MHB S3 Group Symmetry: $(xy)^2 \ne x^2y^2$ Example
  • Thread starter Thread starter Guest2
    Group Symmetric
In the discussion on S3 group symmetry, an example is provided to demonstrate that for elements x and y in S3, the equation (xy)^2 ≠ x^2y^2 holds. The mappings φ and ψ are defined, with φ swapping x1 and x2 while keeping x3 fixed, and ψ cycling x1 to x2, x2 to x3, and x3 to x1. It is shown that (φψ)^2 results in a different mapping than φ^2ψ^2, confirming the inequality. The importance of using cycle notation for clarity in such problems is also emphasized. This example effectively illustrates the non-commutative nature of the group S3.
Guest2
Problem: In $S_3$ give an example of two elements $x$ and $y$ such that $(xy)^2 \ne x^2y^2$.
Attempt: Consider the mapping $\phi: x_1 \mapsto x_2, x_2 \mapsto x_1, x_3 \mapsto x_3$ and the mapping $\psi: x_1 \mapsto x_2, x_2 \mapsto x_3, x_3 \mapsto x_1$. We have that the elements $\phi, \psi \in S_3$. We also have $x_1 (\phi \psi)^2 = x_1\phi \psi \phi \psi = x_3 \phi \psi = x_1.$ We also have that $\phi^2 = e$ and thus $ x_1 \phi^2 \psi^2 = x_1 \psi^2 = x_2 \psi = x_3$. Therefore $(\phi \psi)^2 \ne \phi^2 \psi^2$. Hence it's enough to take $x = \phi$ and $y = \psi$.
Is the above any good?
That looks good, although you should make it explicit that $\phi\psi$ is the mapping:
$x_1 \mapsto x_3$
$x_2 \mapsto x_2$
$x_3 \mapsto x_1$.
When you learn cycle notation, these kinds of problems will be much easier to write about.
(and yes, to show that two mappings $f,g:A \to B$ are unequal, it is enough to exhibit a single $a \in A$ such that $(a)f \neq (a)g$...in this case we have $A = B = \{x_1,x_2,x_3\}$).
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 0 ·
  • · Replies 21 ·
  • · Replies 26 ·
  • · Replies 34 ·
  • · Replies 52 ·
