Rydberg constant for hydrogen atom and Balmer series
The Rydberg constant remains constant as it is derived from fundamental constants. Discrepancies in measurements related to the hydrogen atom and the Balmer series may arise from the limitations of the Bohr model, which is an approximation that neglects certain effects like fine structure. Additionally, the accuracy of experimental measurements can also contribute to these discrepancies. Understanding these factors is crucial for accurate analysis in atomic physics. The discussion emphasizes the importance of refining models and measurement techniques to enhance precision.
sss1
Does the Rydberg constant change for different Balmer series lines? Like H_α, H_β, etc. according to the formula, it shouldn’t right, it should only change with the amount of electrons and nucleons? I googled some data and I put them into the formula 1/lambda=R(1/n_f^2-1/n_i^2) and tried for several wavelengths for hydrogen (n_f=2), I ended up with pretty close values but with minor differences. I was wondering if this is due to the accuracy of the instruments measuring the wavelength? Or is it meant to differ for different Balmer series lines?
The Rydberg constant is a combination of fundamental constants and so it does not change. The discrepancies you are seeing are probably due to the fact that the Bohr model is only an approximate model and ignores some effects, such as fine structure. Or it could also be due to the accuracy of the measurements, as you said.
Alright, thanks!
  • · Replies 0 ·
  • · Replies 18 ·
