Row space, Column space, Null space & Left null space
In summary, the row space of a matrix consists of all possible linear combinations of its row vectors, representing the output of the matrix when multiplied by a column vector. The column space comprises all linear combinations of its column vectors, indicating the range of the linear transformation associated with the matrix. The null space, or kernel, is the set of all vectors that are mapped to the zero vector by the matrix, reflecting the solutions to the homogeneous equation. Finally, the left null space consists of vectors that yield a zero result when multiplied by the matrix from the left, corresponding to the solutions of the equation formed by the transpose of the matrix. Each of these spaces provides crucial insights into the properties and behaviors of the matrix in linear algebra.
DumpmeAdrenaline
80
\begin{pmatrix} 2 & 4 & 6 \\ 3 & 5 & 8 \\ 1 & 2 & 3 \end{pmatrix}
Using the row operations, R2<-- R2-3R1 R3<-- R3-R1 we find the row echelon form of the matrix.
\begin{pmatrix} 1 & 2 & 3 \\ 0 & -1 & -1 \\ 0 & 0 & 0 \end{pmatrix}
Based on the definition of row space in the book Í am studying from, the row space is a subspace that comprises an infinite collection of linearly independent rows of X.
To check if the row vectors [1,2,3] and [0,-1,-1] are linearly independent we write
$$ \beta_{1} [1,2,3]+\beta_{2} [0,-1,-1]=[\beta_{1}, 2\beta_{1}-\beta_{2}, 3\beta_{1}-\beta_{2}]=[0,0,0] $$
where β1 and β2 are scalars that belong to the field of real numbers.
If we consider the above, the only scalars (solution) that yields the 0 row vector are β1=β2=0. Therefore, the row vectors are independent. How to determine if the independent row vectors span the subspace and they form the basis vector for that subspace. Is the subspace considered here the infinite collection of 3*1 row vectors? If they are basis vectors for subspace does this imply if we add a new row vector to the given matrix we can write it in terms of the identified LI vectors or do we have to go through a new LU decomposition?
I'm not entirely clear what you are asking. But here are a few (non-mathematician's) comments...
To get a matrix to display using LateX (which is what is used on this site) don't use ICODE. Use double hash-tags as delimiters to produce this:
##\begin{pmatrix}
2 & 4 & 6 \\
3 & 5 & 8 \\
1 & 2 & 3
\end{pmatrix}##
If you want the matrix to be enclosed in square brackets, use 'bmatrix' rather than 'pmatrix' to get this:
##\begin{bmatrix}
2 & 4 & 6 \\
3 & 5 & 8 \\
1 & 2 & 3
\end{bmatrix}##
LaTex guide is here: https://www.physicsforums.com/help/latexhelp/
Use the preview icon (top right of editing window) to check formatting is correct before posting.
It's more usual to use right-pointing arrows. Also you missed out the first operation: ##\frac {R_1}2 \rightarrow {R_1}##.
Row echelon form requires that (for rows which do not contain all zeroes) the first non-zero entry is 1 (not -1). So (using ##-R_2 \rightarrow R_2##) the row echelon form is:
##\begin{bmatrix}
1 & 2 & 3 \\
0 & 1 & 1 \\
0 & 0 & 0
\end{bmatrix}##
Based on the definition of row space in the book Í am studying from, the row space is a subspace that comprises an infinitecollection of linearly independent rows of X.
What you mean is '...the infinite set of linear combinations of the linearly independent rows.
The 2 non-zero rows can immediately be seen to be linearly independent. One is not a scalar multiple of the other.
It helps to think geometrically. In 3D space, [1 2 3] and [0 1 1] are 2 vectors pointing in different directions; they lie in some (2D) plane. Linear combinations of these 2 vectors can produce any vector in this plane. So this 2D plane is a subspace of 3D space; the 2 vectors span this 2D subspace and hence are basis vectors.
The 2 vectors are basis vectors (because they span the subspace, as noted above). Note that these 2 basis vectors are not othogonal and not normalised.
It is not clear what you mean by 'add a new row vector to the given matrix'. If you replace the [0 0 0] row by a row which is linearly independent of the other 2 rows, this new row vector does not lie in the 2D subspace discussed above. In this case all 3 rows can be considered as a set basis vectors which will span the whole 3D space.
Likes Mark44, mathwonk and DumpmeAdrenaline
From what I understand, the row operations (interchanging rows, scaling, and replacing one row by the sum of itself and a multiple of another row) ensure that the number of independent rows equals the number of independent columns. However, my book states that the independent columns do not form the basis set for the column space. From the example, I understand that the independent column yield two vectors lying in the x-y plane (z=0) and they span all vectors in that plane. But they do not form the basis set because for the column space because the column vectors in X are all out of the plane of the independent column vectors. Is it because the rank of the column is less than the number of column vectors. Is there a way to prove why the book says so in the most general terms ?
## \begin{pmatrix}
1 \\
0 \\
\end{pmatrix} ## and ## \begin{pmatrix}
2 \\
1 \\
\end{pmatrix} ## are the independent columns and the span of subspace generated by these column vectors is ## \begin{pmatrix}
\beta_{1}+2 \beta_{2} \\
\beta_{2} \\
\end{pmatrix} ## where β1 and β2 belong to the set of real numbers
I'm no expert so what follows is based on my (amateur) understanding. But I'm sure someone will correct me if needed...
Ok. It might be better to say: the column rank and the row rank of a matrix are always equal and the allowed row operations don't change this.
