Rotational motion: rod in a tube
In summary, the conversation discusses finding the equations of motion for a thin rod inside a pivoted tube in a horizontal plane. The mass and length of the rod are given, and the question asks for the equations in terms of the angle of the tube and the radial position of the rod's center. A diagram is requested to clarify the system.
SonOfOle
42
A long thin tube of negligible mass is pivoted so it may rotate freely without friction in a horizontal plane. A thin rod of mass M and length L lies in the tube and can slide without friction in the tube. ([tex]I_{Thin Rod}=\frac{1}{12}ML^{2}[/tex]).
Find the equations of motion for the thin rod in terms of the angle of the tube, [tex]\theta[/tex], and the radial position of the center of the rod, r.
Could you perhaps draw a diagram of what you're asking? I'm a little confused by your description, because you could be describing a number of different systems.
The diagram is attached. Thanks for any help. I'm currently stumped.
  • Untitled.pdf
FAQ: Rotational motion: rod in a tube
1. What is rotational motion?
Rotational motion is the movement of an object around its own axis. In other words, it is when an object rotates or spins.
2. How does a rod in a tube exhibit rotational motion?
A rod in a tube exhibits rotational motion when it is able to rotate around its own axis, while being constrained by the tube. This can happen when a force is applied to one end of the rod, causing it to rotate inside the tube.
3. What factors affect the rotational motion of a rod in a tube?
The rotational motion of a rod in a tube can be affected by various factors such as the length and mass of the rod, the diameter and material of the tube, and the force applied to the rod.
4. How is rotational motion different from linear motion?
Rotational motion involves circular movement around an axis, while linear motion involves movement in a straight line. Additionally, rotational motion involves the concept of torque, while linear motion involves the concept of force.
5. What are some real-life applications of rotational motion of a rod in a tube?
The rotational motion of a rod in a tube can be seen in various everyday objects, such as a bicycle wheel, a merry-go-round, or a drill bit. It is also utilized in machines and devices such as turbines, engines, and motors.
