Rosengrip
- 20
Two spherical bodies with equal mass m1=m2=1000 kg are orbiting around a common barycenter in a weightless environment because of the gravitational attraction.
A: Show how the frequency of orbiting is related to the distance between two bodies.
B: We connect two bodies with a massless rod. There is a spring connected to the center of this rod (axis around which the bodies rotate) with a weight on one end. Mass of weight is 1 kg. What is the spring coefficient, if the weight doesn't move during rotation? Assume the frequency of rotation is one revolution per day.
C: Assume the weight attached to a spring is oscillating during rotations with small amplitudes. What is the spring coefficient, if the weight oscillates 12 times during 1 revolution?
Sketch for better understanding:
[URL]http://www.shrani.si/f/26/TO/4cz4TVm7/skica1.png[/URL]
F = (Gm1m2)/r2
F = ks
Equations for oscillating motion
A: Force of gravity is a centripetal force.
for body1: m1w2r = (Gm1m2)/R2 (r = distance for body1 to barycenter, R = distance between to bodies, w = angular velocity of body1)
Out of this equation I get the frequency of rotation for body1:
f = SQRT[ (Gm2) / (4R2rPi2) ]
It's the same for the other body.
B: Force of spring is a centripetal force
mw2s = ks (s = distance of weight from barycenter and the length of spring, m = mass of weight)
k = mw2
Here I didn't include both attractive forces from two bodies, which complicate things a bit. What I got here is way too simple so I'm pretty sure I'm missing something.
C: don't really have an idea how to do this, any tips would be cool :)
I'm pretty sure my soulution of A is right, not sure about B though. So I need someone to review this. Thanks.
