Row reducing the matrix of a linear operator
In summary: That is, the same row operations that row reduce A to the identity matrix also row reduce the identity matrix to A^{-1}. Now, the reduced row echelon form of a matrix is unique. There is only one reduced row echelon form of a matrix. That means that if A and B are two matrices that reduce to the same reduced row echelon form, A and B are row equivalent. That means that there exist a series of elementary matrices, P1, P2, P3, ..., Pn, so that Pn...P3P2P1A= B. In particular, if A is a matrix that represents a linear transformation, T, and B is the reduced row ech
*FaerieLight*
43
I'm having difficulty understanding the concepts presented in the following question.
I'm given a matrix,
[2,4,1,2,6; 1,2,1,0,1; ,-1,-2,-2,3,6; 1,2,-1,5,12], which is the matrix representation of a linear operator from R5 to R4.
The question asks me to find a basis of the image and the kernel of the map.
Row-reducing the matrix gives
[1,2,0,0,-1; 0,0,1,0,2; 0,0,0,1,3; 0,0,0,0,0,] as the reduced row echelon form. I'm told that the columns 1, 3 and 4 are linearly independent, and hence the corresponding columns of the original matrix form a basis of the image of A. This is what I don't understand. How do I know that these columns are linearly independent? I suppose it has something to do with the fact that these columns are the only ones with a single 1 entry, while all the rest of the entries are 0, above and below. But why should this feature necessarily mean that the columns are linearly independent?
After determining the linearly independent columns, why should the corresponding columns of the original matrix correspond to a basis of the image of A?
Also, how would I find a basis for the kernel from the row-reduced echelon form?
Thanks very much.
I'm given a matrix,
Because that means your vectors are of the form
[tex]v_1= \begin{bmatrix}1 \\ a_1 \\ a_2 \\ ...\end{bmatrix}[/tex]
[tex]v_2= \begin{bmatrix}0 \\ 1 \\ b2 \\ ...\end{bmatrix}[/tex]
[tex]v_3= \begin{bmatrix}0 \\ 0 \\ 1 \\ ...\end{bmatrix}[/tex]
etc.
Now, suppose we have some linear combination [itex]\alpha_1v_1+ \alpha_2v_2+ \alpha_3v3+ ...= 0[/itex]
That gives
[tex]\begin{bmatrix}\alpha_1 \\ \alpha_1a_1+ \alpha_2 \\ \alpha_1a_2+ \alpha_2b_2+ \alpha_3\\ ...\end{bmatrix}= \begin{bmatrix} 0 \\ 0 \\ 0 \\ ...\end{bmatrix}[/tex]
The first component gives [itex]\alpha_1= 0[/itex]. The second component gives [itex]\alpha_1a_+ \alpha_2= 0[/itex] and since [itex]\alpha_1= 0[/itex], [itex]\alpha_2= 0[/itex]. The third component gives [itex]\alpha_1a_2+ \alpha_2b_2+ \alpha_3= 0[/itex]. Since [itex]\alpha_1= 0[/itex] and [itex]\alpha_2= 0[/itex], [itex]\alpha_3= 0[/itex], etc. That is, all scalars in the linear combination are 0 which means the vectors are independent.
Imagine taking A times each of the vectors <1, 0, 0, 0, 0>, <0, 1, 0, 0, 0>, <0, 0, 1, 0, 0>, <0, 0, 0, 1, 0>, and <0, 0, 0, 0, 1>, the "standard basis" for R5 in turn. You would get, of course, just the 5 columns of the matrix. Since "row reduction" does not change "independence", you know that the first, third, and fourth rows of the row-reduced form are independent, so are the first, third, and fourth rows of the original matrix and we know they are in the kernel. The other two, the second and fifth columns, are not independent so they map <0, 1, 0, 0, 0> and <0, 0, 0, 0, 1> into combinations of the other three columns- that is those three columns span the image as well as being independent and so are a basis for the image.
Thanks very much.
A vector, v, is in the kernel of A if and only if Av= 0. Imagine solving the equation by row reducing the augmented matrix. The added column is all 0s so no matter what the row operations are, the last column will remain all 0s. That is, row reducing the augmented matrix for your example will give
[tex]\left[\begin{array}{ccccc}1 & 2 & 0 & 0 & -1 \\ 0 & 0 & 1 & 0 & 2\\0 & 0 & 0 & 1 & 3\\0 & 0 & 0 & 0 & 0 \end{array}\right|\left|\begin{array}{c}0 \\ 0 \\ 0 \\ 0\end{array}\right][/tex]
If call a vector in the domain <u, v, x, y, z> those say that we must have u+ 2v- z= 0, x+ 2z= 0, and y+ 3z= 0. From the second and third equations, x= -2z and y= -3z. From the first equation, z= u+ 2v so that x= -2(u+ 2v)= -2u- 4v and y= -3(u+ 2v)= -3u- 6v. That is, we can write any vector in the kernel as <u, v, x, y, z>= <u, v, -2u-4v, -3u- 6v, u+ 2v>= <u, 0, -2u, -3u>+ <0, v, 4v, -6v, 2v>= <1, 0, -2, -3>u+ <0, 1, 4, -6, -2>v which tells us that any vector in the kernel can be written as a linear combination of <1, 0, -2, -3> and <0, 1, 4, -6, -2>. And those are clearly independent because of the "<1, 0" and "<0, 1" first two terms.
