Say I have my pen on my desk; does it describe a geodesic?
  • Thread starter Dreak
  • Tags
    Geodesic
In summary, the conversation discusses the concept of geodesics and free fall in a gravitational field. It is explained that a test particle in free fall is described by a geodesic in space-time, and that the metric in a gravitational field is only locally Minkowskian. The difference between an object at rest in a uniform gravitational field and an object in free fall is also clarified. The conversation also touches on the difference between coordinate acceleration and proper acceleration in general relativity.
Dreak
52
Let's say I have my pen on my desk; does it describe a geodesic.?
Or not because there is the normalforce working on it.
It is certainly not a geodesic for exactly the reason you stated.
And what about someone falling from the sky? (let's assume that there is no fraction)?
Because I'm not certain about someone in freefall?
Is it ok if I write down my own thinking and you correct it?
If someone stands on the ground; we can go to a reference system in freefall by x'=x-1/2gt². So someone in freefall (falling from the sky, even if there is no fraction) also doesn't describe a geodesic.
The reason is because in a gravitational field; the metric is only local Minkowskian and thus not an inertial frame of reference?
Only outside a gravitation field, with no extern forces working on you (no rocket engines, no graf vield, no EM force...), I describe a geodesic?
A test particle in free fall is described by a geodesic in space-time, by definition. A person falling in the Earth's atmosphere under influence of the Earth's interior gravitational field alone will of course be described by a geodesic. Why would you suspect otherwise?
quote from my course:
"A direct result of the universal movement of objects in a gravitational field is that a constant gravitation field g can always be transformed away by going to an other reference system.
Indeed, if we go over to reference system S' by coordinationtrasformation: x' = x - 1/2gt², we find that a = 0. We say that reference system S is in freefall."
But the pen on my desk also has a = 0, so it's also in freefall?
Or am I messing 2 things up?
The pen on the desk doesn't have ##a = 0##. It has ##a = g## because there is a normal reaction force from the desk on the pencil. If you instead dropped the pen towards the floor then ##a = 0## (ignoring air resistance). The second scenario describes a freely falling pen; the first scenario describes an accelerating pen.
Remember the Einstein elevator thought experiments: an object at rest in a uniform (constant) gravitational field ##g## is equivalent to an object accelerating in free space with magnitude ##g## whereas an object in free fall in a uniform gravitational field ##g## is equivalent to an object freely floating in free space. In our case, the pen on the desk is at rest in the uniform gravitational field of the Earth hence it is accelerating according to general relativity whereas the pen in free fall in the Earth's uniform gravitational field is actually inertial according to general relativity.
Likes 1 person
Remember the Einstein elevator thought experiments: an object at rest in a uniform (constant) gravitational field ##g## is equivalent to an object accelerating in free space with magnitude ##g## whereas an object in free fall in a uniform gravitational field ##g## is equivalent to an object at rest in free space. In our case, the pen on the desk is at rest in the uniform gravitational field of the Earth hence it is accelerating according to general relativity whereas the pen in free fall in the Earth's uniform gravitational field is actually at rest according to general relativity.
Of course! Thanks, can't believe I messed that up.
No problem! More generally, if we have a particle described by some curve ##\gamma## in space-time with 4-velocity ##u^a##, the 4-acceleration of the particle (i.e. the acceleration of ##\gamma##) is given by ##a^b = u^a \nabla_a u^b## and ##a^b =0## if and only if ##\gamma## is a geodesic i.e. the particle is in free fall.
In GR geodesic worldlines are easy to identify. They are the ones where accelerometers read 0. An accelerometer strapped to the pen on your desk reads 1 g upwards.
You are confusing coordinate acceleration (dv/dt) and proper acceleration (what an acceleratometer measures). In General Relativity a geodesic world line corresponds to zero proper acceleration:
http://en.wikipedia.org/wiki/Proper_acceleration
In Newtons theory gravity is a real force that cancels the normal force, so the net force is zero for the pen on the table, and the world line is straight in undistorted space-time. In General Relativity there is only the normal force, which accelerates the pen, so it's world line is not geodesic (locally straight). See the apple hanging on the branch in this animation:
https://www.youtube.com/watch?v=DdC0QN6f3G4
FAQ: Say I have my pen on my desk; does it describe a geodesic?
Does placing my pen on my desk create a geodesic?
No, placing a pen on a desk does not create a geodesic. A geodesic is a curved path on a curved surface, such as the Earth's surface. It is not created by simply placing an object on a flat surface.
What is a geodesic and how is it related to my pen on my desk?
A geodesic is the shortest distance between two points on a curved surface. In the context of your pen on your desk, it is the shortest distance between the point where the pen is placed and any other point on the desk's surface.
Is the path my pen takes when I move it on my desk a geodesic?
No, the path your pen takes when moved on a desk is not a geodesic. This is because a geodesic is a straight line on a curved surface, and the path your pen takes is likely curved or zig-zagged.
Can I calculate the geodesic of my pen on my desk?
Yes, you can calculate the geodesic of your pen on your desk using mathematical equations and principles of geometry. However, the calculation may be complicated depending on the shape and curvature of your desk's surface.
Is the geodesic of my pen on my desk affected by external factors?
Yes, the geodesic of your pen on your desk can be affected by external factors such as the shape and curvature of the desk's surface, the weight and shape of the pen, and any other objects on the desk that may cause deviations in the path of the pen.
