MHB Round-Trip Speed Word Problem: Sarah's Boat & River Current
Sarah's boat travels at 15 km/h in still water and takes 4.5 hours for a round trip of 30 km upstream and downstream. To find the speed of the river current, the equations for time taken upstream and downstream are set up using the relationship between distance, speed, and time. By solving these equations, it is determined that the speed of the current is 5 km/h. The calculations confirm that the current's speed affects the total travel time, leading to this conclusion.
MarkFL
MHB
Here is the question:
Round-Trip Speed Word Problem help?
I'm having trouble and been stuck for half an hour just trying and erasing and I need some help.
Question: In still water, Sarah's boat can travel 15 km/h. If it takes her a total of 4 1/2 hours to travel 30 km up a river and then to return by the same route, what is the speed of the current in the river?
I have posted a link there to this thread so the OP can view my work.
Mathematics news on Phys.org
Hello Meh,
Let's break this down into the upstream portion of the trip and the downstream portion, using the relation distance equals speed times time. We will let $0<c$ be the speed of the current and $t_1$ be the time going upstream and $t_2$ be the time going downstream.
$$30=(15-c)t_1$$
$$30=(15+c)t_2$$
Now, we also know the total time is 4.5 hours, so we may state:
$$t_1+t_2=4.5\implies t_2=4.5-t_1$$
And so our second equation becomes:
$$30=(15+c)\left(4.5-t_1 \right)$$
Solving the first equation for $t_1$, we find:
$$t_1=\frac{30}{15-c}$$
Now, substituting this into our new second equation, we obtain an equation in one variable $c$, which is what we are trying to find:
$$30=(15+c)\left(4.5-\frac{30}{15-c} \right)$$
Multiplying through by $15-c$, we get:
$$30(15-c)=(15+c)\left(4.5(15-c)-30 \right)$$
Distribute on the right:
$$30(15-c)=(15+c)\left(67.5-4.5c-30 \right)$$
Combine like terms:
$$30(15-c)=(15+c)\left(37.5-4.5c \right)$$
Multiply through by $2$:
$$30(30-2c)=(15+c)\left(75-9c \right)$$
Distribute on both sides:
$$900-60c=1125-60c-9c^2$$
Combine like terms and arrange as:
$$9c^2=225$$
Divide through by $9$:
$$c^2=25$$
Take the positive root:
$$c=5$$
Thus, we conclude that the current in the river is $$5\,\frac{\text{km}}{\text{hr}}$$.
I'll solve this with one variable.
In still water, Sarah's boat can travel 15 km/hr.
I will use: .\text{Time} \;=\;\frac{\text{Distance}}{\text{Speed}}Let x = speed of the current.
Going upstream, her speed is 15-x km/hr.
To travel 30 km, it takes: .\tfrac{30}{15-x} hours.
Going downstream, her speed is 15+x km/hr.
To travel 30 km, it takes: .\tfrac{30}{15+x} hours.
Her total time is 4\!\tfrac{1}{2} hours.
. . \frac{30}{15-x} + \frac{30}{15+x} \:=\:\frac{9}{2}Multiply by 2(15-x)(15+x)\!:
. . \begin{array}{c}60(15+x) + 60(15-x) \:=\:9(15-x)(15+x) \\ \\ 900 + 60x + 900 - 60x \:=\:9(225-x^2) \\ \\ 1800 \:=\:2025 - 9x^2 \\ \\ 9x^2 \:=\:225 \\ \\ x^2 \:=\:25 \\ \\ x \:=\:5 \end{array}The speed of the current is 5 km/hr.​
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
