MHB Saqifriends's Question from Math Help Forum
  • Thread starter Thread starter Sudharaka
    Forum
To find a standard basis vector that can be added to the set {v1, v2} to create a basis for R3, the determinants of matrices formed with standard basis vectors and the given vectors are calculated. The determinants for the vectors (1,0,0) and (0,1,0) show they are linearly independent from {v1, v2}, while the determinant for (0,0,1) is zero, indicating linear dependence. Both sets { (1,0,0), v1, v2 } and { (0,1,0), v1, v2 } span R3, confirming they are valid bases. Thus, either (1,0,0) or (0,1,0) can be added to the set to form a basis for R3.
Sudharaka
MHB
Title: Find a standard basis vector
saqifriends said:
Find a standard basis vector that can be added to the set {v1, v2} to produce a basis for R3 where;
v1 = (-1, 2, 3), v2 = (1, -2, -2)
Hi saqifriends, :)
We can use the determinants to see which standard basis vectors are linearly independent with the given two vectors.
\[\begin{vmatrix} 1 & 0 & 0\\-1 & 2 & 3\\1 & -2 & -2 \end{vmatrix}\neq 0\]
\[\begin{vmatrix} 0 & 1 & 0\\-1 & 2 & 3\\1 & -2 & -2 \end{vmatrix}\neq 0\]
\[\begin{vmatrix} 0 & 0 & 1\\-1 & 2 & 3\\1 & -2 & -2 \end{vmatrix}=0\]
Therefore, \(\{(1,0,0),\,(-1, 2, 3),\,(1, -2, -2)\}\mbox{ and }\{(0,1,0),\,(-1, 2, 3),\,(1, -2, -2)\}\) are linearly independent sets.
Now we shall show that, \(\{(1,0,0),\,(-1, 2, 3),\,(1, -2, -2)\}\) spans \(\Re^{3}\).
Take any, \((x,y,z)\in\Re^{3}\).
\[(x,y,z)=\alpha(1,0,0)+\beta(-1, 2, 3)+\gamma(1, -2, -2)\]
\[\Rightarrow \alpha=x+\frac{y}{2},\,\beta=z-y,\,\gamma=z-\frac{3\,y}{2}\]
\[\Rightarrow \alpha,\,\beta,\,\gamma\in\Re\]
Therefore, \(\{(1,0,0),\,(-1, 2, 3),\,(1, -2, -2)\}\) spans \(\Re^{3}\).
Similarly it could be shown that, \(\{(0,1,0),\,(-1, 2, 3),\,(1, -2, -2)\}\) spans \(\Re^{3}\).
Hence both \(\{(1,0,0),\,(-1, 2, 3),\,(1, -2, -2)\}\mbox{ and }\{(0,1,0),\,(-1, 2, 3),\,(1, -2, -2)\}\) are bases of \(\Re^{3}\).
Kind Regards,
Sudharaka.
Mathematics news on Phys.org
Hi saqifriends, :)
Kind Regards,
Sudharaka.
Correct! one has to first solve the simultaneous equation:
##x=α-β+ϒ##
##y=2β-2ϒ##
##z=3β-2ϒ##
##x=α-β+ϒ⇒α=x+β-ϒ##
and from
##y=2β-2ϒ##⇒
##\dfrac{y}{2}##=##β-ϒ##
on substituting into
##α=x+β-ϒ##
##α=x+\dfrac{y}{2}## as shown...the other constants can be found in a similar approach (by use of elimination method).
Likes Greg Bernhardt
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
