Satellite dish motor - electromotor characteristics
In summary, the conversation discusses the technical characteristics of electromotors used in satellite dish motors, specifically for 120cm steel satellite dishes. The choice of motor is not as important as the gear train, which should have high torque and low speed. The motor is driven by LNB voltage and a typical satellite receiver coax output cannot supply enough power. The conversation also mentions designing a motor with its own power supply and controller, and suggests looking at high-torque devices like drills or lathes.
etf
179
Hi!
What are technical characteristics of electromotors inside satellite dish motors? Can someone write here some models of these electromotors? Especially I'm interested about motors which carry 120cm steel satellite dishes. I think 120cm steel satellite dish is about 15kg weight. Thanks in advance
I suspect that it largely depends upon the manufacturer. There's no reason to think that they're all the same. Have you checked with any of their websites for specifications?
I didn't see informations I need on manufacturer site. Here is one photo I found on google http://wsidigital.com/SG9120-SG6000%20copy.gif . I was wondering which characteristics electromotor must have since it moves relatively heavy load (about 15kg). I'm not so good in mechanics so I appreciate any help :)
I see. I misinterpreted your question to some extent. The choice of motor isn't really all that important compared to the choice of gear train. Generally, you want one with high torque and low speed, but that can be achieved simply through mechanical means regardless of the source motor if necessary. Over all, I'd recommend looking into one made for a good 1/2" drill or a lathe rather than a wall clock or phonograph. :D
Likes etf
http://wsidigital.com/photogallery/IMG_0668.jpg
The motor is driven by the LNB voltage 13.5 volts vertical, 18.5 volts horizontal polarisation. A typical LNB might use 150mA and the motor 300ma when moving. A typical sat receiver coax output can only supply about 0.5A so the motor can't be very powerful. The picture looks like a stepper motor and gear box to a worm-drive for the disk position shaft.
Likes etf
I want to design motor which would be independent of satellite receiver. It would have it's own power supply and it would be connected with some type of controler which has only two buttons for moving dish on east and west I'm able to design it from electrical point of view but I still don't know precisely which characteristics electromotor should have. Can some of you guys suggest me some model which can move load about 15kg weight?
I already answered that. Look at a drill or lathe or other high-torque device. And as far as I know, the channel selector automatically controls the dish orientation via pre-programming. It's like the "fire-and-forget" type of missile. Switch channels with your remote, and the hardware decides how to get the one that you specify.
FAQ: Satellite dish motor - electromotor characteristics
What is a satellite dish motor and how does it work?
A satellite dish motor is a device that is used to rotate a satellite dish in order to align it with a specific satellite in space. It is typically an electromotor that is controlled by a signal from a satellite receiver. The motor rotates the dish to a specific angle, allowing it to receive signals from the desired satellite.
What are the main characteristics of a satellite dish motor?
The main characteristics of a satellite dish motor include its torque, speed, and power consumption. The torque determines the strength of the motor and its ability to rotate the dish, while the speed determines how quickly the motor can rotate the dish. The power consumption refers to the amount of electricity needed to operate the motor.
How do I choose the right satellite dish motor for my satellite dish?
When choosing a satellite dish motor, you should consider the size and weight of your dish, as well as the satellite you want to receive signals from. The motor should have enough torque to rotate the dish, and its speed should be compatible with the satellite's orbit. It is also important to consider the power supply and compatibility with your satellite receiver.
Can a satellite dish motor be repaired if it breaks?
Yes, a satellite dish motor can be repaired if it breaks. The specific repair process will depend on the type and extent of the damage. In some cases, it may be more cost-effective to replace the entire motor rather than trying to repair it.
What are the common issues that can affect the performance of a satellite dish motor?
Some common issues that can affect the performance of a satellite dish motor include mechanical failures, electrical failures, and weather damage. Mechanical failures can be caused by worn out or damaged gears, while electrical failures can be due to faulty wiring or connections. Weather damage, such as strong winds or lightning strikes, can also cause damage to the motor.
