Sakurai page 54: Is this a Taylor expansion?
The discussion centers on whether the expression from Sakurai's text can be considered a Taylor expansion of a Bra. It clarifies that the term being manipulated is actually the position space wavefunction, not the Bra itself. The participants note that the wavefunction typically allows for a well-defined Taylor expansion, which simplifies the understanding of the expression. Questions arise about the treatment of complex conjugates in the context of the expansion, leading to the conclusion that the real nature of position variables may explain the absence of complex conjugates. The conversation emphasizes the relationship between Kets, Bras, and their corresponding wavefunctions in quantum mechanics.
omoplata
From page 54 of 'Modern Quantum Mechanics, revised edition" by J. J. Sakurai.
Obtaining equation (1.7.15),<br /> \begin{eqnarray}<br /> \left(1- \frac{ip\Delta x&#039;}{\hbar} \right) \mid \alpha \rangle &amp; = &amp; \int dx&#039; \mathcal{T} ( \Delta x&#039; ) \mid x&#039; \rangle \langle x&#039; \mid \alpha \rangle \\<br /> &amp; = &amp; \int dx&#039; \mid x&#039; + \Delta x&#039; \rangle \langle x&#039; \mid \alpha \rangle \\<br /> &amp; = &amp; \int dx&#039; \mid x&#039; \rangle \langle x&#039; - \Delta x&#039; \mid \alpha \rangle \\<br /> &amp; = &amp; \int dx&#039; \mid x&#039; \rangle \left( \langle x&#039; \mid \alpha \rangle - \Delta x&#039; \frac{\partial}{\partial x&#039;} \langle x&#039; \mid \alpha \rangle \right)<br /> \end{eqnarray}<br />How does the last line come about? Is it a Taylor expansion?
It looks like a Taylor expansion, indeed.
Can a Bra be Taylor expanded like this? I guess it is like Taylor expanding a vector? I know that Kets are elements of a vector space, and Bras are the elements of the corresponding dual space.
If the result is differentiable in some variable, and behaves nicely (insert strict mathematical formulation here): why not?
It's not quite a bra that is being expanded here. ##\langle x | \alpha \rangle = \psi_\alpha(x)## is the position space wavefunction corresponding to the state ##|\alpha\rangle##. What appears in the expression above is ##\psi_\alpha(x'-\Delta x')##, which is usually a nice enough function to have a well-defined Taylor expansion. It may be the case that you can also manipulate the states themselves in some way, but I expect that if the procedure is to be well-defined, there must be a way to express the same manipulations in terms of appropriate wavefunctions.
Oh, OK. That's easier to understand.
I was about to ask since all operators A should be A^{\dagger} and all constants c should be c^* in the Bra space, why is it,<br /> \int dx&#039; \mid x&#039; \rangle \langle x&#039; - \Delta x&#039; \mid \alpha \rangle = \int dx&#039; \mid x&#039; \rangle \left( \langle x&#039; \mid \alpha \rangle - \Delta x&#039; \frac{\partial}{\partial x&#039;} \langle x&#039; \mid \alpha \rangle \right)<br /> and not, <br /> \int dx&#039; \mid x&#039; \rangle \langle x&#039; - \Delta x&#039; \mid \alpha \rangle = \int dx&#039; \mid x&#039; \rangle \left( \langle x&#039; \mid \alpha \rangle - \Delta (x&#039;)^* {\frac{\partial}{\partial x&#039;}}^{\dagger} \langle x&#039; \mid \alpha \rangle \right)<br />?
I mean, I understand that what's given in the book easily follows if you think of it as a wavefunction. But if you think of it as Taylor expanding a Bra, why don't the complex and hermitian conjugates don't come into play?
Because position is a real variable?
  • · Replies 29 ·
