S6.803.12.5.9 are lines parallel?
In summary, parallel lines are two lines that never intersect and are always the same distance apart. They can be identified by having the same slope and follow the equation y = mx + b. Parallel lines can never intersect and understanding them is important in geometry for determining relationships between lines and solving problems involving angles and geometric proofs.
karush
MHB
3,269
$\tiny{s6.803.12.5.9}$
$\textsf{Is the line through $( -4,-6,1)$
and $(-2,0,-3)$ parallel}\\$
$\textsf{to the line through $( 10,18,4)$
and $(5,3,14)$? }\\$
$\textit{presume, convert to vectors first?}$
\begin{align}
\displaystyle
\end{align}
A vector parallel to the first line is:
\(\displaystyle \langle -4-(-2),-6-0,1-(-3)\rangle=\langle -2,-6,4\rangle=-2\langle 1,3,-2\rangle\)
A vector parallel to the second line is:
\(\displaystyle \langle 10-5,18-3,4-14\rangle=\langle 5,15,-10\rangle=5\langle 1,3,-2\rangle\)
So, yes, the two given lines are parallel. :D
FAQ: S6.803.12.5.9 are lines parallel?
What is the definition of parallel lines?
Parallel lines are two lines that never intersect and are always the same distance apart.
How can you tell if two lines are parallel?
You can tell if two lines are parallel by checking if they have the same slope. If the slopes are equal, then the lines are parallel.
What is the equation for parallel lines?
The equation for parallel lines is y = mx + b, where m is the slope and b is the y-intercept. If two lines have the same slope, then they have the same equation and are parallel.
Can parallel lines intersect at any point?
No, parallel lines can never intersect. If they did, then they would no longer be parallel lines.
What is the importance of understanding parallel lines in geometry?
Understanding parallel lines is important in geometry because it helps us determine the relationship between different lines and shapes. It also allows us to solve problems involving angles and geometric proofs.
