Rotational Motion Problem - 14
In summary, Rotational Motion Problem - 14 involves a solid cylinder rolling down an inclined plane with a rotational speed and a linear speed being given. The solution requires calculating the angular acceleration and the distance traveled by the cylinder before it stops. The solution involves using the equations of rotational motion and the relationship between angular and linear velocity. The final answer is dependent on the initial conditions and the properties of the cylinder.
coldblood
133
Hi friends,
Please help me in solving this problem, I'll appreciate the help.
The problem is as:
https://fbcdn-sphotos-a-a.akamaihd.net/hphotos-ak-frc3/q71/s720x720/1470127_1461728164054289_845411707_n.jpg
Attempt -
https://fbcdn-sphotos-e-a.akamaihd.net/hphotos-ak-frc3/q71/s720x720/1468786_1461728244054281_988835356_n.jpg
Thank you all in advance.
hi coldblood! :smile:
you're only considering the torque of F (about the centre) … what about the torque of the friction? :confused:
hint: the clue is in the diagram
what do you think that dotted line is there for (the extension of F)? :wink:
what would happen if the angle was larger, and that dotted line went exactly through the bottom of the spool?
thread unwinds, spool rotates counter-clock and friction would act right wards. Is that correct?
(just got up :zzz:)
(ie if the force goes exactly through the point of contact with the horizontal surface)
nooo (and what was your reason?) :redface:
hint: where is the centre of rotation?
what is the total torque about the centre of rotation? :wink:
tiny-tim said:
](ie if the force goes exactly through the point of contact with the horizontal surface)
If the external force acts at the bottom point horizontally,
It'll provide spool an anti clockwise torque, friction will act leftwards. And I think thread should unwind.
Because I found some equations: if the force acts at the top point horizontally in + x direction, It generates a torque in clockwise manner and direction of friction is rightwards.
no, you're not understanding what I'm saying …
i'm saying, if the angle α is increased so that the pulling force F is further round, and steeper, and so the line of action of F (as well as f) goes through that bottom point
Then the spool will be rotating clockwise, friction will act right right and thread unwinds.
how many forces are there on the spool?
what is the torque of each of them about the bottom point?
so what is the total torque?
About bottom point only the torque of F will act because weight, frictional force and the reaction from the ground will pass through that point only.
exactly! :smile:
so if the line of action of F passes
(a) to the left of
(b) to the right of
(c) directly through​
the bottom point, which way will the spool turn? :wink:
tiny-tim said:
exactly! :smile:
(a) to the left of
(b) to the right of
Can you please make a figure for the three? Please
(a) is the diagram in the top-left corner of your printed question
for (b) and (c), if you move the string further round, α will increase, and the dotted line will slide over to the right
(eg if α = 90°, it's obviously to the right!)
https://fbcdn-sphotos-f-a.akamaihd.net/hphotos-ak-prn2/1476572_1462877957272643_1028005643_n.jpg
https://fbcdn-sphotos-g-a.akamaihd.net/hphotos-ak-prn1/q71/s720x720/936643_1462877960605976_1351577648_n.jpg
your first equation, α = F(b - a)/IP is correct only if the angle of F is 0
you have drawn F in the wrong place, F does not come out of the bottom of that small circle, it has to be tangential, so it comes from a point at the same angle from the vertical as F is from the horizontal :wink:
and you do not really need to calculate it exactly, or to use k
it's enough to say "the only torque about P is from F, which is clearly clockwise, and so the spool rotates clockwise" :smile:
similarly, the only torques about C are F (anticlockwise) and f … since we know the spool rotates clockwise, that means that the torques of f must be … ? :smile:
now do the other two cases, (b) and (c) (with a corrected diagram)​
Related to Rotational Motion Problem - 14
1. What is rotational motion?
Rotational motion refers to the movement of an object around an axis or center point. This type of motion is circular and can be seen in objects such as wheels, planets, and spinning tops.
2. How is rotational motion different from linear motion?
Rotational motion involves movement around an axis, while linear motion involves movement in a straight line. Additionally, rotational motion is described by rotational variables such as angular displacement, velocity, and acceleration, while linear motion is described by linear variables such as displacement, velocity, and acceleration.
3. What is torque and how does it relate to rotational motion?
Torque is the measure of the force that causes an object to rotate around an axis. It is calculated by multiplying the force applied to an object by the distance from the axis of rotation. In rotational motion, torque is what causes an object to change its rotational motion.
4. What is angular momentum and how is it conserved in rotational motion?
Angular momentum is a measure of an object's rotational motion and is calculated by multiplying the object's moment of inertia by its angular velocity. In rotational motion, angular momentum is conserved, meaning it remains constant unless an external torque is applied.
5. How do you solve problems involving rotational motion?
To solve problems involving rotational motion, you need to use the principles of rotational kinematics and dynamics, as well as any relevant equations. It is important to clearly define the variables and units involved, and to carefully consider the direction of rotation and any external forces acting on the object.
