MHB S5.t.5 Find domain and asymptotes.
  • Thread starter Thread starter karush
    Domain
The discussion focuses on finding the domain and asymptotes of the function g(x) = (2x^2 - 14x + 24) / (x^2 + 6x - 40). The domain is all real numbers except x = 4 and x = -10, expressed as x ∈ (-∞, -10) ∪ (-10, 4) ∪ (4, ∞). The horizontal asymptote is determined to be y = 2, while the vertical asymptote occurs at x = -10. There is also a mention of a removable discontinuity at x = 4, although it was not explicitly requested. The discussion touches on the conditions for oblique asymptotes but does not reach a conclusion on their presence.
karush
MHB
$\tiny{s5.t.5 Kiaser HS}$
Find domain asymptotes.
$g(x)=\dfrac{2x^2-14x+24}{x^2+6x-40}$
$\begin{array}{rll}
\textsf{factor}&=\dfrac{2(x-3)(x-4)}{(x-4)(x+10)}
=\dfrac{2(x-3)\cancel{(x-4)}}{\cancel{(x-4)}(x+10)}
=\dfrac{2(x-3)}{x+10}\\
\textsf{Domain} & -\infty<-10<\infty\\
HA \quad y&=3 \\
VA \quad x&=-10
\end{array}$
I think there is an oblique asymptote but ??
Also the OP has a hole at $x=4$ but they didn't ask for it ?
btw how come tab does not work here?:confused:
Mathematics news on Phys.org
what does $-\infty < -10 < \infty$ mean?
the domain is all reals except x = 4 and x = -10 …
$x \in (-\infty, -10) \cup (-10,4) \cup (4, \infty)$
horizontal asymptote is y = 2
oblique asymptotes occur when the degree of the numerator is one greater than the degree of the denominator
yes, the original rational function has a removable discontinuity at x = 4
how do you get y=2 for HA
$\displaystyle \lim_{x \to \pm \infty} \dfrac{2x^2-14x+24}{x^2+6x-40}$
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