Thanks for that! It was a very helpful explanation.
I have another question. What exactly does row reducing a matrix do to it? Why is it that we can gain so much information about the matrix and the linear operator it represents from the row reduced form?
Thanks
Every row operation is the same as multiplying by an "elementary matrix"- the matrix you get by applying that row operation to the identity matrix. So if A can be row reduced to B then there exist a series P1, P2, P3, ..., Pn so that Pn...P3P2P1A= PA= B. Since every row reduction is invertible, their product, P, is also invertible. It follows then that if A is invertible, so is B, etc. For example, if B is the identity matrix, Pn...P3P2P1A= I then Pn...P3P2P1 is the inverse matrix to A. Since Pn...P3P2P1= Pn...P3P2P1I, applying the same row operations, that reduce A to the identity matrix, to the identity matrix gives [itex]A^{-1}[/itex].
As a scientist, it is important to have a solid understanding of the concepts and methods used in your field. In this case, it seems like you are struggling with the concept of linear independence and its connection to the reduced row echelon form of a matrix. Let me try to explain it in a simpler way.
First, let's define linear independence. A set of vectors is said to be linearly independent if none of the vectors can be written as a linear combination of the others. In other words, no vector in the set is redundant, and each one adds something unique to the set.
Now, let's look at the reduced row echelon form of a matrix. When we row-reduce a matrix, we are essentially performing a series of elementary row operations to simplify it and bring it to a more organized form. The reduced row echelon form is the most organized form, where the leading entry (the first non-zero entry) in each row is a 1, and all the entries above and below it are 0. This form is useful because it allows us to easily determine certain properties of the matrix, such as the rank and nullity.
In the given matrix, when you row-reduce it, you end up with a matrix where the first, third, and fourth columns are the only ones with a leading 1. This means that these columns are linearly independent, as no other column can be written as a linear combination of them. In other words, each of these columns adds something unique to the matrix.
Now, why do these columns correspond to a basis of the image of the linear operator? Remember that the image of a linear operator is the set of all possible outputs (vectors) that can be obtained by applying the operator to any input (vector). In this case, the matrix represents a linear operator from R5 to R4. This means that any input vector in R5 will be transformed into a vector in R4. The columns of the matrix represent the coefficients of the linear combination needed to transform an input vector into an output vector. So, the linearly independent columns correspond to the unique combinations needed to produce all possible outputs, thus forming a basis for the image.
To find a basis for the kernel, we can look at the columns in the reduced row echelon form that do not have a leading 1. In this case, the second and fifth columns have no leading 1, which means they are not linearly
FAQ: Row reducing the matrix of a linear operator
1. What is row reducing a matrix and why is it important in linear algebra?
Row reducing a matrix is the process of applying elementary row operations to transform a matrix into a simpler form, typically a row-echelon or reduced row-echelon form. This is important in linear algebra because it allows us to solve systems of linear equations, determine linear independence, and find the inverse of a matrix.
2. How do you row reduce a matrix of a linear operator?
To row reduce a matrix of a linear operator, we use the same elementary row operations that we use for any other matrix. These include adding a multiple of one row to another, multiplying a row by a non-zero constant, and swapping two rows. The goal is to transform the matrix into a simpler form without changing the solutions to the underlying system of equations.
3. Can you provide an example of row reducing a matrix of a linear operator?
Yes, for example, let's say we have the matrix A = [1 2; 3 4] representing a linear operator. To row reduce this matrix, we can perform the following elementary row operations:- Multiply the first row by -3 and add it to the second row- Multiply the second row by -2The resulting matrix is A = [1 2; 0 -2], which is in reduced row-echelon form and represents the same linear operator as the original matrix.
4. What is the significance of the pivots in a row-reduced matrix of a linear operator?
The pivots in a row-reduced matrix of a linear operator represent the leading entries in each row. These are important because they determine the number of solutions to the underlying system of equations. If there is a pivot in every row, the system has a unique solution. If there are fewer pivots than rows, there are infinitely many solutions. And if there are no pivots, the system has either no solutions or infinitely many solutions depending on the consistency of the system.
5. Are there any limitations to row reducing a matrix of a linear operator?
Yes, there are certain cases where a matrix cannot be row reduced. For example, if the matrix has a row of all zeros, it cannot be row reduced. Additionally, if the matrix has infinitely many solutions, the row-echelon form will have a row of all zeros. In these cases, we must use other methods such as Gaussian elimination to solve the underlying system of equations.
