SAT Math: Greatest Possible Area of Triangle (7, 10)
In summary: So, the maximum area of a triangle with those dimensions is 70. Thanks for the tip!In summary, the greatest possible area of a triangle with one side of length 7 and the another side of length 10 is 35.
DaniNY
What is the greatest possible area of a triangle with one side of length 7 and the another side of length 10?Choices:
A - 17
B - 34
C - 35
D - 70
E - 140
Answer is 35 but how?
Thanks in advance
Mathematics news on Phys.org
consider it to be a right triangle
but how to know that is the greatest area possible?
Hi DaniNY, (Wave)
Welcome to MHB! :)
You can prove this fact using trigonometry and/or calculus but for the SAT I recommend just memorizing this. Some things are worth deriving and some thing are worth memorizing. This one is the latter case in my opinion.
Anyway, once you know that it must be a right triangle how can you find the answer?
if you rotate the side that is the altitude from 90d then the area can only become smaller because the attitude is smaller
Thanks for you help! I am actually teaching an SAT course and I just want to make sure I can explain this as clearly as possible
Ah, ok. :)
Here is an argument for why this is. The general formula for the area of a triangle can be expressed as: $A = ab \sin(C)$, where $a,b$ are two legs of the triangle and $C$ is the angle between them. Let's also say that $a,b$ represent the two shortest legs.
If you examine some possibilities of the $\sin(C)$ term, you'll see that this value is the biggest for $\sin(90 ^{\circ})$. Try some other values of this and you'll get something less than 1. Does that make sense?
Jameson said:
Ah, ok. :)
Ah yes, that does make more sense...I know trig is not required for the SAT and I think many of my students will be confused. I am going to tell them to remember that maximum area occurs in right triangles.
Any ideas on how I can visually show them this concept?
Thanks so much for your help!
Being an ignorant foreigner, I know nothing about SAT requirements. But I imagine that students are meant to know that the area of a triangle is half the base times the vertical height. If you are told that the base is 10 and the sloping height is 7, then the way to maximise the area is to make the vertical height as big as possible, namely equal to the sloping height ... .
FAQ: SAT Math: Greatest Possible Area of Triangle (7, 10)
How do I find the greatest possible area of a triangle with coordinates (7, 10)?
To find the greatest possible area of a triangle with given coordinates, you can use the formula A = 1/2 * base * height. In this case, the base and height will be the side lengths of the triangle. You can use the distance formula to calculate the side lengths, and then plug them into the area formula to find the maximum area.
Is there a specific method or formula to use for finding the greatest possible area of a triangle?
Yes, the formula for finding the area of a triangle is A = 1/2 * base * height. To find the greatest possible area, you will need to calculate the side lengths using the distance formula and then plug them into the area formula.
Can I use any other formulas or techniques to determine the greatest possible area of a triangle?
There are multiple methods and formulas for finding the area of a triangle, such as Heron's formula or using trigonometric functions. However, for a given set of coordinates, the formula A = 1/2 * base * height will give you the maximum area.
How does the placement of the coordinates affect the greatest possible area of a triangle?
The placement of the coordinates can affect the greatest possible area of a triangle as it determines the lengths of the sides of the triangle. For example, if the coordinates are closer together, the sides may be shorter and therefore the maximum area will be smaller compared to coordinates that are further apart.
Are there any limitations to finding the greatest possible area of a triangle with given coordinates?
Yes, there are limitations to finding the greatest possible area of a triangle with given coordinates. The coordinates must form a triangle, meaning that the three points cannot be collinear. Additionally, the coordinates must also be unique and cannot form a degenerate triangle with zero area.
