Rotational motion inclined plane
In summary: I*You need to apply Newton's 2nd law to both rotation and translation. You'll end up with two equations, which you'll combine.Friction causes the ball to translate down the incline. In summary, a ball rolling down an incline plane will have translational and rotational motion due to the force of friction.
pff
Hi guys,
I need to model a ball rolling on an incline plane, and i would like to be able to calculate acceleration due to gravity for a given angle.
Currently i have:
a = f / m
f = m*g*sin(angle)
a = g*sin(angle)
I am aware this does not take rotational motion into account, which is what I'm trying to do now
Its been a while since i took a physics class, If someone could help me out it would be much appreciated
When you have the ball rolling without slipping on an incline, you'll need to include the force of friction. By applying Newton's laws to translation and rotation, and the constraint for rolling without slipping (v = ωr), you'll be able to figure out the acceleration as a function of angle.
ok, i came up with the following
a = [tex]\alpha[/tex]r
[tex]\alpha[/tex] = [tex]\tau[/tex]/I
solid sphere I = (2/5)mr[tex]^{2}[/tex]
[tex]\tau[/tex]=rF
[tex]\alpha[/tex] = rF/(2/5)mr[tex]^{2}[/tex]
a = Fr/(2/5)mr
= g*sin(angle) / (2/5)
Is this sensible? i would have expected an r term.
Almost, but not quite.
Translational motion due to the ball slipping?
Now my head is starting to hurt.
I would need to have a value for friction, then split the force between rotational acceleration and acceleration down the plane?
I don't have any specific value for friction coefficient.
If there is sufficient friction could I just ignore the translational component?
No, translational motion due to the ball rolling down the incline. (It translates as well as rotates.
You don't need to know the value of the friction, just call it F. (No, you can't ignore translational motion!)
What forces act on the ball? Draw a free body diagram.
well i already have translational acceleration
a = g*sin(angle)
...can i just add them together?
a = a(rot) + a(tran) = g*sin(angle) / (2/5) + g*sin(angle)
a = g*sin(angle)
That's the translational acceleration if the ball slid down the incline without rolling. (What would happen with no friction, for example.) When the ball rolls, things change.
No. Do what I said earlier. Apply Newton's 2nd law twice.
I guess i have to account for friction then?
a = m*g*sin(angle) - F / m
Your saying apply Newtons laws twice? i suppose this is to get a net force?
F(tran) = m*g*sin(angle) - F(friction)
F(rot) = ma = m*g*sin(angle)/(2/5)
F = m*g*sin(angle) - F(friction) + m*g*sin(angle)/(2/5)
Is that what you had in mind? along the right track?
I doubt it because using F=ma the m cancels and its equivalent to summing acceleration. I hope you just made me do properly, because I'm stuck otherwise, I need more of a hint please.
Of course.
No, not to get a net force. Once for rotation (where net torque is used instead of net force) and once for translation.
OK, that's the net force. Set it equal to ma:
m*g*sin(angle) - F(friction) = ma
Hint: Newton's 2nd law for rotation is Torque = I*alpha. (You used it earlier.)
What torque does friction exert on the ball? How does alpha relate to a?
Sorry, a = g*sin(angle) - F / m
I thought torque from friction was equivalent to the force pulling the ball down the slope in order to make it rotate
torque = m*g*sin()*r
alpha = a/r, but i don't understand where that gets me, back to a = g*sin(angle) / (2/5) ?
OK, but you're getting ahead of yourself. So far, we have one equation, for translation. (See last post.)
Not sure what you're doing here. Torque due to friction is just F*r. So write Newton's 2nd law for rotation. That will give you your second equation.
sorry, so i have
and
t = rF = r*m*g*sin(angle)
pff said:
sorry, so i have
I was using "F" to represent friction; Instead, for clarity, let's call Friction Ff.
The net force is:
ΣF = m*g*sin(angle) - Ff
Apply Newton's 2nd law:
m*g*sin(angle) - Ff = ma
[this is equation #1]
and
The torque producing force is the friction; it's torque is r*Ff. (Nothing to do with gravity.)
Torque = I*alpha
Flesh that last equation out; it will be equation #2.
ok, but if i have
t = I[tex]\alpha[/tex]
so
I = (2/5)*m*r^2
but angular acceleration is due to the angular component of gravity, although the friction causes the rolling, the amount is due to g isn't it?
unless i use a = [tex]\alpha[/tex]r
[tex]\tau[/tex] = I*a/r
is that better?
pff said:
ok, but if i have
so
I = (2/5)*m*r^2
You're thinking way too much. The torque is due to the friction, which depends on the angle. But let the equations do the work for you.
is that better?
Yes. So far, so good. Replace tau and I with what they equal.
t = I*a/r
= (2/5)*m*r^2*a / r
t = Ff*r
Ff*r = (2/5)*m*a*r
F = (2/5)*m*a
the force? that's what we want first right?
pff said:
t = I*a/r
= (2/5)*m*r^2*a / r
t = Ff*r
Ff*r = (2/5)*m*a*r
F = (2/5)*m*a
Yes! (Make sure that F is really Ff, the friction force.)
This is equation #2. Combine it with equation #1, and then solve for the acceleration. (You can also solve for the friction force, if you want.)
Ff = (2/5)*m*a
ma = m*g*sin(t) - Ff
ma = m*g*sin(t) - (2/5)*m*a
a = g*sin(t) - (2/5)*a
a + (2/5)*a = g*sin(t)
(7/5)*a = g*sin(t)
a = g*sin(t) / (7/5)
please?
pff said:
Ff = (2/5)*m*a
(7/5)*a = g*sin(t)
please?
Yes! You made it!
But write it as
a = (5/7)*g*sin(t)
woohoo!
Thanks for your time and patience, its very much appreciated.
You're welcome.
Notice that the acceleration is less than something sliding with no friction. This should make sense, since some of the gravitational PE is being converted to rotational KE, leaving less translational KE.
But no energy is lost to friction, since there's no slipping. Mechanical energy will be conserved.
FAQ: Rotational motion inclined plane
1. What is rotational motion on an inclined plane?
Rotational motion on an inclined plane refers to the movement of an object as it rolls or slides down a slope. This type of motion involves both translation (movement in a straight line) and rotation (movement around an axis).
2. How does the angle of the inclined plane affect rotational motion?
The angle of the inclined plane affects the velocity and acceleration of the object in rotational motion. A steeper angle will result in a faster velocity and greater acceleration, while a smaller angle will result in a slower velocity and lower acceleration.
3. What is the relationship between rotational motion and friction on an inclined plane?
Friction plays a significant role in rotational motion on an inclined plane. It can either help or hinder the motion, depending on the direction of the force. Friction in the direction of the object's motion will slow it down, while friction in the opposite direction will speed it up.
4. How is torque involved in rotational motion on an inclined plane?
Torque, or the turning force, is essential in rotational motion on an inclined plane. It is responsible for causing the object to rotate and can be calculated by multiplying the force applied to the object by the distance from the axis of rotation.
5. What factors affect the stability of an object in rotational motion on an inclined plane?
The stability of an object in rotational motion on an inclined plane is affected by its mass, shape, and the placement of its center of mass. A larger mass, a wider base, and a lower center of mass will result in a more stable object.
