S^2 union a line connecting the north and south pole
In summary, the fundamental group of S^2 union a line connecting the north and south pole is $\mathbb{Z}$, which can be shown by considering the universal cover of an infinite string of spheres like beads on a long string. The group of deck transformations of this universal covering space is isomorphic to the fundamental group, thus proving that the fundamental group is indeed $\mathbb{Z}$. Another approach using the Seifert Van Kampen Theorem can also be used, by considering the two subsets "left of the sphere with the string" and "right of the sphere with the string" and their amalgamation, which identifies the two generators and yields the integers. However, the universal cover provides a more straightforward explanation for
mathsq
I have been trying to determine the fundamental group of S^2 union a line connecting the north and south pole by using the Seifert Van Kampen Theorem. But every time I try and pick my two subsets U and V they are either not open or not arcwise connected or their intersection isn't particularly nice.
My guess is that the fundamental group should be $\mathbb{Z}$, but other than my intuition, I can't seem to find a way to show this.
look at the universal cover, an infinite string of spheres like beads on a long string.
Thanks! So, I look at the group of deck transformations of the universal covering space (the string of beads), which I believe is Z. Then since the group of deck transformations of the universal covering space is isomorphic to the fundamental group, we are done.
Just for concreteness, what is the reason that the universal cover is this string of beads?
If you wanted to use Van Kampen, couldn't you take the "left of the sphere with the string" along with the "right of the sphere with the string"? Each piece will be homotopic to a circle and their overlap will be homotopic to a figure 8. It seems that the amalgamation will identify the two generators and you indeed get the integers, which is the "obvious" answer.
Oh, I was thinking of your bead incorrectly, I see why it is the universal cover, never mind!
well you are right i ignored the question. but the cover makes it obvious the group is Z. (i think?)
No, your answer was nice, much nicer than using Van Kampen- I was just noting that it isn't too hard to use Van Kampen if that's what the OP wanted to do.
I've just thought again about your answer. Do I have this right- in your bead, I imagine your sphere (and interval) being cut in halves along the equator, and then the interval is made to point out in the opposite direction. You then glue these all back together in the obvious way. It will have trivial fundamental group since it is homotopic to a wedge of spheres and the covering map sends a point to where it came from in the above construction.
The set of deck transformations is Z, because it just matters where you send some particular sphere (I was worried about "flipping" everything being a self-homeomorphism- but thinking about it, this won't be a deck transformation).
Related to S^2 union a line connecting the north and south pole
What is S^2 union a line connecting the north and south pole?
S^2 union a line connecting the north and south pole is a mathematical concept that combines a sphere (S^2) with a line connecting the north and south pole. This creates a shape that is topologically equivalent to a disc.
What is the purpose of S^2 union a line connecting the north and south pole?
The purpose of S^2 union a line connecting the north and south pole is to study the properties of a disc in a more abstract and general way. It allows for the exploration of geometric and topological concepts in a simplified setting.
How is S^2 union a line connecting the north and south pole different from a regular sphere?
S^2 union a line connecting the north and south pole differs from a regular sphere in that it includes a line connecting the north and south pole, which creates a boundary. This boundary allows for the disc-like properties of the shape to be studied.
What are some real-life applications of S^2 union a line connecting the north and south pole?
S^2 union a line connecting the north and south pole has applications in various fields, such as physics, computer graphics, and topology. It can be used to model shapes and spaces in a simplified way, which can aid in understanding complex systems and phenomena.
Are there any other shapes or objects similar to S^2 union a line connecting the north and south pole?
Yes, there are other shapes and objects that are similar to S^2 union a line connecting the north and south pole, such as a cylinder and a torus. These shapes also have boundaries and allow for the study of disc-like properties in a more abstract setting.
  • Topology and Analysis
  • Math Proof Training and Practice
