Rules in determining family of planes in Hexagonal
In summary, the crystallographic point group determines the maximum number of families of planes that can exist in a given crystal.
ralden
85
Hi guys, I'm assume that you already know the 7 crystal system, each crystals have unique way of determining the family of planes, for example in cubic, we all know (111) plane is same (-1-1-1), and so on ((-1-11),(-11-1)...) a total of 8, in fact there is pattern to determine how many possible planes does a miller indices (hkl) can have in each crystal, so now my problem is, how to determine all family of planes in hexagonal, based on literature for h is not equal to k, k is not equal to l and h is not equal to l, there are 24 possible planes you could have, but what are those 24? for example in hexagonal you have (123) plane and you could have 24 family of planes, but what are the basis or rules to determine the maximum possible families of planes? please help thanks.
In general, you have to consider the crystallographic point group. By applying all the point group operations to your reciprocal lattice vector (HKL) you
obtain all equivalent vectors, i.e. all other planes in the same family.
For cubic and tetragonal groups you can do that pretty much by inspection. For hexagonal this is a bit more tricky. Sometimes a 4th (redundant) Miller index is used to make lattice planes within the same family look alike:
http://en.wikipedia.org/wiki/Miller_index#Case_of_hexagonal_and_rhombohedral_structures
so given a p\lane in hexagonal (134), how could you determine all possible family of plane it have?
This number (24) is also called multiplicity. To calculate it we should calculate the length of your reciprocal lattice vector. In hexagonal case (hkl)^2 = a*^2(h^2+k^2+hk) + c*^2 l. Then we should look at which h,k,l the length remains the same. So the problem is reduced to h^2+k^2+hk=const. This can be done algebraically or geometrically. You can have additionally h'=h-k,k'=-k, etc. Geometrically we have reciprocal a* and b* that make an angle of 60 degrees. This makes 360/60=6 possible combinations, then 6*2=12 because we can exchange h and k, and finally 12*2=24 due to +/-l.
Voila...
ahhmm but if you have 110 which have 6 multiplicity, using your equation it only generates 2 multiplicity which is 110, and -1-10.
and also 00-4 based on your equation is equal to -100, and -110
24 is a maximal multiplicity when h # k # l # 0. For 110: -110, 0-10,-210,...
00-4 can be equal to -100 only accidentally. Look at the formula. There are also lengths a*, c* which are different.
so what are lengths a* and c* ?
reciprocal lattice constants.
Your basis is a*=[b x c]/V, b* =[c x a]/V, c* = [a x b]/V.
V - is cell volume, a,b,c, - basis of the lattice. The hkl that you use are written in the above basis.
can you list down all possible families of plane in (123?) I'm still confuse.
-3 1 3
-3 2 3
-2 -1 3
-2 3 3
-1 -2 3
-1 3 3
1 -3 3
2 -3 3
2 1 3
3 -2 3
3 -1 3
and the same as above multiplied by -1.
hope it helps...
FAQ: Rules in determining family of planes in Hexagonal
What is the definition of a family of planes in Hexagonal?
A family of planes in Hexagonal is a group of planes that share a common orientation and intersect at a single point, forming a 3-dimensional lattice structure.
How do you determine the family of planes in Hexagonal?
The family of planes in Hexagonal can be determined by identifying the Bravais lattice type, which is determined by the lattice points and unit cell of the crystal structure. For Hexagonal crystal structures, the Bravais lattice type is Hexagonal, and the family of planes will have a Miller Index notation of (h, k, l).
What are the rules for determining the Miller Indices of a plane in Hexagonal?
The rules for determining the Miller Indices of a plane in Hexagonal are as follows:
  • The first index (h) is the distance between the plane and the origin along the a-axis.
  • The second index (k) is the distance between the plane and the origin along the b-axis.
  • The third index (l) is the distance between the plane and the origin along the c-axis.
  • If the plane is parallel to an axis, the corresponding index is 0.
  • If the plane intersects an axis, the corresponding index is infinity.
What is the significance of determining the family of planes in Hexagonal?
Determining the family of planes in Hexagonal is important in understanding the crystal structure and properties of a material. It can also help in predicting the growth and behavior of crystals, as well as in studying their physical and chemical properties.
Are there any exceptions to the rules in determining the family of planes in Hexagonal?
Yes, there are exceptions to the rules in determining the family of planes in Hexagonal. These exceptions occur when the crystal lattice is distorted or when there are impurities present in the crystal structure. In these cases, the Miller Indices may not follow the traditional rules and may need to be adjusted accordingly.
9K
