Russian style nuclear powered drive for a space ship?
In summary, the Russian nuclear ramjet engine is a jet engine that requires air to produce thrust. However, the Boeing's fusion drive engine is a jet engine that does not require air to produce thrust.
consuli
62
Russia has developed a micronized nuclear powered drive for ballistic misiles and cruize misiles. This is obviously a very aggressive and environment polluting action.
However, could such nuclear powered drive be used for space ships, that would start in space and do not touch the atmosphere of earth?
There is a lot of background radiation in space allready, so that a little more wouldn't really be a pollution, right or wrong?
How much power would such nuclear drive approximately have?
Consuli
Without details it's hard to say for sure. Just because it's nuclear?
There are several different solutions known for nuclear powered jet and rocket engines.
Likes Astronuc, gmax137 and russ_watters
consuli said:
Imho, it is well accepted
No, it is not. It was only a design choice for that Pluto project, which was intended to be a disposable engine used in a nuclear war.
There is no rule stating that a nuclear powered engine must leave a trail of fission products behind.
And the environmental friendly design of a nuclear (fission) ramjet engine - you are talking about - is what?
Consuli
Consuli
All you need to do is not expose the core to the air like in literally every nuclear reactor in service. When I first googled this I thought it was an error because the idea of exposing the core to the air is just so stupid. But I guess during the cold war they would entertain ideas that were only viable if the world was already in the process of being destroyed.
Anyway, there can be no "accepted" conventional wisdom for experimental projects, by definition.
However it seems, that russian military has only managed to micronize a nuclear ramjet engine, that fits into a rocket or cruize missile, by operating a critical nuclear reactor unshielded and exposed to air.
https://www.quora.com/How-might-a-nuclear-powered-cruise-missile-engine-work said:
Basically, its an unshielded nuclear reactor in critical condition, which generates an incredible amount of heat (and fallout). Once pushed up to speed using a rocket booster, the air passing through the ramjet (and past the unshielded reactor) becomes superheated from both compression and the reactor, which produces thrust. Lots of it. In theory, such a missile would have unlimited range. It would also spew out radiation the entire time, which, during the Cold War was actually considered a “feature” rather than a bug.
Consuli
I'm aware. That doesn't make it "well accepted" that it has to be that way.
I don't think those engaged in global war, conventional or nuclear, are much concerned with niceties.
Likes russ_watters
Exactly. One who accepts, that a conventional warhead will automatically be also a (nuclear) dirty bomb, will - most probably - accept polluting the environment by radioactive material, either.
However, this polluting the environment discussion by the russian nuclear ramjet engine is out of the scope of what I have been asking in my initial posting.
I wanted to know, if the russian nuclear ramjet engine or Boeing's fusion drive engine could be used to propel a space ship.
And Russ has answered my question so far, that
  • the russian nuclear ramjet engine is a jet stream engine, that requires air to produce thrust,
  • Boeing's fusion drive engine is also called a jet engine, but effectively would run without air.
So my following questions are:
  1. Thus, Boeings fusion drive engine is much more appropriate to propel a spaceship (if it works), because it does not need air or any other extra carried matter, that gets heated, so that it gets spit out with high velocity backwards (to produce thrust)?
  2. This is only the case, because the fusion products of Boeings fusion drive are gases (at the temperature of the reactor/ combustion chamber?
  3. Isn't it possible to select a very special fissible material as nuclear fuel, that has a fission chain, that produces a lot gases in the end (so that it wouldn't be necessary to carry extra matter for heating to produce thrust?)
Consuli
Even if you have a lot of energy, you still need reaction mass to make a lot of thrust.
But we do have ion engines that make small thrust for long periods of time to accelerate light weight space probes. Is that what you're thinking? or is it thrust large enough for manned spacecraft that you're asking about?
I am asking for thrust of a large manned spacecraft .
In that case, no. Outgasses from a nuclear reactor will provide nowhere near enough thrust.
consuli said:
Imho, it is well accepted, that. . .
Consuli
Well accepted by whom. In the article cited in the OP, details are insufficient to render definitive perspective on activity release. Nuclear ramjets are not inherently polluting with fallout, but they could if poorly designed. I suspect in the case of a nuclear powered cruise missile, it would not be conventional. Roughly one third of fissions produce volatile or gaseous (Xe, Kr) fission products, and these can be limiting if burnup goes much beyond 6-7% fission of initial metal atoms. A cruise missile is designed for minutes to hours of operation, and the burnup will depend on the fraction of fissile material consumed during the flight.
Forget fusion systems, since we do not have a controlled nuclear fusion system generating power over hours as steady-state.
As for propulsion, there has to be a propellant, e.g., hydrogen or some other fluid. There are various types of electromagnetic thrusters, which could use a nuclear power plant to supply electricity with which to accelerate a propellant. Then there are the more conventional low Isp nuclear thermal systems that simply force the propellant through the core.
consuli said:
  • Thus, Boeings fusion drive engine is much more appropriate to propel a spaceship (if it works), because it does not need air or any other extra carried matter, that gets heated, so that it gets spit out with high velocity backwards (to produce thrust)?
