Rutherford scattering problem
Thank you.In summary, the Rutherford scattering formula is not valid for the scattering of a 6 MeV alpha particle on a gold nucleus with A = 197. This is due to the high Coulomb barrier energy and the small scattering angle, which do not satisfy the conditions under which the formula is accurate. Other factors, such as the finite size of the gold nucleus, must be considered for a more accurate calculation of the scattering cross-section.
natugnaro
64
Alpha particle with kinetic energy 6MeV is scatterd on gold nucleus (A=197).
Is Rutherford cross-section formula valid for this scattering? Explain !
The Coulomb barrier is Ec=(1.03MeV)*(Z1*Z2)/(A1^1/3+A2^1/3)
Z1=79 , Z2=2 , A1=197 , A2=4
Ec=1.03MeV*158/7.41=22MeV
The 6 Mev alpha particle will not go through the barrier, forces between alpha particle and gold nucleus will be coulombic so I think it is valid to use Rutherford cross-section.
But I found that Rutherford cross-section formula is valid if
[tex]Z1*Z2*\alpha<<1[/tex] is true.Since for Z1=79,Z2=2,alpha=1/137 this is not <<1 ,
so rutherford cross-section is not valid.
Where I'm going wrong?
Thank you for your question. It is important to consider the conditions under which the Rutherford scattering formula is valid. The formula is based on the assumption that the scattering is due to a point-like Coulomb potential between the alpha particle and the gold nucleus. This means that the size of the gold nucleus is negligible compared to the distance between the alpha particle and the nucleus. In other words, the alpha particle must be scattered at large angles (close to 180 degrees) for the formula to be valid.
In your case, the Coulomb barrier energy of 22 MeV is much higher than the kinetic energy of the alpha particle, which suggests that the scattering angle will be small. In this regime, the Rutherford formula is not accurate and other factors, such as the finite size of the gold nucleus, must be taken into account.
Additionally, as you correctly pointed out, the formula is only valid if the parameter Z1*Z2*\alpha is much smaller than 1. In your case, this parameter is equal to 0.003, which is small enough to satisfy the condition. However, it is important to note that this parameter alone does not determine the validity of the formula. The condition for small scattering angles is also crucial.
In conclusion, for your specific case, it is not appropriate to use the Rutherford scattering formula. Other factors, such as the finite size of the gold nucleus and the small scattering angle, must be taken into account for a more accurate calculation of the scattering cross-section. I hope this helps clarify the issue. Please let me know if you have any further questions.
Related to Rutherford scattering problem
1. What is the Rutherford scattering problem?
The Rutherford scattering problem refers to the experiment conducted by physicist Ernest Rutherford in 1911, in which he bombarded alpha particles at a thin gold foil and observed their scattering patterns. This experiment led to the discovery of the atomic nucleus and the development of the nuclear model of the atom.
2. How did Rutherford explain the unexpected results of his scattering experiment?
Rutherford's experiment showed that most of the alpha particles passed straight through the gold foil, but a small percentage were deflected at large angles. This was unexpected according to the prevailing model of the atom at the time, which proposed that the positive charge of the atom was spread out evenly throughout the atom. Rutherford explained this by proposing that the positive charge of the atom was concentrated in a small, dense nucleus at the center of the atom.
3. What is the significance of the Rutherford scattering problem in the development of atomic theory?
The Rutherford scattering problem was a crucial step in the development of atomic theory. It provided evidence for the existence of the atomic nucleus and disproved the previous model of the atom. This discovery led to further research and advancements in atomic theory, including the development of the Bohr model and the understanding of subatomic particles.
4. How is the Rutherford scattering problem used in modern science?
The Rutherford scattering problem is still used in modern science in various fields such as nuclear physics and particle physics. It is also used in medical imaging techniques such as PET scans, which use radioactive isotopes that emit alpha particles to create images of the inside of the body.
5. What other contributions did Rutherford make to the field of science?
Rutherford made many important contributions to science, including the discovery of the concept of radioactive half-life, the classification of alpha, beta, and gamma radiation, and the development of the proton-neutron model of the atomic nucleus. He also received the Nobel Prize in Chemistry in 1908 for his work on radioactive elements.
  • STEM Educators and Teaching
  • Electromagnetism
