Satellite Orbiting Earth Energy
In summary, the conversation discusses the calculation of the energy needed to move a satellite from a constant orbit of 99km to a circular orbit with an altitude of 195km. The equation used is E = (-GMm)/2r and the final answer should be in MJ. The correct answer is 2.26 x 10^-9 MJ.
blackheart
1. A 962kg satellite orbits the Earth at a constant altitude of 99km. How much energy must be added to the system to move the satellite into a circular orbit with altitude 195km?
2. Homework Equations :
E = (-GMm)/2r
[tex]\Delta E[/tex] = Ef - Ei
3. My work (which produced the wrong answer)...
Ei = (-GMEms)/(2(rE + 99000m))
Ef = (-GMEms)/(2r(E + 195000m))
[tex]\Delta E[/tex] = ((-GMEms)/2)((1/rf)-(1/ri)
The answer needs to be in MJ. I got 858MJ which is incorrect.
Hi blackheart. The method looks good. I got about half your answer.
Did you get 2.26 x 10^-9 for the difference between the 1/r terms?
Oh! I didn't divide by two... I have it now. Thanks a bunch.
Most welcome.
I would like to clarify that the formula used in the work provided is not accurate for this scenario. The formula used, E = (-GMm)/2r, is for calculating the potential energy of a satellite in an elliptical orbit, not a circular orbit. To accurately calculate the energy required to move the satellite into a circular orbit at a higher altitude, we need to use the formula E = (-GMm)/r, which calculates the potential energy of a satellite in a circular orbit.
Using this formula, we can calculate the initial energy (Ei) of the satellite in its current orbit at 99km altitude to be:
Ei = (-6.67x10^-11 Nm^2/kg^2)(5.97x10^24 kg)(962 kg)/(6.38x10^6 m + 99000 m) = -5.86x10^10 J
Next, we can calculate the final energy (Ef) of the satellite in its desired circular orbit at 195km altitude to be:
Ef = (-6.67x10^-11 Nm^2/kg^2)(5.97x10^24 kg)(962 kg)/(6.38x10^6 m + 195000 m) = -2.95x10^10 J
Therefore, the change in energy (ΔE) required to move the satellite into the circular orbit at 195km altitude would be:
ΔE = Ef - Ei = (-2.95x10^10 J) - (-5.86x10^10 J) = 2.91x10^10 J
Converting this energy into MJ, we get:
ΔE = 2.91x10^10 J x (1 MJ/10^6 J) = 29.1 MJ
Therefore, the amount of energy required to move the satellite into a circular orbit with altitude 195km is approximately 29.1 MJ.
FAQ: Satellite Orbiting Earth Energy
What is a satellite orbiting Earth energy?
A satellite orbiting Earth energy refers to the potential and kinetic energy possessed by a satellite as it orbits around the Earth. This energy is a result of the gravitational pull between the Earth and the satellite, and it is constantly changing as the satellite moves through its orbit.
How is the energy of a satellite orbiting Earth calculated?
The energy of a satellite orbiting Earth is calculated using the formula E = -GmM/r, where G is the gravitational constant, m is the mass of the satellite, M is the mass of the Earth, and r is the distance between the satellite and the center of the Earth. This formula takes into account both the potential and kinetic energy of the satellite.
Can the energy of a satellite orbiting Earth be changed?
Yes, the energy of a satellite orbiting Earth can be changed through various mechanisms such as thrusters, solar sails, or gravitational assists from other objects in space. By altering the speed or direction of the satellite, its energy can be increased or decreased.
How does the energy of a satellite orbiting Earth affect its orbit?
The energy of a satellite orbiting Earth is directly related to its orbit. A higher energy results in a larger orbit, while a lower energy results in a smaller orbit. This is because the energy of a satellite determines its speed and distance from the Earth, which are key factors in determining its orbit.
What are the applications of satellite orbiting Earth energy?
The energy of a satellite orbiting Earth has many practical applications, including communication, navigation, weather forecasting, and scientific research. It also allows for the deployment of satellites to different orbits and the exploration of distant objects in the solar system.