  • This is only the case, because the fusion products of Boeings fusion drive are gases (at the temperature of the reactor/ combustion chamber?
  • Isn't it possible to select a very special fissible material as nuclear fuel, that has a fission chain, that produces a lot gases in the end (so that it wouldn't be necessary to carry extra matter for heating to produce thrust?)
1. Still need propellant. One would have to feed the fusion reactor to make up for whatever plasma is used in the propulsion system.
2. Fusion systems use plasmas, but the plasma has very low density, so low mass flow rate. And fusion systems are massive.
3. No.
Correct me if I'm wrong but I feel the need to add something here,
Russ commented that we don't expose reactor cores in modern reactors (we did in some early test reactors for bomb production) and that is true, we have secondary loops etc, the thing is in a nuclear reactor in order to get water superheated into steam you only need about 300-400 celsius to do that which is well within the material and steel alloy temperature limits so there is no problem of making secondary loops.Now if I'm not mistaken in a rocket in order to have some serious thrust the exhaust temperature needs to be high (I read in conventional rockets it is about 3000 celsius) now 350 celsius which is the average design temp of primary loop in a water cooled reactor is nothing compared to that temp. I can make 350 degrees in my home using a gas burner and it won't take or lift off the ground anytime soon.
In a chemical type rocket the two fuels are mixed but they burn in a special chamber which directly ventilates into the atmosphere so metal parts are not directly subject to this temperature so they don't melt, in a nuclear reactor rocket that is also environmentally friendly you would have to make a heat transfer loop in order to shield the core but since you need to heat the bypassing air to such high temperatures you would need the metal parts that would transfer the heat to the air to be also at this temperature and as far as I'm aware this is the problem also the limitation.
either you get low temps and the air has very low thrust or you expose the core and the rocket becomes a "one use only" item that simply needs to reach the target and spews "Chernobyl" along the way.
This is why they were interested in fusion rockets because with fusion you could let the byproducts directly into the air since they are not harmful (Helium for example) but we are yet to reach a point where we can achieve self sustaining fusion so this is off the table for now.
Ok, I give up. You guys find the environment pollution of the russian nuclear power drive for balistic and cruise missiles more interesting. So, we have to finish this one first, I guess, before we can deal with the thread-openers question. :wink:
girts said:
In a chemical type rocket the two fuels are mixed (and then burn at about 3000 celsius), but they burn in a special chamber which directly ventilates into the atmosphere so metal parts are not directly subject to this temperature so they don't melt, in a nuclear reactor rocket that is also environmentally friendly you would have to make a heat transfer loop in order to shield the core but since you need to heat the bypassing air to such high temperatures you would need the metal parts that would transfer the heat to the air to be also at this temperature and as far as I'm aware this is the problem also the limitation.
Sounds very plausible to me.
I also referenced to this miniaturization problem of a nuclear reactor. A cruise missile is not big enough, to install a high temperature heat exchanger in it, if such thing has been engineered yet, at all ! However, no one understood me, as I used - the maybe wrong - term micronisation for it.
Consuli
[moderator: p.s. removed]
The OP question, clarified in #13, could we power a manned spaceship with a nuclear engine using offgas from the reactions as a propellant, has been answered.
Thread closed.
Related to Russian style nuclear powered drive for a space ship?
1. How does a Russian style nuclear powered drive work?
A Russian style nuclear powered drive, also known as a nuclear thermal rocket, works by using the heat generated from a nuclear reactor to heat a propellant, such as liquid hydrogen. This heated propellant is then expelled out of a nozzle at high speeds, creating thrust and propelling the space ship forward. This method is much more efficient than traditional chemical rockets and allows for longer and faster space travel.
2. Is a Russian style nuclear powered drive safe?
Safety is a top priority in the development of any nuclear technology, and the same applies to a Russian style nuclear powered drive. These drives are designed with multiple layers of shielding to protect the crew and the environment from radiation. Additionally, rigorous safety protocols and testing are conducted before any launch.
3. What are the advantages of using a Russian style nuclear powered drive for a space ship?
One of the main advantages of using a Russian style nuclear powered drive is its high efficiency. Due to the intense heat generated by the nuclear reactor, these drives can achieve higher speeds and travel longer distances compared to traditional chemical rockets. They also require much less propellant, making them ideal for long-term missions.
4. Are there any environmental concerns with using a Russian style nuclear powered drive?
While the use of nuclear technology always raises environmental concerns, a Russian style nuclear powered drive is designed with the utmost care to minimize any potential impact. The reactors used are designed to be highly efficient and produce little to no emissions, and strict protocols are in place for disposal of any nuclear waste.
5. How long has Russia been developing nuclear powered drives for space ships?
Russia has been researching and developing nuclear powered drives for space ships since the 1950s. The first test flight of a nuclear thermal rocket, the KIWI-A, was conducted by the United States in 1959. Russia continued to develop and test various designs throughout the 1960s and 1970s, with the most recent test flight taking place in 2018.
  • Aerospace Engineering
  • Astronomy and Astrophysics
