolling motion.
