Sand Pile Growth Rate: 10 Seconds After Falling
In summary, we have shown that after 10 seconds of sand falling at a rate of 9m^3 per minute, the rate at which the radius of the base of the pile is increasing is 3^{\frac{1}{2}}(\frac{4}{\pi})^{\frac{1}{3}}m per minute. This was achieved by finding the relationship between the height and radius of the pile using the angle of repose, differentiating the formula for volume with respect to time, and using given information to solve for the rate of change of the radius at a specific time.
jiasyuen
25
Sand falls on to horizontal ground at the rate of per minute and forms a heap in the shape of a right circular cone with vertical angle . Show that 10 seconds after the sand begins to fall, the rate at which the radius of the base of the pile is increasing is per minute.
First, what is the volume of a right circular cone?
jiasyuen said:
Correct, we have:
Now, given that the angle of repose is , can you express the height as a function of ?
I've no idea. Can you show me? Thanks
Am I correct? How to proceed?
You are correct, although I would have written:
So, substitute this into your formula for the volume of the cone so that you have the volume as a function of only. The reason we want only is because we are asked to find .
Then differentiate both sides of the formula with respect to time ...what do you get?
How to proceed from here? How to 'differentiate both sides of the formula with respect to time t' ?
On the right side, you will need to use the power and chain rules...what do you get?
Do you mean this ?
jiasyuen said:
Do you mean this ?
Close, but you have omitted one crucial piece, resulting from the application of the chain rule...you should have:
Now, in the problem statement, you are given information regarding ...that is, how fast the volume of the pile of sand is changing with respect to time...can you use this to make a substitution?
How to proceed?
Okay, you need to know the value of when ...any ideas on how you can find this?
I've no idea.
If the volume of the pile is increasing at a rate of per second, what is the volume after 10 seconds? Can you use the relationship you have between and to then find ?
I'm stupid. Stuck at here :(
The volume of the pile can be written as:
Hence:
And so we must have:
So, solve that for , and then plug the result for into your value of which is a function of . After you simplify, you should get the desired result. :D
. How to simplify it into ?
We neglected the fact that the time rate of change of the volume of the pile is given in meters cubed per minute, and we are to find the rate of change after 10 seconds, or 1/6 of a minute, and so we want:
Hence:
Now see what you get. :D
Teach me how to simplify.
FAQ: Sand Pile Growth Rate: 10 Seconds After Falling
What is "Sand Pile Growth Rate: 10 Seconds After Falling"?
"Sand Pile Growth Rate: 10 Seconds After Falling" is a scientific experiment that measures the rate at which a pile of sand grows after it has been disturbed and allowed to settle for 10 seconds.
How is the "Sand Pile Growth Rate" experiment conducted?
The "Sand Pile Growth Rate" experiment involves creating a pile of sand and then gently tapping the container to disturb the sand. The pile is then allowed to settle for 10 seconds before measuring its growth rate.
What factors can affect the growth rate of the sand pile?
The growth rate of the sand pile can be affected by the size and shape of the container, the type of sand used, the force and intensity of the disturbance, and the temperature and humidity of the surrounding environment.
What can the results of the "Sand Pile Growth Rate" experiment tell us?
The results of the "Sand Pile Growth Rate" experiment can provide insights into the behavior of granular materials, such as sand, and how they respond to disturbances. It can also help us understand how natural phenomena, such as landslides or avalanches, occur.
How is the data from the experiment analyzed?
The data from the "Sand Pile Growth Rate" experiment is typically analyzed using mathematical models and statistical methods to determine the growth rate and patterns of the sand pile. This data can also be compared to previous experiments or used to make predictions for future experiments.
