Sample Test | Component Lifetime
In summary, Dave told me that I could use the gamma distribution to model the time to failure of a set of components, and that the mean and standard deviation of the gamma distribution would be 0.12 and 0.29, respectively. He also explained that if my excel sheet is giving me different numbers for the PDF and CDF (like 3.8E-14 and 7.6E-16), then I need to use the 1/\beta\ parameter.
Joris Kievits
Hi,
I'm currently working on a project for which I have to determine the Life-Time of a certain mechanical component within a certain confidence interval. By sampling a small number (let's say n = 10) of these components and measuring the number of hours until failure, I want to determine this confidence interval.
I currently have one main question:
How can I determine the 'trueness' of the mean of these 10 components after determining the standard deviation and mean from the test? (If I were to measure just 2 times but the deviation is extremely small then I would still have a huge uncertainty to my mean right?)
I'd greatly appreciate it if someone could help me figure this out!
I tend to like Bayesian statistical methods, so that is what I would use here. If you are modeling your failure time as exponential, meaning that you have a constant hazard rate ##\lambda## then a conjugate prior/posterior for ##\lambda## is the Gamma distribution with ##\alpha## equal to the number of observations and ##\beta## equal to the sum of the failure times for previous observations
Likes Joris Kievits
Hi Dave,
Thanks for responding so quickly! Could you please elaborate a bit more, maybe using an example? I'm not familiar with Bayesian methods and I'd hate to misinterpret your answer..
Thanks either way!
Sure. Suppose you model a set of components whose true constant failure rate is ##\lambda## = 0.01/day meaning that the mean time to failure is 100 days. Since we assume a constant failure rate (no burn-in or wear) we can use an exponential distribution to model the days to failure of any given component. So suppose you take 10 such components and you use them until they all fail, then you might have data that looks like this:
{98.0327, 364.585, 135.671, 69.0766, 113.28, 15.9393, 64.3092, 118.104, 15.5044, 71.9093}
So if you don't know ##\lambda## then the Bayesian approach would be to treat it as a random variable, take this data, and compute a probability distribution function for P(##\lambda## | data). It turns out that the best PDF to use for ##\lambda## is the gamma distribution (see https://en.wikipedia.org/wiki/Exponential_distribution#Bayesian_inference ). The gamma distribution is a pretty common distribution, but not as common as the normal distribution, so you may not have worked with it before. It has two parameters ##\alpha## and ##\beta##, and the data allows us to set ##\alpha## and ##\beta## so that we get ##\alpha = n = 10## and ##\beta = n \bar{x} = \Sigma x = 1066.41##. So then we can plot this PDF if you like, or you can summarize it with mean ##\alpha/\beta = 0.0094## and standard deviation ##\sqrt{\alpha}/\beta=0.0029##. You can construct 95% credible intervals and so forth as well.
Hi Dave,
I'm trying to implement this into an Excel file, so that I can update it while testing. However, I seem to get extremely low values for the Gamma distribution. I'm also not able to totally wrap my head around the prior/posterior story so that might be what I've done wrong. Is there any way that you could show me the exact calculations for a data set of for example: { 8.4, 8.9, 7.3, 9.0, 6.9 } hours of operation until failure?
I'd understand if it would be too much trouble...
Thanks for the help either way!
So, for that data ##\alpha = n = 5## and ##\beta = \Sigma x = 40.5##. So the mean failure rate is ##\alpha/\beta = 0.12## failures per hour. That makes sense because they typically failed in less than 10 hours per failure, so that is more than 0.1 failures per hour.
If you are evaluating the PDF, then the PDF of this gamma distribution is equal to 7.9 at 0.1. The CDF is equal to 0.38 at the same 0.1 value. If you find that your excel sheet is giving you far different numbers (like 3.8E-14 and 7.6E-16 for the PDF and CDF) then try using ##1/\beta## instead of ##\beta##. Unfortunately, some software packages use ##\beta## and some use ##1/\beta## and often there is no way to know which is used without just trying it both ways and seeing which makes sense.
Hi Dave,
It was indeed the case that I needed to use ##1/\beta##! Thanks for the clear explanation! However, I have some questions with respect to Bayes and the "trueness" of this PDF. Is this accounted for in the Gamma distribution? Or does the value, that I get from the Gamma distribution, still have to be modified using some "trueness error"? And you told me that I could model the time to failure as an exponential distribution, is this the Gamma distribution or should I implement the mean of the Gamma distribution, with an amount of uncertainty, into another exponential distribution? Thanks for all the help so far and I'm sorry for going on and on...
Joris Kievits said:
Hi Dave,
I am Dale, not Dave
I don’t know what you mean by “trueness”.
So the idea is that we are modeling the time to failure as an exponential distribution.
The exponential distribution has a single parameter, ##\lambda##, which is the failure rate. We don’t know that failure rate, so we treat it as a random variable too, in this case as a gamma distributed variable. The gamma distribution has two parameters, ##\alpha## and ##\beta##, which are determined from the data.
So if we are doing a Monte Carlo simulation of failure times you would first simulate a failure rate with the gamma distribution and then you would use that rate as the parameter to simulate an exponential distribution to get the failure time. Then to get your next Monte Carlo draw you would simulate a new gamma and a new exponential. This process accounts for both the inherent randomness of failure times as well as the lack of knowledge of the exact failure rate.
Hi Dale (my apologies for mixing up your name),
By "trueness" I mean the amount of uncertainty associated with a small number of tests. If I were to perform 3 tests but the values would all be very close to each other I'd have a small standard deviation but I would expect that there is more uncertainty to the mean than just this small standard deviation... do you know if this is true?
About the exponential distribution, what value from the Gamma distribution should I use as lambda? I've attached a two plots, one of the measurements and one of the Gamma distribution (for n=10) I got out of Excel. Does it look correct to you?
This is automatically accounted for in the Bayesian method. There ##\alpha=n## and a small ##\alpha## gives a broad distribution for the failure rate.
All of them!
If you are doing a Monte Carlo simulation then you start with a draw from the gamma distribution and only then make a draw from the exponential distribution. If you are doing something else then you would marginalize over ##\lambda##
I am not on my main computer, but visually yes it looks good.
FAQ: Sample Test | Component Lifetime
What is a "Sample Test" in terms of component lifetime?
A sample test is a type of experiment or trial that is conducted on a component to determine its expected lifetime. It involves subjecting the component to various conditions and measuring its performance over time to estimate its durability and longevity.
Why is it important to conduct sample tests for component lifetime?
Sample tests are crucial for predicting the lifespan of a component and ensuring its reliability. By conducting these tests, scientists and engineers can identify any potential weaknesses or defects in the component, make necessary improvements, and ensure that it meets the expected performance standards.
What factors are typically considered in a sample test for component lifetime?
There are several factors that are usually taken into account during a sample test for component lifetime. These include environmental conditions such as temperature, humidity, and exposure to various substances, as well as mechanical factors like stress, strain, and vibrations.
How long does a typical sample test for component lifetime last?
The duration of a sample test for component lifetime can vary depending on the type of component and the specific conditions being tested. In some cases, it may last for a few hours or days, while in others, it may take several months or even years to complete.
What are some common methods used in sample tests for component lifetime?
There are various techniques and methods that can be used in sample tests for component lifetime. These include accelerated life testing, where the component is subjected to extreme conditions to simulate long-term use, as well as non-destructive testing, which uses various tools and instruments to assess the component's performance without causing damage.
