Row Space, Column Space and Null Space
In summary, we are asked to construct a matrix with a null space consisting of all linear combinations of the column vectors v1={1;-1;3;2} and v2={2,0,-2,4}. Additionally, the equation x1+x2+x3=1 can be viewed as a linear system of one equation in three unknowns, and its general solution can be expressed as a particular solution plus the general solution of the corresponding homogeneous system.
Swati
1.Construct a matrix whose null space consists of all linear combination of the vectors, v1={1;-1;3;2} and v2={2,0,-2,4} (v1,v2 are column vector).2.The equation x1+x2+x3=1 can be viewed as a linear system of one equation in three unknowns. Express its general solution as a particular solution plus the general solution of the corresponding homogeneous system.
Hello Swati.
Sorry but I can't answer your question.
Here at MHB helpers don't straightaway give you the solutions. We like to lead you to the solution and not blatantly provide the full solution. You are required to show some effort.. whatever ideas you had on how to approach your problem.
Also try to post using latex. To learn how to do that you can check out the latex help forum on the homepage.
Regards.
FAQ: Row Space, Column Space and Null Space
What is the difference between row space, column space, and null space?
Row space refers to the set of all possible linear combinations of the rows of a matrix, while column space refers to the set of all possible linear combinations of the columns. Null space, also known as the kernel, is the set of all vectors that when multiplied by the matrix result in a zero vector.
How are row space and column space related to each other?
Row space and column space are related through the rank of the matrix. The rank is the number of linearly independent rows or columns in the matrix. The dimension of the row space is equal to the rank, and the dimension of the column space is also equal to the rank.
How can I find the row space, column space, and null space of a matrix?
To find the row space and column space of a matrix, you can use row reduction techniques to put the matrix into echelon form. The non-zero rows in the echelon form will form the basis for the row space, while the pivot columns will form the basis for the column space. To find the null space, you can solve the homogeneous system of equations using Gaussian elimination and the solutions will form the basis for the null space.
What is the significance of row space, column space, and null space?
Row space, column space, and null space are important concepts in linear algebra as they provide a way to understand the properties and behavior of matrices. The row space and column space can help determine the rank and invertibility of a matrix, while the null space can be used to find solutions to homogeneous systems of equations.
Can the row space and column space of a matrix be equal?
Yes, it is possible for the row space and column space of a matrix to be equal. This occurs when the matrix is a square matrix, and the rank is equal to the number of rows or columns. In this case, the basis for the row space and column space will consist of the same vectors, and the dimensions of the row and column space will also be equal.
