Rotational motion of a solid sphere of mass
In summary, a solid sphere of mass m is released from rest from the rim of a hemispherical cup and rolls along the surface. When the ball reaches the bottom of the cup, the normal force exerted by the cup on the ball is equal and opposite to the weight of the ball, acting upwards and of magnitude m*g. The rim of the cup is kept horizontal, so the tangent plane to the bottom of the cup is also horizontal.
kaka01
A solid sphere of mass m is released from rest from the rim of a hemispherical cup so that it rolls along the surface. If the rim of the hemisphere is kept horizontal, find the normal force exerted by the cup on the ball when the ball reaches the bottom of the cup.
This sounds suspiciously like a homework question... anyway, the bottom of the cup is horizontal so the normal force must be equal and opposite to the weight of the ball, ie. acting upwards and of magnitude m*g.
Yep. It belongs in the Intro Physics forum.
No, the rim of the cup is kept horizontal.
Okay, so the tangent plane to the bottom of the cup is horizontal?
As the solid sphere rolls along the surface of the hemispherical cup, it experiences both translational and rotational motion. The translational motion is caused by the force of gravity pulling the sphere towards the bottom of the cup, while the rotational motion is caused by the torque exerted on the sphere by the cup.
At the point of release, the sphere is at rest and the only force acting on it is the force of gravity. As it rolls down the cup, the force of gravity remains constant, but the normal force exerted by the cup increases in order to balance the torque exerted by the cup on the sphere.
When the sphere reaches the bottom of the cup, the normal force exerted by the cup on the sphere will be equal to the force of gravity acting on the sphere. This is because the sphere has reached its maximum speed and is no longer accelerating, meaning that the net force on the sphere is zero.
In order to determine the normal force at the bottom of the cup, we can use the equation for torque: τ = Iα, where τ is the torque, I is the moment of inertia, and α is the angular acceleration. Since the sphere is rolling without slipping, we know that the angular acceleration is equal to the linear acceleration divided by the radius of the sphere, or α = a/r.
Substituting this into the torque equation, we get τ = I(a/r). We can also use the equation for rotational kinetic energy: K = 1/2Iω^2, where K is the kinetic energy, I is the moment of inertia, and ω is the angular velocity. Since the sphere is rolling without slipping, we know that the linear velocity is equal to the angular velocity multiplied by the radius of the sphere, or v = ωr.
Substituting this into the kinetic energy equation, we get K = 1/2I(v^2/r^2). Since the sphere is released from rest, its initial kinetic energy is zero, and at the bottom of the cup, its kinetic energy is equal to its final kinetic energy, which is equal to 1/2mv^2.
Setting these two equations equal to each other and solving for the normal force, we get:
1/2I(v^2/r^2) = 1/2mv^2
Solving for v^2, we get v^2 = 2gr, where g is the acceleration due to gravity
FAQ: Rotational motion of a solid sphere of mass
1. What is rotational motion of a solid sphere of mass?
Rotational motion of a solid sphere of mass refers to the movement of a solid sphere around an axis of rotation. This type of motion is governed by principles of angular momentum, torque, and rotational inertia.
2. How is rotational motion different from linear motion?
Rotational motion involves movement around an axis, while linear motion involves movement in a straight line. Additionally, rotational motion is characterized by angular velocity, angular acceleration, and moment of inertia, while linear motion is characterized by velocity, acceleration, and mass.
3. What factors affect the rotational motion of a solid sphere?
The rotational motion of a solid sphere is affected by its mass, distribution of mass, and the torque applied to it. The shape and size of the sphere can also impact its rotational motion.
4. How is the rotational motion of a solid sphere measured?
The rotational motion of a solid sphere can be measured using angular displacement, angular velocity, and angular acceleration. These measurements can be obtained using various instruments such as a protractor, tachometer, and accelerometer.
5. What are some real-life examples of rotational motion of a solid sphere?
Some real-life examples of rotational motion of a solid sphere include the spinning of a basketball on a player's finger, the rotation of a rolling tire, and the motion of a spinning top. Other examples include the rotation of planets and other celestial bodies in space.
