Satellite in circular orbit with friction
In summary: The Attempt at a SolutionI have a hard time setting this problem up. Will gravitational PE stay the same, so K1=K2?suppose you are rotating a stone tied to a string at some velocity/speed v.some air friction due to wind is doing -ve work on your stone . what will happen ?try to set up a diagram ... show frictional force against the displacement and try to visualize ...if the speed decreases what will happen to radius of rotation path?Will it decrease as well? But we don't know how far away the satellite is from the Earth.
reminiscent
131
A satellite with mass 848 kg is in a circular orbit with an orbital speed of 9640 m/s around the earth. What is the new orbital speed after friction from the earth’s upper atmosphere has done -7.50·109 J of work on the satellite? Does the speed increase or decrease?
K1+U1+Wfriction=K2+U2
one can assume a value of radius say r and see what happens .
some body said
.. A satellite orbiting in motion will speed up as its height (or distance from the earth) is decreasing and slow down as its height (or distance from the earth) is increasing .
is it true ..check
is it true ..check
I see. But I don't understand still because there are 2 unknown variables to find then.
first you may find the the argument on the basis of energy whether its speed decreases/increases.
what are the other variable to find.
I am getting confused because there is a distance that needs to be accounted for - the one from the Earth to the satellite. When you say "one can assume a value of radius say r and see what happens," do you mean keep R the same when calculating the change in gravitational potential energy? But wouldn't that make gravitational PE = 0?
No, drvrm means assume a stable orbit at a new r. What is the relationship between orbital radius and orbital speed?
Is it v=√GM/r?
For circular orbit though.
Do I solve for R by using v=√GM/r, using the initial velocity given?
No,both v and r change. The new v and r are related by that equation, as were the original v and r. In each case, you can express the total energy in terms of the v and r. So you know the original total energy and the energy lost. That gives you a second equation relating the new v and r to the new energy. Solve the pair of simultaneous equations.
i think i will again quote my post number 3 in which i asked you to rotate a stone in circular orbit by tying a string- go back to doing that little experiment.
what we do -we pull on the string and the stone rotates with a radius say r1. suppose one wants to decrease the radius a further pull on the stone is required - the stone moves with a constant speed during circular path. if one releases /reduces the pull the stone takes a path of larger radius.
In satellite motion the pull is given by Earth's gravitational field -which is smaller as radius increases- and larger as radius decreases-
think about the force required for circular motion- it has a special name -and Earth's gravitational pull provides that.
another feeling with stone the speed of rotation increases as the radius is shortened and decreases as the radius is longer.
that is being done on the satellite by the gravitational attraction- working in the above manner.
now i think we are in a better situation to judge as to what will happen if the frictional force has reduced the kinetic energy of satellite-
so the speed must have reduced and now the satellite can rotate in a larger orbit -having increased radius and that will be provided by the gravitational pull -which is reduced by the distance/radius increase.
so the new radius is different or larger -and try to calculate the change in the radius .
think how one can do the numbers!
Related to Satellite in circular orbit with friction
1. How does friction affect a satellite in circular orbit?
Friction can cause a decrease in the satellite's velocity, which can lead to a decrease in its orbital radius. This means that the satellite will gradually spiral in towards the Earth's surface and eventually burn up in the atmosphere.
2. What causes friction for a satellite in circular orbit?
The main source of friction for a satellite in circular orbit is the Earth's atmosphere. As the satellite moves through the atmosphere, it experiences air resistance which causes friction.
3. Can the effects of friction be completely eliminated for a satellite in circular orbit?
No, it is not possible to completely eliminate the effects of friction for a satellite in circular orbit. However, the effects can be minimized by choosing a higher orbit that experiences less atmospheric drag.
4. How does friction affect the lifespan of a satellite in circular orbit?
Friction can significantly decrease the lifespan of a satellite in circular orbit. The constant drag from the atmosphere will gradually slow down the satellite and cause it to fall towards Earth, eventually resulting in its destruction.
5. Can a satellite in circular orbit be powered to counteract the effects of friction?
Yes, a satellite can be powered by thrusters to counteract the effects of friction and maintain its orbit. This is known as station keeping and is often necessary for satellites in low Earth orbit to prevent them from falling back to Earth. However, this requires a constant supply of fuel and can only be sustained for a limited amount of time.
