Rutherford Scattering Problem.
In summary, in an experiment, an alpha particle of mass 6.7e-27 kg and charge 3.2e-19C travels in a straight line with a speed of 2.0e7m/s towards the center of a gold nucleus of charge 1.3e-17C. The kinetic energy of the alpha particle is 1.34e-12J. The potential at a distance x from the center of the gold nucleus is V=4.1875*10^6JC^-1. The closest distance of approach is 2.79e-14m.
Cilabitaon
69
In an experiment, an alpha particle of mass 6.7e-27 kg; charge 3.2e-19C travels in a straight line with a speed 2.0e7m/s towards the centre of a gold nucleus.
Find:
1. The kinetic energy([tex]KE[/tex]) of the alpha particle;
2. The potential(V) at a distance '[tex]x[/tex]' from the centre of the gold nucleus(of charge 1.3e-17C)
3. The closest distance of approach, and prove that it is 2.8e-14m
[tex]KE=\frac{mv^{2}}{2}[/tex]
[tex]E=\frac{F}{Q}[/tex]
[tex]E=\frac{V}{x}[/tex]
1. [tex]KE=\frac{mv^{2}}{2} = \frac{1}{2}·{(6.7*10^{-27}) · (2*10^{7})^{2}}[/tex] = [tex]_1.34*10^{-12}J[/tex]
This part I'm pretty sure of, and I know I should be doing these in my sleep by now, but it was 3:00am when I did this and haven't checked any of these much.
2. E=F/Q and E=V/x
F/Q=V/x -> V=(Fx)/Q
I really had no idea what I was being asked here; yes I realize it tells me clear-as-day, but I just can't seem to get anywhere with this question.
2. I really didn't have a clue. I have tried so many approaches with each being as tame as the last: I first tried initial KE = final PE, to no avail; but that may just be since every time I go over the question I end up answering it in the same WRONG way.
Sorry, I'm not asking anyone to do my homework for me, but I just feel like I'm missing that little piece of info I happened to overlook.
For question 1, your result for the KE of the alpha particle is correct.
Question 2. is about the potential of the gold nucleus. It is considered a point charge of 1.3e-17C. What is the potential at a distance x from a point charge of q?
Question 3 is not a question. Are you sure you copied the problem well? Maybe, you are to find the original distance of the particle from the nucleus.
ehild
I still don't get the question, the point charge q has a value, so am I expected to put that into a formula with potential(V) and distance (x): where all I'd get is (Wx/q)=V
Question 3 is trying to get me to use current data to find the closest distance of approach, but the question tells me what it is just so I can say "yeah, I'm right/wrong" when I get to the final answer.
You can find the distance of closest approach if you know the initial position of the particle. Maybe it was meant that the particle started from very far, practically infinity. Or it is asked from where the particle had started, so as the closest approach is at the given distance.
Try to assume that the particle has that 1.34e-12 J KE at infinity. At the closest approach, the KE is converted to potential energy. What is the potential energy when the alpha particle is at a distance x from the gold nucleus? You need to use the Coulomb potential.
ehild
So I need [tex]V=\frac{Qq}{4\pi\epsilon_{0}r^{2}}[/tex]?
But then that would make [tex]Q[/tex] my Au nucleus and my point charge the alpha particle, correct?
Also, I change [tex]r^{2}[/tex] for [tex]x^{2}[/tex], don't I?
Thanks a lot for this help by the way; it's much appreciated.
That is the Coulomb force, not the potential energy!
Yes, r or x is the distance between the nucleus and the alpha particle. And Q is the charge of the gold nucleus and q is that of the alpha particle.
ehild
ehild
Sorry, I was quoting from my A2 textbook and it states:
Force between two point charges;
[tex]F=\frac{Q_{1}Q_{2}}{4\pi\epsilon_{0}r^{2}}[/tex]
and
electric potential;
[tex]V=\frac{W}{Q}[/tex]
Should the latter not have [tex]r[/tex], not [tex]r^{2}[/tex]?
I still don't know the potential at any point, or the distance, so how can potential energy changes be used?
I've just thought, with the equation [tex]V=\frac{W}{Q}[/tex] I can find [tex]V[/tex] for the [tex]\alpha[/tex] particle.
[tex]W=1.34*10^{-12}J[/tex]
[tex]V=\frac{1.34*10^{-12}}{3.2*10^{-19}} = 4.1875*10^{6}JC^{-1}[/tex]
The potential around a point charge Q is
[tex]
V=\frac{Q}{4\pi\epsilon_{0}r}
[/tex]
What you cited V=W/Q means the definition of the potential: It is the work done by the electric field on unit positive charge when it moves from the given point to infinite, or to a position where the potential is zero. The potential energy of a charge q is Vq.
So, find the distance from the nucleus, where the potential is
[tex]
V= 4.1875*10^{6}JC^{-1}
[/tex]
ehild
Thanks a lot!
This does give me confidence, but now I'm wondering; isn't this the potential of the [tex]\alpha[/tex] that we have both just found?
edit:
Oh my goodness, I do believe I am an idiot :)
Thanks so much, I've just realized I've been making the same problems for myself every time I go through this, and now it's just become clear that it wasn't a problem at all!
[tex]V = \frac{Q}{4 \pi \epsilon_{0}r}[/tex]
[tex]r = \frac{Q}{V \cdot 4 \pi \epsilon_{0}}[/tex]
[tex]r = \frac{1.3 \times 10^{-17}}{(4.1875 \times 10^{6}) \times 4 \pi \times (8.85 \times 10^{-12})}[/tex]
[tex]r = 2.79 \times 10^{-14}m[/tex]
*problem solved* ;)
At last :smile:
ehild
Related to Rutherford Scattering Problem.
1. What is the Rutherford Scattering Problem?
The Rutherford Scattering Problem refers to the phenomenon observed by physicist Ernest Rutherford in 1911, where he bombarded thin gold foil with alpha particles and found that some were deflected at large angles. This led to the discovery of the atomic nucleus and the development of the nuclear model of the atom.
2. How does Rutherford Scattering work?
Rutherford Scattering occurs when charged particles, such as alpha particles, approach a target nucleus. The positively charged nucleus repels the incoming particle, causing it to change direction. The amount of deflection depends on the charge and mass of the particle, as well as the distance between the particle and the nucleus.
3. What does Rutherford Scattering tell us about the structure of the atom?
Rutherford Scattering provided evidence for the existence of a small, dense, positively charged nucleus within the atom. This led to the development of the nuclear model of the atom, where the majority of the atom's mass is concentrated in the nucleus and electrons orbit around it.
4. How is Rutherford Scattering used in modern science?
Rutherford Scattering is still used in modern science to study the properties of atomic nuclei and to probe the structure of matter. It is also used in fields such as particle physics and nuclear medicine.
5. Are there any limitations to Rutherford Scattering?
While Rutherford Scattering is a powerful tool for understanding the structure of the atom, it does have limitations. It only applies to particles with a small size compared to the target nucleus, and it does not take into account the effects of quantum mechanics. Additionally, it cannot be used for elements with a high atomic number, as the strong nuclear force overpowers the repulsive force between the nucleus and incoming particles.
  • STEM Educators and Teaching
