Rotational Kinetic Energy of Planet
In summary, the rotational kinetic energy of a planet about its spin axis decreases steadily because of tidal friction. The rotational period increases by 15μs each year, so at the end of 1 year the period will be 24h(3600s/h)+15x10^-6s. The rotational kinetic energy of the planet at the end of the year is 2.4369x10^29J, which is way off from the correct answer of -8.39x10^23J/day. Make sure your units are consistent between problems.
rrfergus
This question has two parts; the first part I understand but the second part I do not.
Part 1: What is the rotational energy of a planet about its spin axis? Model the planet as a uniform sphere of radius 6420 km, and mass 5.59x10^24 kg. Assume it has a rotational period of 24.0 h. The answer to this is 2.44x10^29J. I understand this part.
Part 2: Suppose the rotational kinetic energy of the planet is decreasing steadily because of tidal friction. Assuming the rotational period increases 15.0 μs each year, find the change in one day. (Let 1 yr = 365 d.). The answer to this is -2.32x10^17 J/day, but I do not understand how to get it. Thank you! :)
KE = 1/2Iω^2
I = 2/5MR^2
ω = 2π/T (T is period)
If T increases by 15μs each year, then at the end of 1 year the period will be 24h(3600s/h) + 15x10^-6s. So, I use that to find the rotational kinetic energy of the planet at the end of the year and I get 2.4369x10^29J. Then, I subtract the original rotational kinetic energy (the answer from part 1) and divide the result by 365 (since there are 365 days/year). The result is about -8.39x10^23J/day, which is way off from the correct answer.
Make sure your units are consistent between problems. I recommend converting everything into units of days when determining the kinetic energy. Simply diving by 365 in the very end may not give you what you're looking for, try calculating [itex]\Delta E = \frac{1}{2}I(\omega_2^2-\omega_1^2)[/itex] after your units of [itex]\omega[/itex] are consistent. It's likely the error was made with unit conversion.
Once all your units are for a single day, you won't need to divide by anything in the end. Your answer will be the change in energy from one day to the next, so it would be equivalent to Joules/Day
Great! I got the right answer! Thank you so much!
Related to Rotational Kinetic Energy of Planet
1. What is rotational kinetic energy of a planet?
The rotational kinetic energy of a planet is the energy associated with its rotation around its own axis. It is a type of mechanical energy that results from the planet's mass and its angular velocity.
2. How is rotational kinetic energy of a planet calculated?
The rotational kinetic energy of a planet can be calculated using the formula KE = 1/2 * I * ω^2, where KE is the rotational kinetic energy, I is the moment of inertia, and ω is the angular velocity.
3. What factors affect the rotational kinetic energy of a planet?
The rotational kinetic energy of a planet is affected by its mass, moment of inertia, and angular velocity. A planet with a larger mass or faster rotation will have a higher rotational kinetic energy.
4. How does rotational kinetic energy contribute to a planet's overall energy?
Rotational kinetic energy is one of the forms of energy that make up a planet's total energy. It is a significant component of a planet's overall energy, along with other forms such as gravitational potential energy and thermal energy.
5. Can the rotational kinetic energy of a planet change?
Yes, the rotational kinetic energy of a planet can change due to factors such as changes in its mass, moment of inertia, or angular velocity. For example, a planet's rotational kinetic energy may increase if its mass increases or its rotation speeds up.
