jwlgrant
- 1
Here's the problem: "On a journey to Mars, one design is to have a section of the spacecraft rotate to simulate gravity. If the radius of this section is 30 meters, how many RPMs must it rotate to simulate one Earth gravity (1 g = 9.8 meters/sec^2)?"
[itex]A = \frac{V^2}{R}[/itex]
I completed this problem, getting an answer of 5.5 RPM. Apparently I was wrong, and the answer should have been 14 RPM. I asked my instructor about it, and he showed me the calculations used to get 14 RPM, but it still didn't quite make sense to me.
Here's the process my instructor used to solve the problem:
Circumference is C = 2∏(30) = 188 meters.
1 rpm is like rotating 1 full circular rotation every minute, so 188/60 = 3.1 meters/sec.
Then V = 3.1 meters/sec x RPM.
Then A = (3.1 RPM)^2/188 = 0.05 x rpm^2.
So: 9.8 = 0.05rpm^2
RPM = 14
Here's my process:
A = 9.8 (m)/(s^2)
R = 30 m
V = √(AR)
V = 17.15 m/s
1 revolution = circumference = 2∏30 m
[1 revolution/(2∏30 m)] * [60s/1 min] (1 rev is equal to 2π30m and sixty seconds is equal to one minute)
V = (17.15 m/s)/∏ RPM
V = 5.5 RPM
I realize, of course, that we both used different methods to get the answer. I thought I did it wrong, so I solved the problem again, using his method, to try to get the correct answer. He used 188m for the radius component when solving for A=V^2/R, but when I used 30m I got an answer of 5.5RPM. The radius, 30m, should be used in that equation, not 188m, right?
I would greatly appreciate any help in understanding this problem. I can't tell where/how I went wrong in solving it.
