A Saha Equation In Plasma for Muons
The discussion centers on the application of the Saha equation to muon-catalyzed fusion in a dense plasma. It explores the formation of muonic atoms when muons are introduced into a plasma where pressure ionization has freed all electrons. The key question is whether a modified version of the Saha equation can be used, substituting parameters related to electrons with those relevant to muons, given that muons are more massive and the density of muons is lower than that of ions. The feasibility of this approach hinges on treating both ions and muons classically. Ultimately, the discussion seeks to clarify the conditions under which this adaptation of the Saha equation is valid.
STZweig
TL;DR Summary
If I have a fully ionized hydrogen plasma and I introduce some muons into the plasma, does the Saha equation apply to the muons.
I am currently working on the determining the viability of muon-catalyzed fusion in a dense but tepid plasma and the first question pertains to the formation of muonic atoms once muons are injected into the plasma. Suppose the plasma is sufficiently dense such that pressure ionization ensures that all of the electrons are free. But since muons are much more massive than electrons, they can still form bound states. Assume the density of muons is less then that of the ions and that the ions and muons can be treated classically, can a version of the Saha equation where every parameter that would pertain to electrons is changed to pertain to the muons be applied?
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