I don't understand that. Check it carefully. I believe that a set of all linearly independent columns is (by definition) a basis set for the column space.
In the Post #1 matrix for example, any 2 columns are independent of the 3rd. Any 2 columns can be used as the basis of the column space.
I don't think that's right.
For the Post #1 matrix, the first 2 columns are linearly independent (the 3rd column is the sum of these). So a perfectly good basis for the column space are the 2 vectors [2 3 1]##^T## and [4 5 2]##^T##.
This column vector space has dimension 2 and can be visualised as a tilted plane in 3D. It is a different space to the matrix's row space (though both spaces are necessarily 2D). They can be visualised as two different subspaces (2 different planes) in 3D space (the 'ambient' space) if this helps.
## \begin{pmatrix}
1 \\
0 \\
2 \\
1 \\
This is confused. You can't use columns of the row echelon form as basis vectors for the column space of the original matrix. That's wrong
What you can do (though it's not necessary here) is to note that the pivots in the row echelon form are in column s 1 and 2. So columns 1 and 2 of the original matrix are basis vectors for the original matrix's column space.
\beta_{2} \\
Not sure about what you are saying but you don't need sums such as ##\beta_1 + 2\beta_2##. If ##\vec {b_1}## and ##\vec {b_2}## are basis vectors for a 2D space, then the space is spanned by ##a_1\vec {b_1} + a_2\vec {b_2}## where ##a_1## and ##a_2## are arbitrary (scalar) values. ##a_1## and ##a_2## are completely independent.
Likes DumpmeAdrenaline and mathwonk
What Steve is telling you is that row operations do not change the row space, but they do change the column space. so a basis for the row space of the echelon form will also be a basis for the row space of the original matrix, but this is not true for the column spaces. Row operations do however preserve the dimension of the column space, so the column rank is the same for the echelon form and the original matrix.
what is also true is that the two matrices have the same null space, since the null space space is determined by the row space (it is the orthogonal complement of the row space). But an element of the null space is a sequence of coefficient vectors that give a linear relation among the columns. so if certain columns of the echelon form are dependent, say the first and third, by means of a certain relation, that same relation will give a dependency among the first and third columns of the original matrix.
consequently, a certain subset of the columns of the echelon form will be independent if and only if the same subset of columns of the original matrix are independent, and hence a basis for the column space of the echelon form will be in the same positions as a basis for the column space of the original matrix. Here, since the first two columns of the echelon form are a basis for the column space of the echelon matrix, then also the original first two columns are a basis for the original column space.
Likes DumpmeAdrenaline and Steve4Physics
Do we say that vectors in the null space are orthogonal to vectors in the row space because the dot product of row vectors of matrix X with the column vector is 0. $$ X\beta=0 $$
$$ x+2y+3z=0 \hspace{0.2cm} y+z=0 $$
How do we interpret the pair of linear equations? Is it correct to say that each equation represents a plane with the same normal vector therefore the pair of row vectors lie in the same because a normal vector cannot be orthogonal to two different planes.
If the three row vectors are linearly independent they cannot all lie in the same plane. Therefore, if the row vectors originate from a common different pair of the three vectors forming different planes will intersect at the point they originate from which is the zero vector.
If we take the transpose of the column vector $$ \beta $$ and multiply the resulting row vector by the given matrix (either in its original form or reduced echelon form) we will be finding the vectors that are normal to the column subspace spanned by the linearly independent columns.
$$ \beta ^T X=0 $$
Can you please clarify this point?
" Do we say that vectors in the null space are orthogonal to vectors in the row space because the dot product of row vectors of matrix X with the column vector is 0. "
yes.
"How do we interpret the pair of linear equations? Is it correct to say that each equation represents a plane with the same normal vector "
no. the first equation is for a plane with normal vector = (1,2,3), and the second equation is for a plane with normal vector (0,1,1).
"Can you please clarify this point?"
when you multiply an mxn matrix M times a column vector A of length n, the answer is a linear combination of the length m column vectors in the matrix; the coefficients of this linear combination are the n entries in A.
This is absolutely basic information about matrix multiplication. You should play a little with matrices until you grasp this fundamental information.
Likes Mark44
We have two equations of planes that contain the origin, and we are trying to find the points that lie on both planes. Since the planes are not parallel the points of intersection will lie on a line. This line will be normal to the two normal row vectors.
$$ y+z=0 \rightarrow z=-y $$
$$ x+2y+3z=0 \rightarrow x+2y-3y=0 \rightarrow x=y $$
The null space is the set of column vectors ## \begin{pmatrix}
y \\
y \\
-y
\end{pmatrix} ## where y is any real number
I understand that there different views to think about a matrix-vector product. You are saying that If we interpret matrix M as a set of rows. When we write MA=0 we are solving for the entries of A) such that A is orthogonal to each of the independent row vectors. If we are interpreting M as a set of column vectors we are finding the scalars that would yield from the linear combination of column vectors (independent and dependent) the zero vector.
## \begin{pmatrix}2 & 4 & 6 \\3 & 5 & 8 \\1 & 2 & 3\end{pmatrix} ## * ## \begin{pmatrix}
y \\
y \\
-y
\end{pmatrix} ##=y## \begin{pmatrix}2 \\3 \\1 \end{pmatrix} ## +y## \begin{pmatrix}4 \\5 \\
2 \end{pmatrix} ## -y ## \begin{pmatrix}6 \\8 \\3 \end{pmatrix} ##=## \begin{pmatrix}0 \\0 \\0 \end{pmatrix} ##
nice. that's it.
