Roxy's question at Yahoo Answers regarding finding the area between two curves
In summary: And so, in summary, the area between the curves on the interval [0,1] of y=sin3x and y=cos2x is approximately 0.521657539274763.
MarkFL
MHB
13,288
Here is the question:
Calculus finding the area between the curves on the interval?
find the area between the curves on the interval [0,1]. y=sin3x and y=cos2x
please show me the steps thank you !
I have posted a link there to this thread so the OP can view my work.
Mathematics news on Phys.org
Hello Roxy,
The area in question can be found with:
\(\displaystyle A=\int_0^1 \left|\sin(3x)-\cos(2x) \right|\,dx\)
Here is a graph of the two curves over the given interval:
We need to find where the two curves intersect so that we may split the integral into two integral where the integrand of each contains the upper curve minus the lower curve. So, equating the two curves, we have:
\(\displaystyle \sin(3x)=\cos(2x)\)
Applying a triple-angle identity for sine on the left and a double-angle identity for cosine on the right, we have:
\(\displaystyle 3\sin(x)-4\sin^3(x)=1-2\sin^2(x)\)
We may then arrange this as:
\(\displaystyle 4\sin^3(x)-2\sin^2(x)-3\sin(x)+1=0\)
Factor:
\(\displaystyle \left(\sin(x)-1 \right)\left(4\sin^2(x)+2\sin(x)+1 \right)=0\)
The only root that results in $x$ being in the given interval comes from:
\(\displaystyle \sin(x)=\frac{-1+\sqrt{5}}{4}\implies x=\frac{\pi}{10}\)
And so, we may state:
\(\displaystyle A=\int_0^{\frac{\pi}{10}} \cos(2x)-\sin(3x)\,dx+\int_{\frac{\pi}{10}}^1 \sin(3x)-\cos(2x)\,dx\)
Applying the FTOC, we obtain:
\(\displaystyle A=\left[\frac{1}{2}\sin(2x)+\frac{1}{3}\cos(3x) \right]_0^{\frac{\pi}{10}}-\left[\frac{1}{3}\cos(3x)+\frac{1}{2}\sin(2x) \right]_{\frac{\pi}{10}}^1\)
\(\displaystyle A=\frac{1}{2}\sin\left(\frac{\pi}{5} \right)+\frac{1}{3}\cos\left(\frac{3\pi}{10} \right)-\frac{1}{3}-\frac{1}{3}\cos(3)-\frac{1}{2}\sin(2)+ \frac{1}{3}\cos\left(\frac{3\pi}{10} \right)+\frac{1}{2}\sin\left(\frac{\pi}{5} \right)\)
Combine like terms:
\(\displaystyle A=\sin\left(\frac{\pi}{5} \right)+\frac{2}{3}\cos\left(\frac{3\pi}{10} \right)-\frac{1}{3}-\frac{1}{3}\cos(3)-\frac{1}{2}\sin(2)\)
\(\displaystyle A=\frac{1}{12}\left(5\sqrt{2\left(5-\sqrt{5} \right)}-\left(6\sin(2)+4\cos(3)+4 \right) \right)\approx0.521657539274763\)
FAQ: Roxy's question at Yahoo Answers regarding finding the area between two curves
What are the steps to finding the area between two curves?
The steps to finding the area between two curves are as follows:
1. Identify the two curves and their equations.
2. Determine the points of intersection between the two curves.
3. Set up the integral by subtracting the lower curve's equation from the upper curve's equation.
4. Integrate the resulting equation with respect to the variable of integration.
5. Use the limits of integration to evaluate the definite integral and find the area between the two curves.
Can you provide an example of finding the area between two curves?
Sure, let's say we have two curves: y = x^2 and y = 2x + 3. First, we need to find the points of intersection between the two curves by setting their equations equal to each other:
x^2 = 2x + 3
x^2 - 2x - 3 = 0
(x - 3)(x + 1) = 0
x = 3 or x = -1
Next, we set up the integral by subtracting the lower curve's equation from the upper curve's equation:
∫ (2x + 3) - x^2 dx
Then, we integrate the resulting equation:
2x^2/2 + 3x - x^3/3 + C
Finally, we plug in the limits of integration (3 and -1) and evaluate the definite integral to find the area between the two curves, which is approximately 10.33 square units.
Do the curves have to be intersecting to find the area between them?
No, the curves do not have to be intersecting to find the area between them. If the curves do not intersect, you can still find the area between them by using the limits of integration as the points where the curves "intersect" on the x-axis.
Can the area between two curves be negative?
Yes, the area between two curves can be negative. This can happen when the upper curve's equation is below the lower curve's equation for a certain range of values. In this case, the area between the two curves would be considered negative and would be subtracted from the overall area.
Are there any real-life applications of finding the area between two curves?
Yes, finding the area between two curves has many real-life applications in fields such as physics, engineering, and economics. Some examples include calculating the work done by a varying force, determining the volume of a complex shape, and calculating the profit or loss of a business with changing costs and revenues.
