Rotman - Theorem 2.64 - Irreducibility
  • MHB
  • Thread starter Math Amateur
  • Tags
    Theorem
In summary, Rotman's Theorem 2.64 states that a polynomial in the ring of integers can only be factored into two non-unit polynomials of lesser degree, with each factor being at least degree 1. This is due to the fact that we do not consider factorizations involving units, and the monic nature of the polynomial ensures that the leading coefficients of the factors are not 0. This theorem is an important tool in determining the irreducibility of polynomials, particularly in the case of Eisenstein's criterion.
Math Amateur
MHB
3,998
48
I am reading Chapter 2: Commutative Rings in Joseph Rotman's book, Advanced Modern Algebra (Second Edition).
I am currently focussed on Theorem 2.64 [pages 115 - 116] concerning irreducibility.
I need help to the proof of this theorem.
Theorem 2.64 and its proof read as follows:https://www.physicsforums.com/attachments/2695
https://www.physicsforums.com/attachments/2696In the above text: Rotman writes:
" ... ... Suppose that \(\displaystyle f(x) \) factors in \(\displaystyle \mathbb{Z} [x] \); say \(\displaystyle f(x) = g(x)h(x) \), where \(\displaystyle deg(g) \lt deg(f) \) and \(\displaystyle deg(h) \lt deg(f) \). Now \(\displaystyle \overline{f}(x) = \overline{g}(x) \overline{h}(x) \) so that \(\displaystyle deg( \overline{f}) = deg( \overline{g}) + deg( \overline{h}). \) Now, \(\displaystyle \overline{f}(x) \) is monic because f(x) is and so \(\displaystyle deg( \overline{f}) = deg(f) \). Thus both \(\displaystyle deg( \overline{g}) \text{ and } deg( \overline{h}) \) have degrees less than \(\displaystyle deg( \overline{f}) \) ... ..."
My question is as follows:
How does (on what grounds) does Rotman reach the conclusion that both \(\displaystyle deg( \overline{g}) \text{ and } deg( \overline{h}) \) have degrees less than \(\displaystyle deg( \overline{f}) \)?
Indeed, what is preventing one of \(\displaystyle deg( \overline{g}) , deg( \overline{h}) \) from being equal to 1 and hence having degree zero and the other having degree n? (Having one of them having degree 0 and being equal to a unit other than 1 would, of course, contradict the monic nature of f, but one of them being equal to 1 seems an open possibility)
Hope someone can help clarify the above issue.
Peter
A polynomial $f(x) \in F[x]$, for any field $F$ is said to be REDUCIBLE if:
$f(x) = g(x)h(x)$
where neither $g$ nor $h$ is a unit in $F[x]$ (a unit in $F[x]$ is, of course, a unit of $F$, that is to say: a non-zero constant polynomial).
If $f \neq 0$, then since $F[x]$ is an integral domain, if $f$ is reducible, neither $g$ nor $h$ can be 0, either.
Furthermore, if $f$ is monic, then without loss of generality we can find $g$ and $h$ monic as well, for if the leading coefficient of $g$ is $a$, then the leading coefficient of $h$ must be $1/a$, in which case we have:
$f(x) = [(1/a)g(x)][ah(x)]$ and both these factors are monic.
Now $\text{deg}(g),\text{deg}(h) > 0$, since these are non-zero non-units. This precludes the possibility that either one is the constant polynomial $1$.
In $\Bbb Z[x]$, the situation is considerably simpler: if such an $f$ factors into two non-unit polynomials OF LESSER DEGREE, then each factor must be AT LEAST degree 1. In other words: polynomials of degree one is "as low as we go"...the reason being, is that irreducibility is defined "only up to units".
We don't want factorizations like $f(x) = (-1)(-f(x))$ to "count", these are somewhat trivial. Again, this is along the same lines as not considering the integer 1 as "prime" for we can "factor it" all day long:
$1 = (-1)(-1)(-1)(-1)(1)(-1)(1)(-1)$, for example.
In a similar vein, in the ring $Z_5[x]$ we can factor the irreducible polynomial $x + 3$ as:
$x + 3 = (2)(3x + 4)$, but this really shouldn't count. Since $2 = 3^{-1}$ in $\Bbb Z_5$, the above factorization is actually:
$\dfrac{3x + 4}{3} = \dfrac{3x + 3}{3} + \dfrac{1}{3} = x + 1 + 2 = x + 3$.
IN GENERAL, for a commutative ring $R$, and an ideal $I$, if we have:
$f(x) = g(x)h(x)$ in $R[x]$, we certainly have:
$\varphi^{\ast}(f(x)) = \varphi^{\ast}(g(x))\varphi^{\ast}(h(x))$ in $R/I[x]$.
The underlying idea is this:
Often we want to establish a particular monic polynomial $f(x) \in \Bbb Z[x]$ is irreducible over $\Bbb Q$. Now Gauss' lemma tells us that if it factors in $\Bbb Q[x]$ (and, again "factors" means here "factors into two non-units", we want non-trivial factorizations), it factors in $\Bbb Z[x]$.
The ring-homomorphism $\varphi^{\ast}$ preserves the factorization, so if when we reduce mod $p$, we get an irreducible polynomial, we must not have had any possible factorization to begin with. The point to doing this, is that there often fewer cases to check in $\Bbb Z_p[x]$.
