Satellite Slingshot manoeuvre question
In summary, the problem involves a satellite performing a sling shot manoeuvre around a planet with a mass of 6.00 * 10^{24} kg. The satellite has a mass of 7.00 * 10^{2} kg and approaches the planet with a relative speed of 2 * 10^{3} ms^{-1} and impact parameter of 6.0 * 10^{7} m. The goal is to determine the closest approach distance, maximum speed of the satellite relative to the planet, and the angle through which it is deflected. The equations used include 1/r = \alpha \sqrt {2c/l^{2} + \alpha^{2}} \hspace {5 mm}
Crosshash
50
I've already attempted to work everything out by the way but my answers seem a little off.
A satellite performs a sling shot manoeuvre around a planet. The mass of the planet is [itex]6.00 * 10^{24} kg[/itex] and the mass of the satellite is [itex]7.00 * 10^{2} kg[/itex]. The satellite approaches the planet from a great distance with relative speed [itex]2 * 10^{3} ms^{-1}[/itex] and impact parameter [itex]6.0 * 10^{7} m[/itex]. Determine the closest approach distance, the maximum speed of the satellite relative to the planet and the angle through which it is deflected.
[itex] 1/r = \alpha \sqrt {2c/l^{2} + \alpha^{2}} \hspace {5 mm}sin (\theta + \theta_{o})[/itex]
where
[itex] \alpha = {G(M_{1}+M_{2})}/l^{2}[/itex]
[itex] l = V_{0}b[/itex]
[itex] c = 1/2 V_{0}^{2}[/itex]
I've attempted to solve the whole question, but I think my values for the closest approach distance and maximum speed are quite wrong.
[itex]M_{planet} = 6.00 * 10^{24} kg[/itex]
[itex]M_{satellite} = 7.00 * 10^{2} kg[/itex]
[itex]V_{0} = 2*10^{3} ms^{-1}[/itex]
[itex]Impact Parameter = b = 6.00 * 10^{7}m[/itex]
Deflection Angle
[itex]\sqrt {1 + 2c/l^{2}\alpha^{2}} \hspace {5 mm} sin \theta = -1[/itex]
[itex] c = (2 * 10^{3})^{2}/2 = 2*10^{6}[/itex]
[itex] l = (2 * 10^{3}) * (6.0*10^{7}) = 1.2*10^{11}[/itex]
[itex] \alpha = G(6.00*10^{24} + 7*10^2)/l^{2} = G(6*10^{24})/(1.44*10^{22}) = 4.002*10^{14}/1.44*10^{22} = 2.78*10^{-8}[/itex]
[itex]\sqrt {1 + 2c/l^{2}\alpha^{2}} = \sqrt {1 + \dfrac{2*(2*10^{6})} {(1.2*10^{11})^{2} (2.78*10^{-8})^{2}}[/itex]
[itex] \sqrt {1 + 0.36} = \sqrt {1.36}[/itex]
[itex] sin \theta = {\dfrac{-1} {\sqrt 1.36}}[/itex]
[itex] \theta = -59.04[/itex]
Angle of Deflection = 118.08
Unless anyone can point out a problem here, this seems fine.
Closest Approach Distance
[itex]\dfrac {1}{r_{min}} = \alpha \sqrt {\dfrac {2c}{l^{2}} + \alpha^{2}}[/itex]
[itex]\dfrac {1}{r_{min}} = 2.78*10^{-8} * \sqrt {\dfrac{4*10^{6}}{(1.2*10^{11})^{2}} + (2.78*10^{-8})^{2}}[/itex]
[itex]\dfrac {1}{r_{min}} = 2.78*10^{-8} \sqrt {1.051*10^{-15}}[/itex]
[itex]\dfrac {1}{r_{min}} = 9.01*10^{-16}[/itex]
[itex]r_{min} = 1.11*10^{15}m[/itex]
This seems quite large, and it means that my speed at closest approach is very small.
Speed at closest approach
[itex]\dfrac{v_{0}}{b} = \dfrac {1.2*10^{11}}{1.11*10^{15}} = 1.08*10^{-4}ms^{-1}[/itex]
This seems very small which is why I'm wondering if someone could tell me where I went wrong.
This is also the first time I've tried extensively using latex so pardon me if it's hard to read.
Thanks guys.
an unfortunate bump :(
Hello! It looks like you have made a good attempt at solving this problem. However, your values for closest approach distance and maximum speed do seem a bit off. Here are a few things to consider:
1. Check your units: Make sure all of your units are consistent throughout your calculations. It looks like you have used meters for distance, but your units for mass and velocity are in kilograms and meters per second, respectively. This may be causing some discrepancies in your final values.
2. Consider the direction of the deflection: In your attempt at solving for the deflection angle, you have assumed that the angle is negative and that the sine of the angle is equal to -1. However, this may not be the case depending on the direction of the satellite's motion and the location of the planet. It's important to carefully consider the direction of the deflection when solving this problem.
3. Check your calculations: It's always a good idea to double check your calculations to make sure you haven't made any errors or typos. It's possible that a small mistake in your calculations could lead to significantly different values for closest approach distance and maximum speed.
Overall, it looks like you have a good understanding of the equations and concepts involved in this problem. I would recommend going back and carefully checking your units and calculations to see if you can identify any errors. Also, make sure to consider the direction of the deflection when solving for the angle. Keep up the good work!
FAQ: Satellite Slingshot manoeuvre question
What is a Satellite Slingshot manoeuvre?
A Satellite Slingshot manoeuvre, also known as a gravity assist or swing-by, is a maneuver used by spacecraft to gain or lose speed and/or change direction using the gravitational force of a planet or other celestial body.
What is the purpose of a Satellite Slingshot manoeuvre?
The purpose of a Satellite Slingshot manoeuvre is to conserve fuel and increase the speed and range of a spacecraft without the need for additional propellant.
How does a Satellite Slingshot manoeuvre work?
During a Satellite Slingshot manoeuvre, the spacecraft flies close to a planet or other celestial body, and the planet's gravity pulls on the spacecraft, changing its trajectory and increasing or decreasing its speed. The spacecraft then uses this new trajectory and speed to continue on its journey.
What factors determine the success of a Satellite Slingshot manoeuvre?
The success of a Satellite Slingshot manoeuvre depends on various factors, including the mass and distance of the celestial body, the angle and speed of approach, and the direction and speed of the spacecraft.
What are some examples of successful Satellite Slingshot manoeuvres?
Some examples of successful Satellite Slingshot manoeuvres include the Voyager 1 and 2 spacecraft using Jupiter's gravity to gain speed and travel to the outer planets, and the Cassini spacecraft using multiple gravity assists from Venus, Earth, and Jupiter to reach Saturn.
