정은's question at Yahoo Answers regarding depth of water in trough when half full
In summary, to find the depth of water in a trough when it is half-full, one needs to find the width of the trough at the water line as a function of the depth of the water, use the slope of the linear function, and find the point-slope formula.
MarkFL
MHB
13,288
Here is the question:
Integration using trapezium rule?
The diagram shows the cross section of a water-trough. One side is vertical and the other side slopes. Calculate the depth of water in the trough when it is exactly half-full. (Hint: this means the areas of two trapezia must be equal.)
https://plus.google.com/u/0/118370402069852386878/posts/Ei4LooTa5ze
Above link is shows the diagram of this question.
The answer to this question= 27.19cm
Please explain to me how to get this answer.
I have posted a link there to this topic so the OP can see my work.
Mathematics news on Phys.org
Hello 정은,
This problem does not require integration, or the trapezium rule to approximate a definite integral. While it could be used, it is simpler to just use the given hint.
To compute the areas of the trapezia in the cross-section of the trough above and below the water line, we need to know the width of the trough at the water line as a function of the depth of the water, which we are calling . All linear measures are in cm.
We know this width increases linearly, and we know two points of the form :
and
and so the slope of the linear function is:
Thus, using the slope, and the first point in the point-slope formula, we get:
Now, using the formula for the area of a trapezium:
We find the area of the trapezium below the water line is:
We find the area of the trapezium above the water line is:
Equating the two areas, we have:
Multiplying through by we get:
Distributing and arranging in standard quadratic form, we obtain:
Application of the quadratic formula, and discarding the negative root, there results:
Suppose we wish to generalize a bit, and let the width of the trapezoidal cross-section of a trough at the base and top be and respectively, where . The depth of the trough we can call , and we will, as before, let be the depth when the trough is full, where .
To find the width of the trough at , we note we have the points:
and so the slope of the linear width function is:
and the point-slope formula gives us:
Now, in order for the trough to be full, we require:
Multiplying through by , and arranging in standard quadratic form in , we obtain:
Applying the quadratic formula, and discarding the negative root, we find:
FAQ: 정은's question at Yahoo Answers regarding depth of water in trough when half full
What is the formula for calculating the depth of water in a trough when it is half full?
The formula for calculating the depth of water in a trough when it is half full is: depth = (volume / length) / width. This formula assumes that the trough has a rectangular shape.
How do you determine the volume of the trough?
To determine the volume of the trough, you need to measure the length, width, and depth of the trough. Then, use the formula: volume = length x width x depth. If the trough has a different shape, such as a triangular or circular shape, you will need to use the appropriate formula for calculating volume.
Can you provide an example of how to calculate the depth of water in a trough when it is half full?
For example, if the trough has a length of 2 meters, a width of 1 meter, and a volume of 4 cubic meters, the depth would be calculated as follows: depth = (4 cubic meters / 2 meters) / 1 meter = 2 meters. Therefore, the depth of water in the trough when it is half full would be 2 meters.
Are there any other factors that may affect the depth of water in a trough when it is half full?
Yes, there are other factors that may affect the depth of water in a trough when it is half full. These include the shape of the trough, the material it is made of, and any obstructions or irregularities in the trough that may affect the water level.
How can I ensure accuracy when measuring the depth of water in a trough?
To ensure accuracy, it is important to use precise measurements when calculating the volume and dimensions of the trough. Additionally, using a level to make sure the trough is evenly filled can help avoid any discrepancies in the depth measurement. It is also recommended to take multiple measurements and calculate an average for more accurate results.
