MHB -s6.6 solve exponential eq 3^x-14\cdot 3^{-x}=5
  • Thread starter Thread starter karush
    Exponential
The exponential equation 3^x - 14·3^(-x) = 5 can be rewritten as 3^x + 14/3^x = 5, leading to the quadratic equation 3^(2x) - 5·3^x - 14 = 0. Factoring gives (3^x - 7)(3^x + 2) = 0, resulting in the valid solution 3^x = 7. The solution for x is x = log_3(7) = log(7)/log(3) ≈ 1.7712. The discussion also highlights alternative approaches to solving the equation and clarifies the factoring process. The final solution is confirmed to be correct.
karush
MHB
\tiny{s464\\6.6}
solve the exponential equation. $3^x-14\cdot 3^{-x}=5$
Rewrite $\quad 3^x+\dfrac{14}{3^x}=5$
$\times$ $\quad 3^x \quad 3^{2x}+14=5\cdot 3^x$
quadratic $\quad 3^{2x}-5\cdot3^x-14 =0$
Factor $\quad (3^x-7)(3^x+2)=0$
Discard $\quad 3^x =7$
hence $\quad x=\log_3(7)=\dfrac{\log 7}{\log 3}\approx 1.7712$
ok i think it is correct
probably better to use () rather than $\cdot$
didn't know is factoring out the 3 was possible
Mathematics news on Phys.org
That's good. I would have done it just slightly differently. I would have let y= 3^x so that the equation became y- 14/y= 5. multiplying by y gives y^2- 5y- 14= 0. That, of course, factors as (y- 7)(y+ 2)= 0 so that y= 7 or y= -2. But 3^x cannot be negative so the only solution is 3^x= 7, x log(3)= log(7) and x= log(7)/log(3) as you had.
(I don't see where you "factored out" a 3.)
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