For example, take the polynomial:
$p(x) = x^3 - 2x^2 + 7x + 15 \in \Bbb Z[x]$.
The only thing immediately obvious is that any integral root is $\pm 1,3,5,15$. That's 8 possible roots to try. If we take this polynomial mod 2, we get:
$x^3 + x + [1]$, and we have just 2 roots to try:
$\overline{p}([0]) = [1]$
$\overline{p}([1]) = [1]$neither of which work, so we conclude that $p$ is irreducible over $\Bbb Q$.
In general, it's HARD to decide if a given monic integral polynomial is irreducible, especially if the degree is > 3. Even if we conclude it has no integer roots, it may still factor into integral quadratics, or cubic, etc. So irreducibilty criteria are invaluable (time-savers).
Indeed, the theorem you are looking at now is just a prelude to the important Eisenstein's criterion:
If $f(x) = x^n + a_{n-1}x^{n-1} + \cdots + a_1x + a_0 \in \Bbb Z[x]$ is a polynomial such that:
$p|a_j$, for $j = 0,1,\dots,n-1$ but $p^2\not\mid a_0$, for some prime $p$, then $f(x)$ is irreducible over $\Bbb Q$.
To see how this works, suppose that on the contrary for such a polynomial:
$f(x) = g(x)h(x)$. Reducing mod $p$, we get:
$\overline{f}(x) = \overline{g}(x)\overline{h}(x)$.
Since $p$ divides all but the leading coefficient, we have $\overline{f}(x) = x^n$
Since $\Bbb Z_p[x]$ is a unique factorization domain, we must have $\overline{g}(x) = x^k$ for $0 < k < n$, and $\overline{h}(x) = x^{n-k}$.
But this implies the constant term of $g$ is divisible by $p$, and likewise for $h$, so that $p^2|a_0$, contradiction.
$f(x) = g(x)h(x)$
Thanks for the help Deveno ... ... just working through your post in detail now ...
Tanks again,
Peter
Tanks again,
Peter
Thanks again for the help, Deveno ... as I worked through your post and also checked on the Theorem 2.64 again, I became aware that the proof did not seem to explicitly make use of the fact that p is prime ... can you help?
My question is - why, exactly, does p have to be prime ... is it to ensure \(\displaystyle \mathbb{F}_p \) is a field, so that \(\displaystyle \mathbb{F}_p [x] \) is a domain? (Presumably we want \(\displaystyle \mathbb{F}_p [x] \) to be a domain - but why?)
Can you clarify this issue?
Peter
It is a theorem that $\Bbb Z/n\Bbb Z$ is an integral domain if and only if $n$ is not composite (the trivial ring $\{0\}$ is "technically" an integral domain, but a somewhat boring one (this is the $n = 1$ case), and the integers themselves are an integral domain (this is the $n = 0$ case)).
Put another way: $\Bbb Z/n\Bbb Z$ is a non-trivial finite integral domain if and only if $n$ is prime.
To see this, suppose $n = ab$ with $1 < a,b < n$.
Then $[a] = [ab] = [n] = [0]$, so $[a]$ and $$ are zero divisors.
On the other hand if $n = p$, a prime, then $\text{gcd}(a,p) = 1$ for all $0 < a < p$, and thus $[a]$ is a unit, so there are no zero divisors.
Now if $n$ is composite, then $\Bbb Z_n[x]$ surely has zero divisors (for example, at least all the zero divisors of $\Bbb Z_n$, realized as constant polynomials). So $\Bbb Z_n[x]$ isn't even an integral domain, MUCH LESS an unique factorization domain. And if we don't have a UFD, we can't test for irreducibility by testing for primality (primality is easier to test for than irreducibility).
The presence of zero divisors in a ring is generally unhelpful to solving problems. For example, if $a$ is a zero divisor in a ring $R$, we can have $ab = ac$, with $b \neq c$. So even if we know $ab = x$, and we know what $a$ and $x$ are, we don't have a way to find out what $b$ is.
FAQ: Rotman - Theorem 2.64 - Irreducibility
What is the Rotman-Theorem 2.64?
The Rotman-Theorem 2.64, also known as the Irreducibility Theorem, is a fundamental result in the field of algebraic geometry. It states that a projective variety is irreducible if and only if its defining ideal is prime.
What does it mean for a projective variety to be irreducible?
A projective variety is said to be irreducible if it cannot be expressed as the union of two proper closed subsets. In other words, it is a single, connected geometric object that cannot be broken down into smaller pieces.
How is the Irreducibility Theorem used in algebraic geometry?
The Irreducibility Theorem is a powerful tool used to study the geometric properties of projective varieties. It allows us to decompose a variety into its irreducible components, simplifying the problem and making it easier to analyze.
What is the significance of Theorem 2.64 in mathematics?
The Irreducibility Theorem is a fundamental result in algebraic geometry and has numerous applications in various branches of mathematics, including number theory, topology, and algebraic topology. It also has important connections to other areas of mathematics, such as algebraic number theory and algebraic geometry.
Are there any generalizations of Theorem 2.64?
Yes, there are several generalizations of Theorem 2.64, including the Noether normalization theorem and the Lefschetz hyperplane theorem. These generalizations extend the result to a wider class of algebraic varieties and have important applications in algebraic geometry and related fields.
