MHB S4.6r.11 Solid of revolution about the y axis
The discussion focuses on finding the volume of a solid of revolution about the y-axis using the washer method. The outer radius is identified as R = a + h, while the inner radius is expressed in terms of y. The volume element is given by dV = π((a + h)² - (y² + a²)) dy, and the limits of integration are determined by the intersections of the line x = a + h and the curve x² - y² = a². The final volume expression incorporates these limits and simplifies to V = 2π∫₀^{√(h(2a + h))} ((a + h)² - (y² + a²)) dy. The discussion emphasizes the importance of correctly identifying the radii and limits for accurate volume calculation.
karush
MHB
Given
$$x_1^2 -y^2=a^2, \ \ x_2=a+h$$
Or
$$x_1=\sqrt{a^2+y^2}$$
Find
Volume about the $y$-axis
So...
$$\pi\int_{a}^{h} \left(x_2^2-x_1^2\right)\,dy$$
Actually I am clueless?!
Is that how the problem is given in your textbook?
Well, that's clear as floodwaters, my friend! (Nod)
Can you humor me for a little bit here and give the problem exactly as stated? (Mmm)
Okay, now we're in bidness...and your inclination to use the washer method is a good one...but you know, when I was a student, I like to work problems like these more than one way (we could use the shell method as well) both for the prctice and as a means of checking my result.
Let's begin with the washer method. The value of an element (a washer) is given by:
$$dV=\pi(R^2-r^2)$$
where $R$ is the outer radius and $r$ is the inner radius. Can you identify these two radii?
I assume $R$ is the major radius or $x_2$
And $r$ is the minor radius or $x_1$
No I'm not sure?
This thing has $a$ and $h$ in it😠😠
No I'm not sure?
First, it is often very helpful to draw a sketch:
Now, we see the outer radius is:
$$R=a+h$$
and the inner radius is:
$$r=x$$
And so we have:
$$dV=\pi\left((a+h)^2-x^2\right)\,dy$$ (I forgot to include the thickness of the washer before)
Now, the expression $a+h$ is a constant, so we don't need to do anything with that. However, since we will be integrating along the $y$-axis, we need to express $x^2$ in terms of $y$...(Thinking)
Sorry,I got lost in this,
The bk ans is $$\frac{4}{3}(2ah+h^2)^{3/2}$$
However $$x=\sqrt{y}$$
Since we are given:
$$x^2-y^2=a^2$$
we then know:
$$x^2=y^2+a^2$$
Hence:
$$dV=\pi\left((a+h)^2-\left(y^2+a^2\right)\right)\,dy$$
Now, you need to find the limits of integration, which will be the $y$-coordinates of the intersections of the line:
$$x=a+h$$
and the curve:
$$x^2-y^2=a^2$$
Can you proceed? :)
$$dV=\pi\left((a+h)^2-\left(y^2+a^2\right)\right)\,dy$$dV
$$\pi\int_{-a}^{a}\left((a+h)^2-\left(y^2+a^2\right)\right) \,dy$$
Don't know what $h$ is?
I get different limits of integration. we have:
$$y^2=x^2-a^2$$
Now, substituting $c=a+h$, we obtain:
$$y=\pm\sqrt{h(2a+h)}$$
And then using the even function rule, we may write:
$$V=2\pi\int_0^{\sqrt{h(2a+h)}} \left((a+h)^2-\left(y^2+a^2\right)\right)\,dy$$
$h$ is just a constant, that is greater than the constant $a$. :)
  • · Replies 16 ·
