Saturated water tables:use temp or pressure
In summary, the table based on pressure gives you results where the two properties are less then the table based on temperature.
kdorsel
In my class we use two Saturated Water (Liquid-Vapor) tables. One is tabulated based on temperature and the other based on pressure.
For example if a state is defined by p=10 kPa and T=40 C and I need to find hf I can get either 167.57 or 191.82 depending on which table I use.
I am unsure which table to use.
Looking in terms of the temperature table at 40 C the given pressure is 7.384 kPa which is less than the state's pressure.
Looking in terms of the pressure table at 10 kPa the given temperature is 45.81 C which is more than the state's temperature.
I have looked at a few problems and whenever this happens one table will yield results were the two properties will be less then the two properties from the other table. In these questions the values needed are taken from the table where the two property values are smaller.
Thus hf=167.57.
Is my logic correct in using the table were the properties have the lowest values. Could I run into a state where one value is higher and the other one is lower ? Then what ?
As long as you're in the mixed-phase region (saturated water to saturated vapor, or 0% < quality < 100%) there is only one possible temperature for a given pressure, or only one possible pressure for a given temperature. The combination you cite (10 kPa and 40C) is not in that region, so it is not saturated water.
It seems that if you look at the saturated water tables @T you get Psat. If Psat < P than the substance is actually sub cooled.
Since the internal energy is mostly a function of temperature using the values found using the table @T gives you the same answers (with the table precision).
You can find the actual values using the table @ T using:
hsubcooled(T) = hsat + vsat(Psubcooled-Psat)
Where hsat, vsat and Psat are found from the table @Tsubcooled
Hopefully that makes sense.
FAQ: Saturated water tables:use temp or pressure
What is a saturated water table?
A saturated water table is a layer of the Earth's surface that is completely filled with water. This means that the pores and spaces between soil particles are completely saturated with water.
How does temperature affect a saturated water table?
Temperature has a direct impact on the amount of water that can be held in a saturated water table. As temperature increases, the water in the saturated water table will expand and cause the water table to rise. As temperature decreases, the water in the saturated water table will contract and cause the water table to lower.
How does pressure affect a saturated water table?
Pressure also plays a role in the level of a saturated water table. Higher pressure from above, such as from heavy rainfall or an increase in groundwater, can push the water table up. Conversely, lower pressure from above, such as from drought or pumping of groundwater, can cause the water table to lower.
Can temperature and pressure both affect a saturated water table?
Yes, temperature and pressure can both have an impact on the level of a saturated water table. Changes in temperature and pressure can cause the water table to fluctuate, sometimes leading to issues with groundwater and flooding.
How do scientists measure and monitor the level of a saturated water table?
Scientists use a variety of methods to measure and monitor the level of a saturated water table, including groundwater wells, piezometers, and remote sensing techniques. These tools allow for accurate and continuous monitoring of the water table, which is important for understanding and managing water resources.
