MHB S10.03.25 Write complex number in rectangular form
The discussion focuses on converting the complex number \( z = 4\left[\cos\frac{7\pi}{4} + i\sin \frac{7\pi}{4}\right] \) into rectangular form. The cosine and sine values from the unit circle are identified, leading to the calculation of the rectangular form as \( 2\sqrt{2} - 2\sqrt{2}i \). There is confusion regarding the use of the imaginary unit \( i \) and its role in the sine function's coefficient. The initial book answer was incorrect, and the importance of verifying inputs in computational tools like Wolfram Alpha is emphasized. The correct rectangular form is confirmed as \( 2\sqrt{2} - 2\sqrt{2}i \).
karush
MHB
$\tiny{s10.03.25}$
$\textsf{Write complex number in rectangular form}$
\begin{align*}\displaystyle
z&=4\left[\cos\frac{7\pi}{4} + i\sin \frac{7\pi}{4} \right]\\
\end{align*}
$\textit{ok from the unit circle: $\displaystyle\cos{\left(\frac{7\pi}{4}\right)}=\frac{\sqrt{2}}{2}$}\\$
$\textit{and it appears distributing in 4 gives the answer}\\$
$\textit{but isn't the purpose of this to deal with powers?}\\$
$\textit{book answer} =2\sqrt{2}+2\sqrt{2}i$
$\textit{however $W|A$ returned $-1$ ??}$
Mathematics news on Phys.org
$$\sin\left(\frac{7\pi}{4}\right)=-\frac{\sqrt2}{2}$$
The correct answer is $2\sqrt2-2\sqrt2i$.
Double-check what you entered into W|A.
ok the $i$ confuses me:confused:
It is merely the coefficient of the sine function. Why are you confused? Because $i=\sqrt{-1}$?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
