Rutherford Backscattering Experiment
In summary, Rutherford's successful approach in the "Rutherford backscattering" experiment was due to his use of an extremely thin foil with a heavier target nucleus. This resulted in confirmation of the atomic nucleus, as most of the foil's mass was concentrated and not evenly distributed. Deviation from the Rutherford scattering formula would occur if the foil was thicker and the target nucleus and incident alpha particle were of comparable mass.
TauDay
In the famous “Rutherford backscattering” experiment, alpha particles (Z=2) of
approximately 7 MeV were used to bombard a Au (Z=79) film. Rutherford derived the
scattering formula by treating an incident alpha particle and a Au target atom as two point
charges with their charge numbers equal to their atomic numbers. This assumption, however,
is not accurate in describing general ion solid interactions. Explain
(a) why was Rutherford’s approach successful in his experiments?
and
(b) under what conditions deviation from Rutherford scattering formula will occur?
a) Rutherford’s approach was successful because he used an extremely thin foil with a target nucleus much heavier than the incident alpha particles.
b) If the foil was thicker and the target nucleus and incident alpha particle were of comparable mass, Rutherford would have observed increased ion-solid reaction types.
The thin foil is certainly an important point. The heavy nucleus is something the scattering formula can take into account.
I think the question asks for something that you missed so far. What was the important historic result of the experiment? If you know the result in advance (as we do know) it might look obvious, but at that time it was unclear.
Hint:
What about electrons, for example?
The result was confirmation of the atomic nucleus - most of the foil's mass is concentrated and not evenly distributed.
Additionally, if the target nucleus had a different charge from the incident particle, the scattering pattern would deviate from Rutherford's formula. Other factors that could affect the deviation from Rutherford scattering include the energy and angle of the incident particle, and the composition and thickness of the target material. In general, the closer the target nucleus and incident particle are in mass and charge, the more likely it is for the scattering pattern to deviate from Rutherford's formula.
FAQ: Rutherford Backscattering Experiment
1. What is the Rutherford Backscattering Experiment?
The Rutherford Backscattering Experiment is an experimental technique used to study the composition and structure of materials. It involves bombarding a sample with high-energy particles, typically alpha particles, and measuring the scattering of these particles as they interact with the atoms in the sample.
2. How does the Rutherford Backscattering Experiment work?
In the experiment, a beam of high-energy particles is directed at a thin sample. As the particles interact with the atoms in the sample, they are scattered in various directions. The detector measures the number and energy of the particles that are scattered back towards the source, known as backscattering. By analyzing the backscattered particles, researchers can determine the composition and structure of the sample.
3. What type of information can be obtained from the Rutherford Backscattering Experiment?
The Rutherford Backscattering Experiment can provide information about the elemental composition and thickness of a sample, as well as the density and distribution of atoms within the material. It can also reveal structural features such as the crystal lattice and defects within the sample.
4. What are the advantages of using the Rutherford Backscattering Experiment?
The Rutherford Backscattering Experiment is a non-destructive technique, meaning the sample being studied is not significantly altered or damaged during the experiment. It also has high sensitivity and can provide precise measurements of the composition and structure of a sample. Additionally, the experiment can be performed on a wide range of materials, including thin films, polymers, and biological samples.
5. What are the limitations of the Rutherford Backscattering Experiment?
One limitation of the Rutherford Backscattering Experiment is that it requires a high-energy particle accelerator, which can be expensive and not easily accessible. Additionally, the technique is not suitable for samples with a high atomic number or those that are very thick, as the backscattering signals may be too weak to detect. It also cannot provide information about the chemical bonding or electronic structure of a sample.
